zorg
salut!
am scanat masina unui prieten la ceva timp dupa ce a facut distributia (poate e intimplare sau nu) are urmatoarele erori:
la rediness, naspa cu EGR:
Readiness Status: 00000000 00000110 10000000 10000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
la scanarea generala:
4 Faults Found
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
P161A - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 155993 km
Time Indication: 0
Date: 2000.00.00
Time: 10:02:32
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001000
Temperature: 16.2°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 155993 km
Time Indication: 0
Date: 2000.00.00
Time: 10:02:32
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001000
Temperature: 16.2°C
Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 155993 km
Time Indication: 0
Date: 2000.00.00
Time: 10:02:32
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001000
Temperature: 16.2°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
P161D - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 155993 km
Time Indication: 0
Date: 2000.00.00
Time: 10:02:32
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001000
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Shop #: WSC 01324 785 00200
1 Fault Found
01406 - No Flame
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 157104 km
Time Indication: 0
Freeze Frame:
Start
Temperature: 48.0°C
Temperature: 47.0°C
Voltage: 14.02 V
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010691904FA
Coding: 3D3F574807008002
Shop #: WSC 02800 995 88888
1 Fault Found
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 157078 km
Time Indication: 0
Date: 2000.00.00
Time: 13:24:09
pentru ca am facut diagnoza pe inserat, nu am vazut nimic deosebit sub capota asa ca suspectez ca au lasat diverse fire neconectate pe acolo.
Laa reclamatia propritarului ca nu prea trage, am facut o tura cu debitmetrul decuplat; senzatia a fost incerta, dar turbina grohaia mai pronuntat....
Log in mers nu am facut, ca am mai avut impreuna antecedente naspa :D
Partea sensibila e ca voi pleca eu cu ea la drum....si nu vreau surprize
Revin cu rezolvarea problemei,cel putin asa cred,asta seara cand sa plec cu masina am sesizat ca nu-mi merge stopul pe frana,prima verificare am facut-o la switch-ul de la pedala de frana,am miscat putin de el si s-a aprins stopul pe frana moment in care s-a stins si martorul din bord.
salut!
l.........
Sterge erorile si vezi ce mai ramane. Sa verifici sigurantele din compartimentul motor - pentru bujii, respectiv bujiile.
Pentru webasto - vezi daca are suficient combustibil - eroare aia apare cand a vrut sa plece unitatea dar era prea putin combustibil.
Pe motor nu vad nci o eroare - sau nu ai postat grupul respectiv
Nu ai unde sa vezi turatia electromotorului, poate turatia motorului la pornire.
Din ce am citit zice ca ar fi asa ceva, care trebuie sa fie 240, daca e sub e de vina electromotorul si de aceea vroiam asta...dar vad ca nimeni nu sa intalnit cu problema asta ;-)...oricum aia cu turatia motorului la pornire care e?
se vede in campul unde apare turatia motorului. Doar ca la ECU al tau, e posibil sa nu iti afiseze, pana nu porneste.
Salut , cand am cumparat masina am pus testerul si am primit eroare urmatore
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame:
RPM: 903 /min
Torque: 51.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
fiind mai credul ,am inghitit ceea ce sigur pare vrajeala ca si cum a schimbat bujia si a ramas eroarea , care s`a sters apoi. Acum peste 4 luni am pus testerul din nou si primesc pe 4 cilindri acceasi eroare. Masina merge ok , porneste mai greu , dar am si bateria proasta rau(dupa doua luni a inceput sa o ia mai greu la cheie )? Ar trebui sa ma ingrijorez , sa schimb ceva?
erorile cu bujiile sint de pe engine si nu erau inainte de distributie (apar in continuare, ca de vreo 2 3 ori am intrat pe engine)
Modificat de DragosR
La scanarea unui Golf IV ALH am gasi eroarea asta care tot apare desi o sterg:
17971 - Quantity Adjuster (N146): Lower Limit Reached
P1563 - 35-10 - - - Intermittent
Pompa de injectie a fost schimbata,masina merge bine dar uneori la relanti mai tremura putin,rar.Am mai gasit eroarea pe forum la pag 80 parca dar nu e nicio explicatie sau rezolvare.De unde sa incep verificarile?
O alta problema descoperita e ca pe Engine-01 temperatura lichiduui de racire e la 11 grade iar in Instruments e la 90 si acul in bord e tot la 90,indica bine.Trebuie inlocuit senzorul G62 sau verificat cablaju mai intai,nuh?
Poate cineva sa-mi interpreteze si mie logo facut, si sa-mi dea un sfat (VW Bora 2002)-EroareCharge Pressure Control Pozitive Deviation
Sunday,21,October,2012,19:35:28 038 906 019 FF,,1.9l R4 EDC G000AG 1449, ,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011 ,,Engine speed,MAF (specified),MAF (actual),EGR duty cycle,,MAF,Atmos. pressure,Intake air press.,Throttle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP ,TIME,790-870,230-310,210-350,50-70%,TIME,800-1100,sensor -f96-,1900-2150,100%,TIME,2850-3150,1900-2150,1900-2150,55-75% Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mbar, mbar,%,STAMP, /min, mbar, mbar, % ,0.01,1092,230.0,494.9,84.5,0.36,485.1,1009.8,1142.4,0.0,0.76,1050,1030.2,1142.4,24.7 ,1.16,1113,355.0,504.7,84.5,1.56,514.5,1009.8,1173.0,7.5,1.96,1113,1050.6,1193.4,24.7 ,2.34,1365,800.0,519.4,4.8,2.74,558.6,1009.8,1295.4,72.9,3.12,1848,2152.2,1479.0,21.1 ,3.52,2079,735.0,617.4,4.8,3.92,705.6,1009.8,1744.2,45.5,4.32,2226,2254.2,1846.2,43.8 ,4.74,2352,830.0,617.4,4.8,5.14,646.8,1009.8,2050.2,50.6,5.55,2373,1295.4,2029.8,88.1 ,5.97,2352,440.0,847.7,84.5,6.37,793.8,1009.8,1897.2,25.9,6.78,1596,1091.4,1530.0,69.7 ,7.16,1575,230.0,490.0,84.5,7.58,485.1,1009.8,1122.0,0.0,7.98,1512,999.6,1081.2,73.3 ,8.38,1470,230.0,465.5,84.5,8.78,475.3,1009.8,1050.6,0.0,9.16,1386,999.6,1071.0,51.0 ,9.56,1344,230.0,490.0,84.5,9.96,514.5,1009.8,1122.0,0.0,10.36,882,999.6,1122.0,24.7 ,10.76,861,250.0,475.3,84.5,11.14,475.3,1009.8,1111.8,0.0,11.54,903,1071.0,1101.6,24.7 ,11.94,1323,610.0,480.2,37.9,12.34,568.4,1009.8,1193.4,23.1,12.74,1239,1142.4,1295.4,43.4 ,13.12,1260,355.0,558.6,59.8,13.52,543.9,1009.8,1295.4,7.1,13.92,1260,1009.8,1264.8,59.0 ,14.32,1239,245.0,524.3,84.5,14.72,514.5,1009.8,1234.2,2.0,15.10,1197,999.6,1213.8,37.1 ,15.50,1155,230.0,509.6,84.5,15.90,499.8,1009.8,1183.2,2.0,16.30,1092,999.6,1173.0,24.7 ,16.70,1071,280.0,504.7,84.5,17.10,499.8,1009.8,1162.8,10.2,17.50,1260,1101.6,1183.2,24.7 ,17.88,1260,470.0,543.9,84.5,18.28,543.9,1009.8,1254.6,0.0,18.68,840,999.6,1203.6,35.9 ,19.08,819,265.0,485.1,84.5,19.48,485.1,1009.8,1142.4,0.0,19.88,819,999.6,1122.0,33.1 ,20.27,819,265.0,465.5,84.5,20.66,470.4,1009.8,1101.6,0.0,21.06,819,999.6,1101.6,24.7 ,21.46,819,280.0,480.2,84.5,21.84,480.2,1009.8,1101.6,0.0,22.24,819,999.6,1101.6,24.7 ,22.64,819,280.0,460.6,84.5,23.04,485.1,1009.8,1101.6,16.1,23.44,1029,999.6,1142.4,24.7 ,23.84,903,745.0,455.7,29.9,24.23,509.6,1009.8,1152.6,69.8,24.62,1512,1734.0,1254.6,28.7 ,25.02,1722,835.0,597.8,4.8,25.42,617.4,1009.8,1540.2,82.4,25.82,1911,2233.8,1672.8,22.3 ,26.21,1995,850.0,578.2,4.8,26.63,578.2,1009.8,1754.4,81.2,27.05,2163,2080.8,1785.0,29.9 ,27.46,2247,855.0,548.8,4.8,27.86,558.6,1009.8,1805.4,67.8,28.27,1743,2019.6,1785.0,19.9 ,28.66,1848,850.0,627.2,4.8,29.06,735.0,1009.8,1825.8,34.9,29.46,1743,2009.4,1856.4,48.6 ,29.86,1764,850.0,695.8,4.8,30.26,646.8,1009.8,2019.6,81.2,30.65,1869,2162.4,2040.0,36.3 ,31.05,1911,850.0,686.0,4.8,31.44,700.7,1009.8,2060.4,77.3,31.84,2016,2233.8,2080.8,34.7 ,32.24,2037,625.0,602.7,33.1,32.63,627.2,1009.8,1907.4,28.2,33.03,2058,1468.8,1836.0,54.6 ,33.42,2079,655.0,632.1,68.9,33.82,622.3,1009.8,1907.4,76.9,34.22,2142,2254.2,1999.2,36.3 ,34.61,2184,765.0,617.4,4.8,35.03,617.4,1009.8,2009.4,40.0,35.41,2205,1315.8,1938.0,82.9 ,35.83,2163,370.0,710.5,84.5,36.24,720.3,1009.8,1805.4,18.8,36.66,2142,1142.4,1774.8,89.6 ,37.06,2121,330.0,739.9,84.5,37.46,754.6,1009.8,1744.2,18.4,37.86,2079,1132.2,1744.2,93.6 ,38.26,2058,290.0,749.7,84.5,38.66,641.9,1009.8,1601.4,16.5,39.05,2058,1091.4,1305.6,77.7 ,39.44,2058,290.0,529.2,84.5,39.84,529.2,1009.8,1142.4,28.6,40.24,2079,2254.2,1346.4,27.5 ,40.64,2163,850.0,950.6,4.8,41.03,999.6,1009.8,2407.2,78.8,41.42,2352,1897.2,2529.6,94.4 ,41.82,2352,440.0,931.0,84.5,42.22,774.2,1009.8,1978.8,11.8,42.62,2310,1040.4,1632.0,79.7 ,43.01,2268,245.0,568.4,84.5,43.41,543.9,1009.8,1234.2,11.8,43.81,2205,1040.4,1183.2,65.3 ,44.20,2184,235.0,529.2,84.5,44.60,553.7,1009.8,1234.2,11.8,45.00,2100,1030.2,1264.8,54.6 ,45.39,2079,235.0,588.0,84.5,45.79,583.1,1009.8,1295.4,11.8,46.18,1995,1030.2,1305.6,54.6 ,46.59,1953,235.0,583.1,84.5,46.99,578.2,1009.8,1295.4,11.8,47.39,1911,1030.2,1295.4,54.6 ,47.79,1869,265.0,573.3,84.5,48.17,602.7,1009.8,1305.6,21.2,48.57,1869,1234.2,1407.6,57.0 ,48.96,1869,295.0,666.4,84.5,49.35,617.4,1009.8,1417.8,14.1,49.75,1848,1060.8,1366.8,67.7 ,50.15,1827,270.0,588.0,84.5,50.55,583.1,1009.8,1315.8,25.9,50.94,1848,2152.2,1417.8,20.3 ,51.33,1932,795.0,862.4,4.8,51.73,872.2,1009.8,1938.0,47.1,52.13,2016,1244.4,1927.8,87.3 ,52.53,1995,270.0,632.1,84.5,52.93,543.9,1009.8,1275.0,13.3,53.33,1974,1040.4,1173.0,70.1 ,53.73,1953,240.0,509.6,84.5,54.15,509.6,1009.8,1111.8,12.9,54.56,1911,1040.4,1132.2,54.2 ,54.96,1869,245.0,548.8,84.5,55.37,558.6,1009.8,1234.2,12.9,55.77,1806,1040.4,1254.6,53.4 ,56.17,1785,245.0,558.6,84.5,56.57,553.7,1009.8,1264.8,12.9,56.97,1743,1040.4,1264.8,52.2 ,57.37,1722,250.0,548.8,84.5,57.77,548.8,1009.8,1264.8,12.9,58.17,1701,1122.0,1275.0,54.6 ,58.57,1722,535.0,607.6,4.8,58.95,666.4,1009.8,1468.8,25.5,59.35,1764,1285.2,1560.6,57.4 ,59.73,1764,415.0,690.9,84.5,60.15,676.2,1009.8,1581.0,20.8,60.55,1827,2091.0,1611.6,19.9 ,60.93,1890,790.0,862.4,4.8,61.33,940.8,1009.8,2040.0,66.7,61.73,2058,2223.6,2172.6,58.6 ,62.13,2121,765.0,940.8,4.8,62.53,945.7,1009.8,2274.6,50.2,62.94,2205,1377.0,2162.4,90.0 ,63.36,2289,850.0,999.6,4.8,63.76,1171.1,1009.8,2509.2,83.9,64.17,2499,2223.6,2580.6,89.3 ,64.59,2541,400.0,911.4,84.5,64.99,710.5,1009.8,1825.8,11.4,65.40,2499,1040.4,1417.8,84.9 ,65.80,2457,295.0,499.8,84.5,66.22,485.1,1009.8,1132.2,13.3,66.63,2394,1071.0,1122.0,72.1 ,67.03,2373,290.0,558.6,84.5,67.43,607.6,1009.8,1315.8,15.7,67.83,2352,1071.0,1407.6,55.8 ,68.23,2331,275.0,651.7,84.5,68.63,656.6,1009.8,1479.0,16.5,69.01,2310,1132.2,1499.4,56.6 ,69.41,2331,430.0,695.8,58.6,69.81,715.4,1009.8,1581.0,30.6,70.21,2352,1448.4,1632.0,71.3 ,70.61,2352,470.0,749.7,84.5,71.01,710.5,1009.8,1632.0,27.1,71.41,2394,1264.8,1530.0,82.1 ,71.79,2394,395.0,617.4,84.5,72.19,588.0,1009.8,1346.4,19.6,72.59,2394,1101.6,1275.0,84.1 ,72.99,2394,305.0,534.1,84.5,73.39,529.2,1009.8,1183.2,16.5,73.77,2373,1091.4,1162.8,79.7 ,74.17,2373,305.0,519.4,84.5,74.57,529.2,1009.8,1162.8,16.5,74.97,2352,1091.4,1295.4,56.2 ,75.37,2352,285.0,641.9,84.5,75.75,641.9,1009.8,1438.2,14.9,76.15,2331,1071.0,1448.4,55.8 ,76.55,2310,265.0,651.7,84.5,76.95,661.5,1009.8,1468.8,14.9,77.35,2289,1071.0,1468.8,55.4 ,77.75,2268,260.0,651.7,84.5,78.15,656.6,1009.8,1479.0,14.9,78.53,2247,1071.0,1468.8,55.4 ,78.93,2226,255.0,656.6,84.5,79.33,661.5,1009.8,1468.8,15.3,79.73,2247,1111.8,1468.8,56.6 ,80.13,2205,320.0,686.0,84.5,80.51,690.9,1009.8,1530.0,18.4,80.91,2205,1224.0,1540.2,70.1 ,81.31,2226,435.0,700.7,84.5,81.71,705.6,1009.8,1560.6,18.8,82.11,2226,1142.4,1489.2,74.5 ,82.51,2226,325.0,637.0,84.5,82.91,627.2,1009.8,1397.4,18.8,83.29,2226,1142.4,1377.0,73.3 ,83.69,2226,325.0,627.2,84.5,84.09,622.3,1009.8,1366.8,21.6,84.49,2247,1264.8,1407.6,70.1 ,84.89,2268,425.0,671.3,84.5,85.27,622.3,1009.8,1417.8,18.8,85.67,2268,1101.6,1315.8,78.5 ,86.07,2268,295.0,573.3,84.5,86.47,568.4,1009.8,1244.4,17.6,86.87,2268,1101.6,1244.4,76.5 ,87.25,2268,295.0,563.5,84.5,87.65,583.1,1009.8,1244.4,17.6,88.05,2247,1101.6,1346.4,56.6 ,88.45,2247,295.0,651.7,84.5,88.85,666.4,1009.8,1448.4,17.6,89.25,2226,1101.6,1468.8,56.6 ,89.65,2226,300.0,676.2,84.5,90.03,681.1,1009.8,1489.2,19.2,90.43,2226,1244.4,1489.2,66.1 ,90.83,2247,430.0,690.9,84.5,91.23,676.2,1009.8,1499.4,19.6,91.63,2247,1111.8,1448.4,76.5 ,92.01,2247,305.0,632.1,84.5,92.41,627.2,1009.8,1366.8,22.7,92.81,2268,1264.8,1397.4,69.3 ,93.21,2268,415.0,666.4,84.5,93.61,646.8,1009.8,1448.4,18.4,93.99,2268,1111.8,1387.2,78.5 ,94.39,2268,265.0,592.9,84.5,94.79,568.4,1009.8,1275.0,15.7,95.19,2268,1081.2,1244.4,74.9 ,95.59,2268,275.0,553.7,84.5,95.98,597.8,1009.8,1275.0,17.6,96.38,2247,1213.8,1387.2,62.2 ,96.77,2247,525.0,695.8,84.5,97.17,862.4,1009.8,1693.2,85.9,97.57,2436,2254.2,2325.6,71.7 ,97.97,2520,790.0,1122.1,4.8,98.36,1029.0,1009.8,2529.6,40.4,98.76,2604,1336.2,2131.8,84.1 ,99.16,2667,835.0,788.9,4.8,99.56,1107.4,1009.8,2305.2,78.0,99.96,2835,2223.6,2580.6,86.5 ,100.36,2877,540.0,945.7,76.1,100.74,784.0,1009.8,1958.4,41.6,101.14,2961,1601.4,1734.0,68.5 ,101.53,2982,490.0,681.1,59.4,101.94,612.5,1009.8,1489.2,37.3,102.34,3024,1315.8,1407.6,85.3 ,102.76,3066,515.0,578.2,84.5,103.17,558.6,1009.8,1336.2,29.0,103.57,3108,2080.8,1336.2,19.9 ,103.99,3150,725.0,882.0,4.8,104.38,739.9,1009.8,1948.2,28.6,104.78,3213,1203.6,1601.4,87.7 ,105.18,3213,625.0,578.2,4.8,105.58,539.0,1009.8,1346.4,24.7,105.98,3234,1173.0,1285.2,87.7 ,106.38,3234,635.0,519.4,4.8,106.78,519.4,1009.8,1244.4,22.0,107.20,3255,1152.6,1234.2,87.3 ,107.59,3255,635.0,499.8,4.8,108.01,504.7,1009.8,1213.8,21.6,108.43,3255,1152.6,1213.8,87.3 ,108.82,3255,645.0,504.7,4.8,109.22,499.8,1009.8,1203.6,21.6,109.62,3255,1152.6,1203.6,87.7 ,110.02,3255,635.0,490.0,4.8,110.42,470.4,1009.8,1162.8,16.5,110.82,3234,1101.6,1142.4,87.7 ,111.22,3234,605.0,460.6,4.8,111.60,465.5,1009.8,1132.2,16.5,112.00,3171,1101.6,1183.2,59.8 ,112.40,3150,550.0,568.4,4.8,112.80,597.8,1009.8,1468.8,16.5,113.20,3129,1101.6,1519.8,59.8 ,113.60,3108,505.0,612.5,4.8,114.00,583.1,1009.8,1530.0,0.0,114.40,3024,1040.4,1428.0,59.8 ,114.80,2961,375.0,539.0,4.8,115.21,539.0,1009.8,1366.8,0.0,115.61,2877,1040.4,1356.6,58.6 ,116.03,2835,345.0,539.0,4.8,116.44,548.8,1009.8,1346.4,11.0,116.84,2751,1071.0,1366.8,58.2 ,117.24,2730,400.0,602.7,83.7,117.62,695.8,1009.8,1550.4,21.2,118.04,2730,1193.4,1611.6,78.1 ,118.44,2751,455.0,646.8,84.5,118.84,671.3,1009.8,1519.8,33.7,119.24,2772,1213.8,1530.0,80.9 ,119.62,2793,425.0,627.2,84.5,120.02,607.6,1009.8,1407.6,20.0,120.40,2793,1132.2,1356.6,78.9
,120.80,2814,460.0,578.2,83.7,121.20,637.0,1009.8,1397.4,39.6,121.60,2856,1346.4,1489.2,82.5
Buna,
dupa ce am pus masina pe tester mi-a aparut cateva erori. Ma poate ajuta si pe mine cineva? Ce inseamna? Cum as putea corecta?
error.txt
17971/P1563/005475 - Quantity Adjuster (N146): Lower Limit Reached
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Reduced Power
  • Engine jerking
Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Quantity Adjuster (N146) faulty
  • Quantity Adjuster (N146) not adjusted
  • Quantity Adjuster (N146) blocked/faulty
Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Quantity Adjuster (N146)
  • Check/Adjust Quantity Adjuster (N146)
  • Check/Replace Injection Pump
Notes
  • On the 1.9L ALH TDI engine:
    • The Quantity Adjuster (N146) should ohm test between 0.5 and 2.5 Ω.
    • With the coolant above 85° C, MVB 001, Field 3 should read between 1.45 to 2.0 Volts.
Buna,
Incearca un basic settings la motorasele de la clima. Boxele de pe spate iti merg? Ai umblat recent pe acolo? Vad ca toate eorile sunt la aceasi ora.
Boxele din spate merg, mai de mult (acum un an aprox) am avut amplificator (asa am cumparat masina) si am fost la un electrician, cine a legat inapot boxele fara amplificator. Deci am scos amplificatorul afara. Oare nu a legat ceva bine la loc?
Poti sa ma ajuti cum pot face basic settings la motoras? Sunt inca incepator... Trebuie sa mearga motorul masinii si AC in timp ce se testeaza masina si se face basic settings sau e suficient sa fie in contact? Merci
Modificat de Ambrus Zsolt
Salut,astazi,fiind in mers mi s-a aprins martorul de la bujiile incandescente si licare continuu,am facut o scanare cu vag-com-ul si imi
apare urmatoarea eroare:
-00742 - Drive Battery Ventilation System
27-00 -- Implausible Signal
Ma poate ajuta cineva cu o explicatie,eventual ce sa verific,masina este o Skoda Octavia 1.9tdi,AHF din 2000.
FA o diagnoza cu o ionterfata VCDS originala, eroarea scrisa de tine nu are cum sa fie pe o Octavia 1.
@Pronet....asta am citit si eu,,,,,,ms oricum ,,,,ma gandeam la ceva mai concret,,,,,care ar fi piesa in discutie..am vazut ceva poze pe google cu ea dar nu stiu unde se afla sau daca se poate repara sau inlocui,daca e in pompa cum banuiesc eu.Alte pareri pt postul #4656?
curata mufa de pe pompa(daca nu ma insel e cu 10 pini).Probabil contacte proaste,oxidate.Pompa e piesa din care ies conductele metalice si pleaca la injectoare.
Revin cu problema mea, cu pornirea grea la cald la un T5 TDI PD, am mai citit si cineva a spus ca se rezolva din soft, am fost la cineva sa o faca din soft si face aceeasi treaba. Sa fie pompele duse sau ce sa ii mai fac, ca sincer nu mai stiu, si pe diagnoza nu da nici o eroare.....are si cate o mica intrerupere la relanti. Multumesc anticipat.
Salut, in urma diagnozei am urmatoarele erori:
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658070558
Coding: 0013602
Shop #: WSC 00028 028 00001
VCID: 306B14F3D8E3
2 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 241
Mileage: 293912 km
Time Indication: 0
Date: 2012.09.13
Time: 03:42:54
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 241
Mileage: 293912 km
Time Indication: 0
Date: 2012.09.13
Time: 03:42:54
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
VCID: 33611BFF29F5
2 Faults Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 3880 km
Temperature: 11.0°C
Voltage: 12.00 V
Voltage: 11.90 V
000 - -
Freeze Frame:
Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Shop #: WSC 131071 1023 2097151
VCID: 214DE1B78309
2 Faults Found:
02443 - Control Head
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 25
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 40
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 131
Reset counter: 242
Mileage: 293912 km
Time Indication: 0
Date: 2012.09.13
Time: 03:45:05
Freeze Frame:
Voltage: 12.32 V
Count: 236
In privinta senzorilor g85 si g200 am incercat basic settings, pe aceasta cale ii multumesc lui F l o r i n pentru suport,dar erorile raman in continuare, servodirectia este "tzapana" (sau nu merge). Oare din cauza senzorului ABS de la roata dreapta fata? Eroarea referitoare la acest senzor se poate sterge, nu apare la punerea contactului/pornirea motorului dar la punerea in miscare reapare.
In "Adv. meas. values" se vad toti 4 senzorii ABS; la punerea in miscare in dreptul senzorului cu pricina nu se modifica valoarea (respectiv viteza), ramane 0, la restul senzorilor se vede viteza de rulare. Asta sa insemne oare ca e dus senzorul sau trebuie curatat? Am incercat sa ii desfac surubul de prindere in fuzeta dar asa e de mancat de rugina incat nu am avut sansa nici sa recunosc daca e nevoie de torx sau alta cheie, nu se poate desface.
Imi puteti da ceva sugestii? Erorile au aparut dupa ce am scos planetara din fuzeta, respectiv am montat-o la loc, dar nu m-am atins de senzor sau cablajul acestuia.
Salut. De ceva timp imi tot apare aceasta eroare... (odata la o luna) Imi apare in mers,clipeste arculetul ,opresc masina o repornesc si nu mai apare. Tin sa precizez ca prima data cand a aparut eram pe un drum f prost de tara. Multumesc
Address 01: Engine Labels: 03G-906-018-BMN.clb
Control Module Part Number: 03G 906 018 EM HW: 03G 906 018 EM
Component and/or Version: R4 2.0l PPD1.2 G 0420
Software Coding: 0000072
Work Shop Code: WSC 00028 028 00001
VCID: 74EC6BBA17A00E9
1 Fault Found
012600 - Intake Manifold Runner Control
P3138 - 006 - Regulation Deviation - Intermittent
Freeze Frame
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 151679 km
Time Indication: 0
Date: 2012.10.09
Time: 19:28:04
Freeze Frame
RPM: 1312 /min
Torque: 0.0 Nm
Speed: 31.0 km/h
Mass Air / Rev.: 425.1 mg/str
Lambda: -24.2 %
Text: Kein Messwert verfuegbar
In urma unei scanari, am observat urmatoarele nereguli: MAF-ul actual si EGR-ul, depasesc parametrii. Ma poate lamuri cineva cu aceasta problema. Atasez si o poza pt o mai buna interpretare. Va multumesc
post-37448-0-71716700-1351507018_thumb.p
fa un log in mers, ca sa vedem valorile debitmetrului
Am facut un log la Grupurile 03, 10, 11. Sper sa fi reusit, deoarece este pt prima oara cand fac un log.
post-37448-0-80499600-1351528054_thumb.p
  • Aerofan pinned this topic
    • SelesanD
