zorg
Am sa verifica cablajul, nu m-am dus spre el ca fiind intermitenta si sa sters, am cam exlus cablajul, @gttinvalentin - ce rezistenat trebuie sa am pe senzor ? Temperaura dupa dpf 90 grade, temperatura in dpf 114 grade, astea sunt cu motorul cald
Aseara mi-a aparut si mie pentru prima data, bobina galbena ce pulseaza, in mers. Putere redusa, nu a mai tras. Am tras pe dreapta, am oprit motorul, am repornit, a disparut eroarea. Totul a revenit la normal si mi-am putut continua drumul de inca 50 de km pana acasa.
Azi am facut o diagnoza sa vad ce problema am avut. Stie cineva la ce se refera problema?
Monday,04,May,2015,07:53:27:62939VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.0.0Data version: 20130910VIN: WVWZZZ1KZBP148120   License Plate: GL27WIP-FAILMileage: 86735   Repair Order: ----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 1K (7N0)Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72VIN: WVWZZZ1KZBP148120   01-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: OK 000004-Steering Angle -- Status: OK 000008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000025-Immobilizer -- Status: OK 000037-Navigation -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000046-Central Conv. -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000056-Radio -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb   Part No SW: 03L 906 023 MK    HW: 03L 907 425 C   Component: 1,6l R4 CR td H43 8818     Revision: --H43---    Serial number: 00000000000000   Coding: 08114014032400080000   Shop #: WSC 00028 028 00023   ASAM Dataset: EV_ECM16TDI02103L 003005   ROD: N/A   VCID: 7BF51167F210BBC6C11-802ENo ASAM data for: "EV_ECM16TDI02103L" (VW36 *) 1 Fault Found:7462 - ROD - Unknown Error Code           - 00 [096]          Intermittent - Not Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Status: 00000001                    Fault Priority: 2                    Fault Frequency: 1                    Mileage: 86676 km                    Date: 2046.14.25                    Time: 20:17:11Readiness: 0000 0000
7462 - EGR Valve (N18) P0403 00 [232] - Malfunction
Problema foarte cunoscuta cu ansamblul EGR
gctinvalentin
alt egr
:( Multumesc de ajutor baieti. Vestea nu e prea buna, dar n-am ce sa ii fac in afara sa il schimb...Alte recomandari? Merita reconditionat?
F l o r i n
Din pacate nu prea ai alta varianta decat inlocuirea.... nu ai ce sa cureti/reconditionezi la el
Buna ziua,
Primesc urmatoarele erori cand scanez cu VCDS 12.12
Care-i buba?
Thursday,07,May,2015,15:33:34:40973
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
00-Steering Angle Sensor -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
33-Flux Capacitor -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Modificat de z3dulik
mario20vest
Intra separat pe modulele unde iti da malfunctie
ok, le-am luat pe rand si cum ca muulte
Address 01: Engine       Labels: 03G-906-018-BKP.clb
Control Module Part Number: 03G 906 018 A    HW: 03G 906 018 A
  Component and/or Version: R4 2.0l PPD1.1 G    9723
           Software Coding: 0000078
            Work Shop Code: WSC 00011 204 84557
                      VCID: 2345090EE275F506A91-8076
1 Fault Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 006 - Electrical Fault - Intermittent - MIL ON
Readiness: N/A
Address 03: ABS Brakes       Labels: 3C0-614-095-C2.clb
Control Module Part Number: 3C0 614 095 N    HW: 3C0 614 095 N
  Component and/or Version: ESP 440 C2     H015 0001
           Software Coding: 0013605
            Work Shop Code: WSC 00042 204 13260
                      VCID: 2D51EF36B4B133760F5-8078
1 Fault Found:
02839 - Wake-Up Line from Control Module for Electrical Parking Brake
            008 - Implausible Signal - Intermittent
Address 08: Auto HVAC       Labels: 3C0-907-044.lbl
Control Module Part Number: 3C0 907 044 Q    HW: 3C0 907 044 Q
  Component and/or Version: ClimatronicPQ46 042 0202
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 2F6DF53EBEBD41663D9-807A
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 - - - Intermittent
01809 - Unlicensed Version. Not all DTCs
            000 - will be decoded. - Intermittent
01810 - Unlicensed Version. Not all DTCs
Address 09: Cent. Elect.       Labels: 3C0-937-049-23-M.lbl
Control Module Part Number: 3C0 937 049 D    HW: 3C0 937 049 D
  Component and/or Version: Bordnetz-SG     H37 1002
           Software Coding: E8888F0700041A00000A00000F000000000959435C
            Work Shop Code: WSC 05311 000 00000
           Additional Info: 3C1955119   Wischer VW461  012  0503   1K0955559R  RegenLichtSens 010  1010
                      VCID: 2A5BE42A855F244EEA7-807F
4 Faults Found:
00887 - Switch for Emergency Flasher (E229)
02394 - Unlicensed Version. Not all DTCs
            012 - will be decoded.
02395 - Unlicensed Version. Not all DTCs
01800 - Light Switch (E1)
Address 15: Airbags       Labels: 3C0-909-605.lbl
Control Module Part Number: 3C0 909 605 F    HW: 3C0 909 605 F
  Component and/or Version: 01 AIRBAG VW8   029 2421
           Software Coding: 0012337
                      VCID: 29591B2680592F56E3D-807C
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - Intermittent - MIL ON
Address 19: CAN Gateway       Labels: 3C0-907-530-V1.clb
Control Module Part Number: 3C0 907 530 C    HW: 3C0 907 951 A
  Component and/or Version: Gateway         007 0040
           Software Coding: 3FFD2C04C21002
                      VCID: 21490306F869E716BBD-8074
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
01304 - Unlicensed Version. Not all DTCs
            004 - will be decoded. - Intermittent
Address 25: Immobilizer       Labels: 3C0-959-433-25.clb
Control Module Part Number: 3C0 959 433 H    HW: 3C0 959 433 H
  Component and/or Version:    IMMO         038 0364
           Software Coding:
            Work Shop Code: WSC 131071 1023 2097151
           Additional Info: 3C0905861A     ELV          021 0350
           Additional Info: Geraet 2097151
3 Faults Found:
01176 - Key
02823 - Unlicensed Version. Not all DTCs
02827 - Unlicensed Version. Not all DTCs
            008 - will be decoded. - Intermittent
Address 42: Door Elect, Driver       Labels: 1K0-959-701-MIN2.lbl
Control Module Part Number: 1K0 959 701 K
  Component and/or Version: Tuer-SG         024 2359
           Software Coding: 0000181
                      VCID: 3663C05A41E770AE7EF-8063
1 Fault Found:
01340 - Mirror Adjustment Switch
Address 52: Door Elect, Pass.       Labels: 1K0-959-702-MIN2.lbl
Control Module Part Number: 1K0 959 702 K
           Software Coding: 0000180
                      VCID: 377DCD5E46ED89A6659-8062
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio       Labels: 1K0-035-1xx-56.lbl
Control Module Part Number: 1K0 035 186 P
  Component and/or Version: Radio BVX       016 0023
           Software Coding: 0040400
                      VCID: 3365F94E52956586591-8066
5 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
00821 - Unlicensed Version. Not all DTCs
            011 - will be decoded. - Intermittent
00870 - Unlicensed Version. Not all DTCs
00871 - Bass Speaker Front Right (R23)
00873 - Unlicensed Version. Not all DTCs
Address 72: Door, Rear Right       Labels: 1K0-959-704-GEN2.lbl
Control Module Part Number: 1K0 959 704 F
  Component and/or Version: Tuer-SG         021 2417
           Software Coding: 0000144
                      VCID: 3467FA52579B62BE40B-8061
1 Fault Found:
00938 - Switch for Electric Window; Rear Right (E54)
Address 7D: Aux. Heat       Labels: 1K0-963-235.lbl
Control Module Part Number: 1K0 963 235 E    HW: 1K0 963 235 E
  Component and/or Version: PTC-Element         0404
           Software Coding:
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
Sincer... du.te la un specialist sa iti rezolve problemele. Nu ai nici macar interfata ok. Nu cred ca sta nimeni sa scrie o pagina despre tot ce ai acolo.
CA sfat, sterge toate erorile si vezi pe urma ce ramane....
F l o r i n
da... si sterge erorile si posteaza doar erorile care nu se sterg.
Dupa stergere, au mai ramas astea 3:
aici am becul pozitie dreapta ars - sterg eroarea si reapare cu becul din bord - deci ok pana schimb becul
09-cent.elect.
Tuesday,01,October,2013,08:47:34:40973
VCDS Version: Release 12.12.0
2 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
42-door elect.driver
Tuesday,01,October,2013,08:48:48:40973
1 Fault Found:
7D -aux.heat
Tuesday,01,October,2013,08:49:22:40973
Software Coding:
1 Fault Found:
014 - Defective
Eroarea asta nu o pot sterge - imi da: the request to clear codes was not asknowledged by the control module. please contact ross-tech
Schimba becul de pozitie. Vezi pe 42 in blocurile de masura cum lucreaza butonul de reglare oglinzi-eventual dat jos si curat cu spray de contacte sau alcool. Ptr PTC-se da jos si se repara-e tutorial pe forum in aria de golf v. Procedura e la fel ptr reparatie dar difera un pic demontarea.
Va salut.
Va scriu si eu pentru ca am o problema. Ieri am montat pe masina din semnatura (Audi A4 B6 1.9 TDI) cruise control. Maneta a fost cumparata noua OEM iar modulul coloanei de directie SH varianta highline (terminatia Q) pentru a suporta cc. Dupa lupte de ore intregi (greseala mea) de a recoda modulul ABS care si-a pierdut calibrarea cand am luat minusul de la baterie, m-am ales cu o eroare pe engine:
18097 - Powertrain Data Bus
            P1689 - 35-10 - Implausible Message from Elect. Load Controller - Intermittent
Mentionez ca nu imi functioneaza cc in momentul asta.
La measure blocks imi vede fiecare actionare a cc, si in modulul engine si in modulul steering wheel.
Ma poate ajuta cineva?
Va multumesc mult!
Raspunsul dat de colegul BLiTZ acum ceva vreme: Defectul semnifica ca pe reteaua CAN nu ajunge semnal de la incarcarea alternatorului. Verifica mufa de pe alternator, nu cumva sa fie scoasa sau vreun fir rupt.
Use search next time.
Am vazut raspunsul despre care vorbesti tu, dar nu sunt sigur ca se potriveste si la mine. Nu aveam eroarea asta inainte sa imi montez cc, a aparut doar dupa ce am schimbat modulul coloanei de directia si maneta cc.
E posibil sa fie o conexiune proasta facuta de mine acolo?
Stiu ca la Audi A6, la montarea CC retrofit se mai adauga un fir intre modulul coloanei de directie si ECU motor. Dar din cate am citit eu la Audi A4 nu este nevoie de acest fir...
Revin cu informatii, Astazi cand am plecat cu masina am zis sa verific daca merge cruise control... Uimit am vazut ca merge :D.
Nu am avut timp sa verific daca mai apare eroarea pe engine cu Powertrain data bus sau daca acum se poate sterge....
Dupa ce am bagat masina pe VCDS si am sters erorile alarma a luat-o razna..ieri de vreo 2-3 ori a pornit de nebuna, azi o data - ma astept la inca 1-2 ori. De ce?
A mai pornit odata de nebuna acum o luna, masina era deschisa, toate portierele si portbagajul deschise, muzica canta si deodata a pornit.
Cum as putea sa o opresc ca deja vecinii cred o iau razna - nu o aud mereu sa o opresc
mario20vest
salutare.
intampin o problema la un passat avf din 2002.
cand aprind pozitiile/faza scurta,becurile din far merg,in schimb nu merge iluminarea ceasurilor de bord,a climei,a casetofonului oem,a butoanelor de deschidere geamuri.am incercat si cu un alt confort si degeaba.
singurele erori sunt urmatoarele,dar rog daca se poate si o solutie pt eroarea 01131 de pe modulul confort,restul nu ma intereseaza,stiu ce am de facut.
va multumesc
Log-PASSAT VERDE-WVWZZZ3BZ3P250839.txt
Modificat de mario20vest
01131 - Control Circuit for Turn Signals : Unknown Switch Condition
Possible Symptoms
Locking Confirmation not working
Possible Causes
Fuse(s) faulty
Wiring/Connectors from/to Central Locking or Comfort Control Module faulty
Emergency Flasher Switch (E229) faulty
Possible Solutions
Check Fuse(s)
Check Wiring/Connectors from/to Central Locking or Comfort Control Module
Check Emergency Flasher Switch (E229)
http://wiki.ross-tech.com/wiki/index.php/01131
F l o r i n
remediezi problema, in functie de erorile/defectul gasit.
dezactivezi alarma cu VCDS-ul, din codarea modulului confort
salutare.
va multumesc
1. probeaza cu alt reostat - butonul de reglaj intensitate lumini.
2. daca nu merge cu altul functional, atunci trebuie mers pe cablaj
georgehada470
Am un Passat CC din 2009, DSG 170 cai.
Mi-a aparut martorul de bujie in bord si urmatoarele erori la tester:
P0544,
U1023
P1647
Mi-ati putea spune ce inseamna si ce ar trebui facut? Va multumesc anticipat
Uite cateva info:
Error code: 16928 P0544
This error code is' Generic OBD (for each carmaker same description and meaning). The following symptoms / causes / solutions specific to VAG cars; for other car brands which may differ in detail.
en temperature sensor exhaust bank 1 (G235) fault circuit
du Geber 1 für Abgastemperatur (G235) elektrischer Fehler im Kreis Strom
and Exhaust Gas Temperature Sensor Circuit (Bank 1) (G235) Malfunction
Additional information on the error codes
Possible symptoms:
No light emission
Possible causes:
Wiring and / or connections faulty
Sensor defect
Possible solutions:
Check / repair wiring and connections
Check (measuring blocks) / replace sensor
Additional info:
At a petrol car will occasionally play, when diesels he will play more often and have three.
Do not ignore the error, since exhaust gas pressure and outlet temperature play an important role in the automatic regeneration of the DPF
Error code: 18055 P1647
   This error code is 'Manufacturer Specific' (for each car maker a different definition and meaning). The following description / symptoms / causes / solutions specific to VAG cars.
en Check coding of control devices in powertrain
du Codierung / Variants of Steuergeräte im Antriebsstrang GÞltigkeit
Please check and coding of ECUs in Data Bus Powertrain
Possible symptoms:
     unknown
Possible causes:
     Error LED (= MIL) lights
Possible causes:
     The coding of the powertrain in combination with the control module is incorrect or incomplete
Possible solutions:
     If found in an Audi A4 (8E): Brake Electronics (Bosch 8.0)
         Check the coding of the powertrain control modules, especially check the related airbag 9:41 Adaptation Channels 050 & 051
F l o r i n
sterge eroarea si vezi cat de repede apare.
daca nu se sterge sau apare, verifica cablajul si conectorul la senzor - daca este ok, atunci trebuie inlocuit. Este vorba de  - sensor exhaust bank 1 (G235)
  • Aerofan pinned this topic
    • Ady71
