zorg
Nu iti vede calculatorul de xenon/leveling - verifica-i alimentarile, etc -daca sunt ok, trebuie probat cu altul.
z35 - rezistenta suplimentara de incalzire din habitaclu - trebuie reparata -
Salut.
Am si eu urmatoarele erori pe G6 1.6 TDI.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 087 H    HW: 5K0 937 087 H
   Component: BCM PQ35 H    011 0035
   Revision: BE011001
   Coding: 40000A3A982D02C040080088140081E40371028874A08DF05CC00000A040
   Shop #: WSC 00066 123 12345
   VCID: 3A7BD463B5AA42CE9A7-806F
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 168
                    Mileage: 150706 km
                    Time Indication: 0
                    Date: 2059.14.28
                    Time: 17:53:33
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 168
                    Mileage: 150706 km
                    Time Indication: 0
                    Date: 2059.14.28
                    Time: 17:53:34
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 170F00
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3169F34F60DC81962BD-8064
2 Faults Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 208
                    Mileage: 150706 km
                    Date: 2059.14.27
                    Time: 16:15:32
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 208
                    Mileage: 150706 km
                    Date: 2059.14.27
                    Time: 16:15:34
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 031209F1000053
   Coding: E9A07F56000A02000002
   VCID: 69D95B2F408C395623D-803C
5 Faults Found:
00457 - Control Module for Network (J519)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 208
                    Mileage: 150706 km
                    Time Indication: 0
                    Date: 2059.14.27
                    Time: 16:15:32
01330 - Central Control Module for Central Convenience (J393)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 208
                    Mileage: 150706 km
                    Time Indication: 0
                    Date: 2059.14.27
                    Time: 16:15:32
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 149668 km
                    Time Indication: 0
                    Date: 2058.14.06
                    Time: 17:40:20
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 208
                    Mileage: 150706 km
                    Time Indication: 0
                    Date: 2059.14.26
                    Time: 15:59:05
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 149668 km
                    Time Indication: 0
                    Date: 2058.14.06
                    Time: 17:40:19
Address 7D: Aux. Heat
Cannot be reached
Mi-a copiat cineva codul de la alta centrala si de atunci am ramas cu aceste erori.
Ce este de facut?
Aux Heat nu imi mai merge de pe telecomanda sa pornesc din casa + acele erori de la codarea incorecta probabil.
Pune inapoi vechiul cod.
salut. detin un golf 5, 1.9 tdi, la care i-am facut o scanare si mi-a dat urmatoarele erori. de la ce provin? ms
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 7D
VIN: WVWZZZ1KZ5W067353   Mileage: 74900km/46540miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC 0200SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D0388652
   Coding: 0000071
   Shop #: WSC 66565 257 00032
   VCID: 65C7C1D6AC16AC3608B-8030
2 Faults Found:
16785 - EGR System
            P0401 - 000 - Insufficient Flow
             Freeze Frame:
                    RPM: 1764 /min
                    Torque: 46.0 Nm
                    Speed: 44.0 km/h
                    Load: 16.9 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 11000000
                    Mass Air / Rev.: 230.0 mg/str
                    Mass Air / Rev.: 600.0 mg/str
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 182.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.93 V
                    Bin. Bits: 00000100
                    Temperature: 0.9°C
                    Bin. Bits: 00110000
Readiness: 1 1 0 0 0
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 CS
   Component: Climatic PQ35   081 0404
   Shop #: WSC 00000 000 00000
   VCID: 77FB9B9E06BA2EA6AA7-8022
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 01 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0HVMFS
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 316F6586A85E3096243-8064
   Subsystem 1 - Part No: 1K0 909 605 H
   Subsystem 2 - Serial number: 6332MSME1B7D4C03
   Subsystem 3 - Serial number: 6342MSME0D494704
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000052
   Shop #: WSC 01392 785 00200
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 K
   Component: Radio GR0           0014
   Revision: 0001002S    Serial number: VWZ2Z2D1006795
   Coding: 0020200
   VCID: 2E557EFAB9602F6E391-807B
1 Fault Found:
00668 - Supply Voltage Terminal 30
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
   VCID: 30696082A354399E2BD-8065
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
membrana la capsula EGR sparta si nu se mai deschide Egr, o bujie arsa. restul au aparut de la o cadere de tensiune...
Dar lipsa de vacum nu ar face la fel? Ma intreb eu,sau elecrovalva,sau s-a blocat egrul de calamina sau sau
cadere de tensiune sau nu eu zic ca bujia nr 3 este arsa,nu e problema daca nu o schimbi,am avut 3 arse timp de 6 luni,pornea si mergea la fel de bine.
Modificat de popalin90
Am facut o scanare cu vag com la un touran 2.0 azv din 2004 si mi-au aparut  urmatoarele erori ? Ma poate lamuri cineva? Daca am gresit locatia postarii imi cer scuze ...
Log-1-WVGZZZ1TZ4W172518-215430km.txt
Chillbrothers
Salut. Detin un GOLF 5 TDI 105 CP, cod motor BLS, an 2007 si in urma unei scanari mi-a aparut eroarea asta:
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 03G 906 021 HB    HW: 03G 906 021 HB
  Component and/or Version: R4 1,9L EDC  000SG  9000
           Software Coding: 0000071
            Work Shop Code: WSC 01279 785 00200
                      VCID: 66C7B2AB28F7
1 Fault Found:
005215 - Mass Air Flow during Regeneration too High
               P145F - 000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11110000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 167891 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:12:46
             Freeze Frame:
                    RPM: 1848 /min
                    Speed: 30.0 km/h
                    Load: 20.8 %
                    Duty Cycle: 100.6 %
                    Duty Cycle: 13.8 %
                    Mass Air / Rev.: 385.0 mg/str
                    Mass Air / Rev.: 735.0 mg/str
Readiness: 0 0 0 0 0
Daca ma puteti ajuta sa imi spunei de la ce provine? Tin sa mentionez ca in mers mi s-a aprins arcul acela care este probabil de la bujii. Multumesc
robertciprian
Salut, am nevoie si eu de ajutor. am un passat b6 si nu mai porneste. S-a mai intamplat odata dar si-a revenit singur dupa cateva zile, acum are peste o saptamana de cand sta nemiscat. Dupa o scanare au aparut aceste erori:
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7E250206   Mileage: 131430km/81666miles
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
   Part No SW: 03G 906 021 NG    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  9308
   Revision: --H07---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 80093 222 69422
   VCID: 71E262AE687E0C90DEB
1 Fault Found
005716 - Please check DTC Memory of Instrument Cluster
               P1654 - 000 -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Mileage: 131439 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:30:52
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.32 V
                    Temperature: 13.5°C
                    Temperature: 10.8°C
                    Temperature: 12.6°C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: Redir Fail!
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775405152
   Coding: 0013569
   Shop #: WSC 05311 000 00000
   VCID: DBBEA0061AF216C0947
2 Faults Found
00650 - Clutch Pedal Switch (F36)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 43
                    Mileage: 130758 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:05:28
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 43
                    Mileage: 130758 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:05:28
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AT    HW: 3C0 907 044 AT
   Component: ClimatronicPQ46 112 0606
   Revision: 00112021    Serial number: 00000000000000
   VCID: 73EE68A612623E802C7
1 Fault Found
01317 - Control Module in Instrument Cluster (J285)
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01111101
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 11
                    Mileage: 131439 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:02:30
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000007061845
   Coding: 01880F0700041A00470A00000F00000000095D435C0001
   VCID: 6CDC73DA4F5CE178EDD
   Subsystem 1 - Part No: 3C1 955 419 A
   Component: Wischer 050407 003  0205
   Coding: 00046997
   Shop #: WSC 05311
1 Fault Found
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 130680 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.75 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1P9DUEH.
   Coding: 0012354
   VCID: 3064A7AAA3F44598915
1 Fault Found
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
   Component: Lenksäulenmodul 006 0010
   Revision: 00006000    Serial number: 3C9953507AB
   Coding: 0000012
   VCID: 336EA8A652E27E80EC7
No fault code found.
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 852 J    HW: 3C0 920 852 J
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00012 000 00000
   VCID: 2A50B5C285283F485F1
1 Fault Found
00779 - Outside Air Temp Sensor (G17)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 131439 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:31:16
Address 19: CAN Gateway        Labels: Redir Fail!
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C07508032A
   Coding: 3DFD0C04C22002
   VCID: 214252EEF81EFC100EB
1 Fault Found
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 38
                    Mileage: 130680 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:11:56
Address 25: Immobilizer        Labels: Redir Fail!
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 39729A8E708E84D026B
   Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000073178402
   Coding: 0000181
   VCID: 3B7E80867AB2B6C0347
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.134 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 346CABBA57EC79B8F5D
1 Fault Found
            000 -  -
Address 46: Central Conv.        Labels: Redir Fail!
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030E763004941570084F0B607CA0
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000105078501
   Coding: 0000180
   VCID: 3C7C839A7FBCB1F83DD
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0000011
   VCID: 244C5BFAE70CE93865D
   Part No: 1K0 035 186 T
   Component: Radio GR0       020 0023
   Revision: 0002006S    Serial number: VWZ2Z2G3562308
   Coding: 0040400
   Shop #: WSC 05314 000 00000
   VCID: 37769CB6469A92A0D0F
1 Fault Found
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1119
   Revision: 11006001    Serial number: 00000001688059
   Coding: 0000144
   VCID: 3D7A8E9E64A6B8F00A3
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1119
   Revision: 11006001    Serial number: 00000001695974
   Coding: 0000144
   VCID: 3E78899269A0A3E8139
End   ---------------------------------------------------------------------
Multe le banuiesc ca ar fi de la o cadere de tensiune( am schimbat si bateria) dar problema mare e ca nu porneste. Am verificat toate sigurantele si sunt intregi si la locul lor. Orice sugestie e binevenita in conditiile in care nu am nici un service decent in zona si reprezentanta VW e la 90km.
Multumesc anticipat.
Ce simptome are?
Afiseaza in continuare press clutch chiar daca e apasat ?
robertciprian
Principala simptoma e ca nu porneste, ventilatorul de la climatizare nu se opreste  (banuiesc ca e de la senzorul de temperatura exterioara), si in bord sunt afisate erorile de la senzorul de pozitie al volanului si abs.
       Va salut. am o problema ciudata. zilele trecute eram in service si aveam o mica scurgere de ulei la chiulasa. a luat tipu un spray de frana si a spalat putin pe acolo sa vedem apoi cam de unde e. am plecat totul ok. la vreo ora am pornit motorul am facut cativa metri si aud un beep mai lung si abs , tcs , frana de mana aprinse. intial am zis sa opresc dar pana sa trag pe dreapta nu mai era nimic aprins si masina mergea normal pentru ca apoi sa se aprinda din nou dar acum impreuna cu steering-ul. se sting din nou mai putin steering-ul care a ramas aprins ( nu mai aveam servo). am oprit motorul fara sa scot cheia din contact si s-a luat curentul :). pur si simplu ptr o secunda s-a oprit tot dupa care a pornit din nou casetofonul. dar ora era resetata la fel si kilometrajul(nu cel total).am resetat codul de eroare cu vcds-ul. azi la fel . am scanat masina din nou si singura eroare e "01288 - Terminal 30; Steering Assist 06-10 - Signal too High - Intermittent".
     ma gandesc ca sprayul a afectat vreo mufa ceva. ce ar trebui sa verific ?
scan.txt
Cf ross tech:
01288 - Terminal 30; Steering Assist: Signal too High
Possible Causes
Fuse(s) faulty
Battery Voltage too High
Possible Solutions
Check Fuse(s)
Check Power Supply/Battery/Generator
Check Wiring/Connectors for Corrosion and/or faulty Pins
Verifica cat incarca alternatorul in vcds,siguranta fire,mufe
Modificat de mario20vest
am facut si eu o scanare la touran 2003, motor AVQ.ma ajutati va rog  cu interpretarea erorilor?
Saturday,04,April,2015,15:16:41:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVGZZZ1TZ4W095050   License Plate:
Mileage: 248900km-154659mi   Repair Order:
Chassis Type: 1T (1K0)
VIN: WVGZZZ1TZ4W095050   Mileage: 248900km/154659miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Sporadic communication error 1000
56-Radio -- Status: OK 0000
   Part No SW: 03G 906 016 BT    HW: 028 101 176 1
   Component: R4 1,9L EDC 0000SG  5644
   Revision: 12345678    Serial number: VWZ7Z0C8563680
   Coding: 0000072
   Shop #: WSC 10191 599 00000
   VCID: 76E300530132E6AEBEF-8023
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0021190
   Shop #: WSC 01324 785 00200
   VCID: 3A7BD46375AA42CE9A7-806F
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 063 0201
   VCID: 2F6DF537BEE897663D9-807A
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000000341009
   Coding: 00890F020004100000120C000000000000
   VCID: 377DCD5746B85FA6659-8062
   Subsystem 1 - Part No: 1T0 955 119 B  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0201
   Coding: 16711828
   Shop #: WSC 00000
3 Faults Found:
01207 - Control Module for Auxiliary Heater (J364)
00526 - Brake Light Switch-F
01504 - Bulb for License-Plate Light (X)
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605     HW: 1T0 909 605
   Component: 05 AIRBAG VW62 0506 2112
   Coding: 0012341
   VCID: F2EBBC43ED5A7A8E127-80A7
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0000002
   VCID: EFEDB537FE685766FD9-80BA
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1T0 920 850 G
   Component: KOMBIINSTRUMENT VDD 3550
   Coding: 0002101
   Shop #: WSC 00844 233 87252
   VCID: 3467FA5B57CEB4BE40B-8061
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2100103A184AED
   Coding: 3D0F0340078002
   VCID: 275D1D179618CF26F59-8072
1 Fault Found:
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 142
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:12:12
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3550
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0127
   Coding: 0000052
   VCID: F4E7BA5B974E74BE00B-80A1
   Part No: 1K1 909 144 E
   Component: EPS_ZFLS Kl.0       1202
   VCID: 2D51EF3FB4E4E5760F5-8078
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 00E802087F2D8404084B0100
   Shop #: WSC 10105 599 10484
   VCID: 306FF64BA3D6889E243-8065
   Part No: 1T0 959 702
   Coding: 0000052
   VCID: F5E1875F9C346DB6375-80A0
   Part No: 1K0 035 186 AF
   Component: Radio GR0       036 0034
   Revision: 0003606S    Serial number: VWZ2Z2H1173834
   Coding: 0020401
   Shop #: WSC 35110 377 08192
   VCID: 6ADB2423458A324E2A7-803F
Cateodata mai primesc pe "engine" si eroarea de mai jos
Control Module Part Number: 03G 906 016 BT    HW: 028 101 176 1
  Component and/or Version: R4 1,9L EDC 0000SG  5644
           Software Coding: 0000072
            Work Shop Code: WSC 10191 599 00000
1 Fault Found:
             Freeze Frame:
                    RPM: 1344 /min
                    Torque: 70.0 Nm
                    Speed: 0.0 km/h
                    Load: 20.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 11000100
                    Temperature: 2.7°C
                    Bin. Bits: 10110000
bujia la cilindru 3 arsa, in rest becuri arse la numar, switch frana defectuos,
Fabian Tiberiu
Ma puteti ajuta si pe mine in legatura cu aceste erori...va rog.
VCDS Windows Based VAG/VAS Emulator Version: Release 12.12.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000
Diagnostic Trouble Code Report Saturday,04,April,2015,18:33:14:65217
VIN: License Plate: Mileage: 265830km-165179mi Repair Order:
Control Module Part Number: 1J0 959 799 AH Component and/or Version: 3C Zentral-SG Komf. 0001 Software Coding: 04097 Work Shop Code: WSC 00028 VCID: 840D145094E55E3E30B-49D8 Additional Info: 1J1959801D 3C Tõrsteuerger. FS0002r Additional Info: 1J1959802E 3C Tõrsteuerger. BF0002r Additional Info: 1J4959811D 3C Tõrsteuerger. HL0002r Additional Info: 1J4959812D 3C Tõrsteuerger. HR0002r
6 Faults Found: 01329 - Convenience System Data Bus in Emergency Mode 35-10 - - - Intermittent 01332 - Door Control Module; Passenger Side (J387) 49-10 - No Communications - Intermittent 00929 - Locking Module for Central Locking; Front Passenger Side (F221) 54-10 - Incorrectly Equipped - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - -00912 - Window Regulator Switch; Front Left (E40) 27-10 - Implausible Signal - Intermittent 00944 - Heated Exterior Mirror; Passenger Side (Z5) 35-00 - -
Nu ma lasa sa atasez fisieru...si l-am pus asa :)
Si ar mai fi o mica problema...in alipirea de sus...imi arata un anumit km. in bord..si cand am dat sa vad km reali imi da ceea ce se vede in poza
post-134669-0-27491300-1428171156_thumb.
Modificat de Fabian Tiberiu
trebuie facute niste verificari ca sunt ceva fire rupte pe undeva, etc
a doua parte e simplu... ai auzit de kilometraj dat inapoi?  ar mai fi variante cu inlocuire calc motor, sau ceasuri... dar mai putin plauzibile...
Modificat de andrei_221
Fabian Tiberiu
Pt prima parte nu e posibil sa fie modulul de comfort ???Iar pt a 2-a ma gandeam eu sa fie dati inapoi...asta e...are 3 ani de cand e la mine :) ....mergem inainte
poate fi si modulul... e usor de verificat , e sub mocheta la picioarele soferului la Passat 3B
Km de ce sa fie dati innapoi,se vede km exprimati in mile si km iar daca calculezi iese o diferenta de vreo 2000 km , ceea ce e normal.
pe ceasurile de bord  : VIN: License Plate: Mileage: 265830km-165179mi Repair Order:
pe calc de motor : ce se vede in poza, adica : 338805 km....
e mai mare diferenta...
terminatorule daca tot postezi citeste mai atent despre ce se vorbeste.
VIN: License Plate: Mileage: 265830km-165179mi Repair Order: atat i arata lui in bord.La asta se refera nu la diferenta dintre mile si km.73.000 km sunt dati inapoi.
Fabian Tiberiu
post-134669-0-99118200-1428216007_thumb.
Unde este pozitionat acest senzor G89 ???ma gandesc ca el este defectul,sau?se poate tot din cauza lui cateodata sa bage doar cald sau doar rece??
post-134669-0-34692000-1428216026_thumb.
Temperatura lichidului mi-o arata,dar cand dau pe verificare EGR sau pe alte functii imi da 0...ma gandesc ca ar trebui sa pornesc motorul..se poate intampla ceva rau daca il pornesc in timp ce este cablu conectat la computerul masinii???
Stiu, ca poate unora vi se pare amuzant,dar nepricepand-uma ,am zis ca mai bine intreb inainte decat sa plang :) .
post-134669-0-65386500-1428216681_thumb.
Si de ce imi da aceste erori cand dau pe anumite functii ???Din cauza ca nu e pornita masina sau nu fac eu ceva bine???
Va multumesc pt sfaturi si mii de scz. pt bataile de cap . :beer:
senzorul ala e undeva sub filtrul de polen, pe tubulatura de aer proaspat.
nu ai ce cauta la OBD II functions , ca alea sunt pentru altceva.
tu ai treaba cu Select module sau Autoscan
cand apare No response from controller incerci sa intrii pe calculatoare care nu exista pe masina ta
  • Aerofan pinned this topic
    • rs4
