zorg
Ti-am raspuns si dincolo. Nu din cauza debitmetrului ai luat limp. Un debitmetru defect sau care masoara aiurea se observa dupa puterea scazuta a masinii, fum negru mult la accelerari, consum marit.
Din cauza debitmetrului nu iei limp mode cu eroarea "positive deviation" ci cea cu "negative deviation".
Sent from my iPhone4S using Tapatalk
cine imi poate spune si mie cate ceva despre erorile gasite aici
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CE HW: 03G 906 018 CE
Component: R4 2.0l PPD1.5 G 9384
Revision: --H35--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 6AD1B30C4564F6E
2 Faults Found:
004720 - PD Unit Injector: Cylinder 4 (N243)
P1270 - 006 - Regulation Range Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 109
Reset counter: 39
Mileage: 167343 km
Time Indication: 0
Date: 2012.10.26
Time: 07:29:38
Freeze Frame:
RPM: 1760 /min
Torque: 56.0 Nm
Speed: 56.0 km/h
78.39 %
Text: 5.125 uF
Text: 13.50 mJ
Text: 12 mJ
Raw, Form. N/A: 000 000 000
001652 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 006 - Electrical Fault - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 170392 km
Time Indication: 0
Date: 2013.01.21
Time: 15:19:31
Freeze Frame:
RPM: 832 /min
Torque: 48.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 14.24 V
Bin. Bits: 10110000
Temperature: 30.0°C
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667968895
Coding: 0013602
VCID: 32616B6CAD347EE
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67D7CA385676CB6
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004466798
Coding: E5808F0700041A00000A00000F00000000095D435C0000
VCID: 30656164A3384CE
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 080906 014 1201
Coding: 00208933
Shop #: WSC 00028
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 163
Mileage: 169722 km
Time Indication: 0
Date: 2013.01.13
Time: 09:07:00
Freeze Frame:
ON
Voltage: 9.90 V
OFF
ON
ON
ON
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 030 2522
Revision: 10030000 Serial number: 003B1PJCXS47
Coding: 0012339
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507P
Coding: 0000111
VCID: 2E597F1CB90C5AE
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 X HW: 3C0 920 871 X
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 65536 645 577705
VCID: 39735C4070428D6
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C069040365
Coding: 3DFD2E04C21002
VCID: 21439420F8D2F56
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 T HW: 3C0 959 433 T
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3B7F46487A7EBF6
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12007001 Serial number: 00000072668918
Coding: 0000245
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
VCID: 346D6D74572070E
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0218
Coding: 00910A0001860E763004941570084F0B605C00
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12007001 Serial number: 00000099068918
Coding: 0000244
VCID: 3C7D45547F70B8E
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio GR0 019 0023
Revision: 0001905S Serial number: VWZ2Z2F2206363
Coding: 0040400
VCID: 356B50705C5A696
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000631397
Coding: 0000208
VCID: 3D7B4850646AB16
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0420
Coding: 0161211
1 Fault Found:
01477 - System Switched Off
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 156
Mileage: 169673 km
Time Indication: 0
Date: 2013.01.10
Time: 11:42:00
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000625068
Coding: 0000208
VCID: 3E794F5C696CAAE
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B7810B40A216
End ---------------------------------------------------------------------
va mutumesc frumos
*Injector 4 cu probleme = necesita mai multe masuratori
*bujia nr 4 cu probleme = trebuie masurata bujia si / sau conexiunea
*Bateria slaba = pe 13.01.2013 ai avut tensiune foarte mica in baterie (aprox 9V). Verifica incarcarea sau bateria e veche.
Cam astea ar fi cele mai importante. Inaite de a te apuca de alte masuratori, sterge erorile si mai scaneaza odata dupa o zi doua si vezi ce erori se mai inregistreaza.
asa este mi-a pornit la a 4 cheie foarte lunga atunci (am tinut-o pe redresor asta am rezolvat-o) iar erorile acelea pe injector le am de peste un an de cand am masina degeaba le sterg ca reapar
apropo care este nr4 ?...si alea cu basul pe radio? ce vrea sa zica am inversat firele in boxe sau cum?
.multumesc mult de tot
Au fost deconectate (posibil cu cass-ul alimentat). Ai avut ceva probleme la portierele din fata?
da am pus folie si am dat fetele de usa jos va multumesc frumos
p.s. cineva ma invatat sa curat mufa de la injector 4 ( a mentionat faptul ca nu are cum sa pice si bujie si injector in acelasi timp si ca este vorba doar de contact electronic)
Doresc si eu niste lamuriri legate de erorile aparute. Mentionez ca masina era in service la momentul aparitiei lor. Dupa cum se vede, masina avea 40 Km/h in momentul aparitiei erorilor. Au apasat oare frana de mana in mers? Va multumesc.
Scan-333.txt
schimba switch-ul de la ambreiaj si vezi dupa aia daca se sterg erorile.
Nu e switch, e un senzor si il gasesti in compartimentul motorului.
Erorile au aparut simultan (Time: 13:12:58), dupa cum se observa, si o singura data. Am sters erorile si nu au mai reaparut. Oricum sunt curios cum au putut ajunge la 40 km/h in 10m. Asta fiind distanta intre locul de parcare si intrarea in service.
Modificat de DiLivio
Dupa ce s-a efectuat curatirea turbinei, masina a plecat la drum lung si s-a ales cu erorile urmatoare:
- de unele mai stim, de altele mai aprofundam materia:)
Address 01: Engine Labels: 03G-906-016-BKC.lbl
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 160057 km
Time Indication: 0
Date: 2000.00.00
Time: 04:08:48
Freeze Frame:
RPM: 2667 /min
Speed: 116.0 km/h
Load: 75.3 %
Voltage: 14.29 V
Bin. Bits: 00001000
Absolute Pres.: 2172.6 mbar
Absolute Pres.: 2499.0 mbar
000772 - Cylinder 4: Misfire Detected
P0304 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 162478 km
Time Indication: 0
Date: 2000.00.00
Time: 13:41:10
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Inj. Quantity: 2.96 mg/str
Temperature: 44.1°C
(no units): 0.0
Readiness: 0 0 0 0 0
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Shop #: WSC 01324 785 00200
3 Faults Found
01406 - No Flame
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 246
Mileage: 159739 km
Time Indication: 0
Freeze Frame:
Start
Temperature: 25.0°C
Temperature: 24.0°C
Voltage: 14.53 V
01407 - Flame Extinguished
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 246
Mileage: 160674 km
Time Indication: 0
Freeze Frame:
Start
Temperature: 64.0°C
Temperature: 63.0°C
Voltage: 14.45 V
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 162253 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2825
Coding: 0000181
1 Fault Found
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CB HW: 1K0 959 433 CB
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 199002085103087F2D06840560084F01E0BC00
Shop #: WSC 02800 995 88888
1 Fault Found
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 235
Mileage: 159791 km
Time Indication: 0
Date: 2000.00.00
Time: 23:01:54
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000181
3 Faults Found
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
Address 69: Trailer
Cannot be reached
trepidatia persista la relanti, conform post 4790; astazi am observat ca valoarea la relanti pe inj 4 sare din schema, parca era 2.99.
cind trepida, valoarea relantiului scadea si ea...
daca acceleram usor, valoarea pe inj 4 scadea....
e posibil ca injectorul sa fie obosit sau sa fie un contact imperfect pina cind se incalzeste si se mai dilata ceva pe acolo...
Modificat de DragosR
Dupa ce s-a curatat turbina s-a refacut planeitatea? Overboost condition - geometria agata sau probl la actuator. Vezi ca ai unitatea de webasto blocata - nu mai merge cu rezervorul pe gol - de aceea se blocheaza. Deblocheaz-o ca e pacat de ea, mai ales in perioada ce urmeaza sa nu beneficiezi de "puterea" ei :)
i-am deblocat webasto colegului iar mecanicul nostru a simtit ca nu e ceva in regula cu actuatorul....cind am luat eu primul limp :)
Sa-i verifice si geometria variabila - asta daca nu a schimbat-o si singura problema ar fi de la actuator. La mine cand imi dadea limp a fost de la geometrie - am preferat sa o schimb decat sa ma apuc de curatat si refacut planeitate. De atunci (2008) nu am mai avut nici o problema cu ea.
Dupa cateva incercari nereusite, azi am fost din nou la diagnoza si si m-am trezit cu ceva nou...
2 Faults Found:
01410 - Heater Over-Temp
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 50
Mileage: 127173 km
Time Indication: 0
Date: 2000.00.00
Time: 06:43:08
Freeze Frame:
Ctrl. Pause
Temperature: 148.0°C
Temperature: 40.0°C
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 50
Mileage: 127173 km
Time Indication: 0
Date: 2000.00.00
Time: 06:43:08
Ce ar mai putea fi de data asta?
Amintesc ca dupa ce am schimbat pompa de recirculare, butonul de pe climatronic ramanea aprins atat timp cat il lasam..(cateva minute in care rabdarea mea ceda asteptand sa aud ventilatorul de initiere a arderii)... dupa aceste erori ..... webasto a intrat in LOCKED si ledul de pe climatronic se stinge dupa 1-2 secunde... si gata e mort....
Ce sa-i mai fac?
Webasto se deblocheaza tot din vcds. Verifica sa nu aiba vreun dop de gheata pe evacuare.
Possible Symptoms
  • Heater not working
  • Heater Module refuses to clear Fault Codes
Possible Causes
  • Fuel Level low
Possible Solutions
  • When found in Aux Heater module of VW Touareg (7L), unlock heater module by saving a 1 in Adaptation Channel 003, then clear fault codes.
  • When found in Aux Heater module of VW Touran (1T, and similar models), unlock heater module by saving a 1 in Adaptation Channel 042, then clear fault codes.
  • When found in Aux Heater module of VW Transporter (7H), unlock heater module by saving a 1 in Adaptation Channel 003, then clear fault codes.
  • When found in Aux Heater module of Audi A8 (4E), unlock heater module by saving a 1 in Adaptation Channel 007, then clear fault codes.
Modificat de misufha
ma poate ajuta un coleg de forum sa imi zica ce este asta si cum as putea sa rezolv defectul sunt mai nou in domeniul acesta :tuktuk:
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Control Module Part Number: 1C0 907 379 M
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0019458
Work Shop Code: WSC 01266 785 00200
VCID: 346D6D74542070E
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
multumesc anticipat !
dupa ce o stergi, reapare ?
1 Fault Found:
Acolo spune sa verifici erorile de pe motor. pe motor ce erori ai ?
Cine poate sa isi dea cu o parere despre eroarea aceasta?
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 30650E19A338729
1 Fault Found:
00573 - Steering Torque Sensor (G269)
Multa lume a spus ca trebuie sa schimb caseta de directie. Tin sa mentionez ca imi apare volanul galben in bord, caseta nu bate, nu are absolut nici o problema. Am incercat sa-i fac adaptare din nou, se stinge iar la prima curba imi apare din nou. Eu vreau sa o reconditionez. O parere? Va multumesc
va o verificare dupa cum spune mai jos :
Checking Steering Torque Sensor (G269)
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
[select]
[44 - Steering Assist]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
[Close Controller, Go Back - 06]
Replacement
After Replacing this Control Module several Steps have to be performed in the following Order:
Check/Update Steering Aid Adaptation Channels 002-009
Perform Basic Setting for Steering Angle Sensor (G85)
Perform Steering Limit Stop Adaptation
Upload/Install a proper Characteristic Curve
Characteristic Curves need to be uploaded with the Factory Tool which has the latest Brand Version installed as well as access to the latest Flash Updates. Unless you have a Factory Tool which meets these Requirements the only Solution to accomplish this Step is to take the Car to the Dealer and have them perform this.
In case you are having trouble with procedure please contact us directly and we will assist you with the Coding Process. Every inquiry on this topic has to include a full Auto-Scan as well as which parts have been replaced and why, also make sure the Auto-Scan includes the complete VIN of the vehicle in question.
Modificat de andrei_221
Deci revin cu rezultatele. Senzorul isi modifica valorile, iar Terminal 15 este On. Sterg eroarea, toate bune si frumoase. Merg cativa km, iar apare. Nu imi pot justifica aceasa eroare daca totul este ok la caseta.
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V20
Coding: 00044
Shop #: WSC 13765
VCID: 418334A04B92D56
1 Fault Found:
00526 - Brake Light Switch-F
36-00 - Open Circuit
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
VCID: F2E12B6CBEB4BEE
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 01034
Shop #: WSC 13765
VCID: 3B7F4648297EBF6
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0006
Coding: 12593
Shop #: WSC 13765
VCID: 1E39AFDC9AACCAE
1 Fault Found:
00532 - Supply Voltage B+
cum pot sa le rezolv?
Am gasit toate erorile stiu de unde provin dar una singura nu am gasit-o pe situl ross-tech este vorba de :
3 Faults Found:
As vrea sa ma ajutati si pe mine cu cateva info despre acest cod.
Multumesc anticipat!
Schimba motorasul de recirculare.
Daca este doar motorasul de recirculare este bine. Ma bucur ca nu am o problema mai grava.
O alta curiozitate:
La ce se foloseste MAF-ul? Ce face el fizic? Cum il pot verifica cu vcds-ul? Care sunt parametrii optimi de functionare?
Ma mai intereseaza si la injectoare. Aceleasi intrebari de mai sus.
Va multumesc!
  • Aerofan pinned this topic
    • sorin0235
