zorg
Am scanat astazi o masina Golf 6 si mi-au dat urmatoarele erori si as dori o informatie cu privire la ele, multumesc:
Monday,30,April,2012,13:39:53:26365
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZAP038152
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03C 906 016 HW: 03C 906 016
Component: MED17.5.5 G 5049
Coding: 0000072
Shop #: WSC 00028
2 Faults Found:
008568 - Bank 1; System Too Rich off Idle
P2178 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 15582 km
Time Indication: 0
Date: 2030.14.22
Time: 10:59:18
Freeze Frame:
RPM: 1519 /min
Load: 37.6 %
Speed: 56.0 km/h
Temperature: 90.0°C
Temperature: 39.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
008584 - Bank 1; System too Rich at Idle
P2188 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 15653 km
Time Indication: 0
Date: 2030.14.23
Time: 11:56:03
Freeze Frame:
RPM: 702 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 41.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Eroarea spune ca ai prea multe hidrocarburi in gazele de evacuare la ralanti, posibil clapeta cu probleme sau altceva,.
Ma ajuta si pe mine careva? Am un consum in relanti destul de mare, cred eu. 0.7 fara consumatori, 1.1 cu clima pornita. Motorul e un avf resoftat (tcmturbo) si avansul l-am reglat eu zilele trecute la 0.5-1.1 (oscileaza). De curand am schimbat si g62. Daca fac astazi un log, mi-l interpreteaza si mie cineva? multumesc
Laurentiu Utiu
nu cred ca e mare consumul tau. Si la mine tot 0.7 (cateodata scade la 0.6) e pe BC. Pe VCDS consumul e de 0.6. Avansul nu e prea stralucit dar inca e in parametrii buni. Hai cu logul sa vedem ce e cu el. Succes
Tuesday,01,May,2012,11:54:31:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 EM HW: 03L 907 309
Component and/or Version: R4 2,0L EDC G001SG 6223
Software Coding: 0000172
Work Shop Code: WSC 10101 599 74661
VCID: 74E3D8E36E2B
1 Fault Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 145631 km
Time Indication: 0
Date: 2012.04.30
Time: 14:05:31
Freeze Frame:
RPM: 2691 /min
Speed: 87.0 km/h
Load: 57.6 %
Absolute Pres.: 2162.4 mbar
Absolute Pres.: 1632.0 mbar
Lambda: 92.3 %
Lambda: 22.1 %
Readiness: 0 0 0 0 0
Wednesday,02,May,2012,17:18:03:10074
VCID: 74E3D8E36E2B
1 Fault Found:
P0299 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 145738 km
Time Indication: 0
Date: 2012.05.02
Time: 15:59:43
Freeze Frame:
RPM: 2668 /min
Speed: 87.0 km/h
Load: 57.6 %
Absolute Pres.: 1662.6 mbar
Lambda: 92.3 %
Lambda: 22.1 %
Address 01: DTCs cleared
Ma ingrijoreaza fault priority-ul :-s Am mai citit informatii si am inteles ca trebuie verificate cablurile,curatat turbina,EGR.Ceva sfaturi inainte sa imi fac maine programarea ?
Am raspuns deja aici:
Turbina, probabil membrana actuatorului nu tine presiunea. Du-te la orice service sa-ti verifice actuatorul cu un manometru, probabil o sa scape presiunea. Daca este asa te costa in jur de 500-700 ron altul nou. Poate fi si de la tubulatura catre acesta, dar mai putin probabil.
Nu-l schimba decat la reprezentanta sau la un service care stie cum sa regleze actuatorul, ca este mai dificil decat la pd-uri
Mi-am facut programare marti la un service unde cunosc personalul,cativa imi sunt amici buni ,ca erau ocupati azi si maine iar luni sunt eu plecat.O sa vad marti,dupa ce dau jos turbina ce are (in prealabil verificat furtune si ce mai trebuie) ,luandu-le prin excludere de la cel mai putin grav in sus.Sper sa scap doar cu o curatare a turbinei si totul sa fie ok !
Incepe cu actuatorul, lasa turbina in pace. Cu un banal manometru si un furtun te dumiresti imediat daca e nevoie de demontat turbina sau nu. Inca o data, atentie la turbina daca o demonteaza, sa stie aia s-o regleze la loc. Putini sunt cei care sunt in stare sa recunoasca atunci cand nu stiu.
Valentin,spune-mi te rop pe privat sau aici un pic cum decurge operatiunea.L-am sunat pe asta de la service si habar nu are ce se face cu manometrul sau cum sa masoare presiunea de la actuator.Explica-mi putin ca sa notez pe o foaie si sa le spun.Merci anticipat !
Laurentiu Utiu
e clar. Schimba mecanicul. Daca nici macar asta nu stie.....
liviuplaton
Ai nevoie de un manometru pt vacum, il cuplezi la furtun si vezi ce indica, daca tin bine mine am vazut undeva scris 0,8 nu is singur, sincer schimba servisul, bafta.
cum a dat caldura, clima de la masina unui amic a mers putin si a cedat; intilnit, facut diagnoza si ca eroare pe clima a venit doar asta:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
revenind ulterior cu intermitent
m-am plimbat si printre Measuring Blocks si ce mi s-a parut aiurea e aici:
post-1792-0-39272600-1336157609_thumb.pn
ventilatoarele functioneaza, dar nu se aude nimic deosebit atunci cind se porneste clima.
ceva pareri???
In principal cea de airbag ma intereseaza, am sters eroare dar tot apare. pur si simplu a aparut pe la 115000 km, nu a fost lovita, nu s-a umblat la mufe...
16567 - Fuel Temp. Sensor A (G81): Open or Short to Plus
P0183 - 000 - - - Intermittent
Freeze Frame:
RPM: 777 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Temperature: 49.5°C
Temperature: 63.0°C
Temperature: 36.9°C
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Control Module Part Number: 1K0 963 235 E HW: 1K0 963 235 E
Component and/or Version: PTC-Element 0404
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 2D550D87CFD1
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
Address 15: Airbags Labels: 1K0-909-605.lbl
Control Module Part Number: 1K0 909 605 N HW: 1K0 909 605 N
Component and/or Version: 2E AIRBAG VW8 015 2100
Software Coding: 0012869
Work Shop Code: WSC 01373 785 00200
VCID: 37792FEF3D8D
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Modificat de Serban87
Schimba sau verifica firele de la senzorul de temperatura combustibil.
schimba elementul de incalzire auxiliara
elimina mufele de la airbagul din scaunul pasagerului.
Modificat de Al Bundy
terminatoru
La o scanare mi-a aparut asta,am mai avut de a face cu ea:
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 0A AIRBAG VW5 04 0004
Coding: 12353
Shop #: WSC 00028
VCID: 366722EB3A87
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
Se refera la airbag-ul din scaunul soferului sau din volan?Nu mai tin minte exact.Airbag-urile sunt bune nu sunt sarite,din cate imi amintesc eu eroarea se refera la scaun,sau nu?
Eroarea se refera la cel din volan. Poate e problema cu spira. Claxonul functioneaza ?
F l o r i n
Daca claxon-ul functioneaza (si sunt mai mult ca sigur ca da) problema e la conectorii care intra in spira (cei galbeni) sau cel care intra in airbag volan - intarite contactele, stearsa eroarea si se rezolva - problema destul de des intalnita la g4 si Passat b5
terminatoru
Aham,am spus ca am mai avut problema asta si am rezolvat-o tot asa prin intarirea contactelor,am sa desfac capacul la volan si le intaresc din nou si revin cu rezultatul.
terminatoru
La scanarea unui Golf IV ALH mi-a aparut urmatoarea eroare si pe wiki ross tech nu o gasesc,stiti la ce se refera?
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 M
Component: 1,9l R4 EDC G000SG 2813
Coding: 00002
Shop #: WSC 01317
VCID: 1A3FD65BAE5F
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
Readiness: N/A
SA verifici erorile de pe IC.
terminatoru
Deci nu arata alta eroare in afara de cea de mai sus,sa selectez IC si sa intru separat pe el in FAULT CODES ? Toate functioneaza in IC.
terminatoru
M-am uitat in IC la Fault Codes si era o eroare cu senzoru de temperatura la ulei pe care urmeaza sa-l inlocuiasca si revin cu detalii dupa.
salutare , am un volkswagen bora adusa recent din germania 1,6 l, 110cp fsi si avea o problema de cand am luat-o si anume 2 secunde dupa pornire facea ca un motor diesel dar am citit pe alt topic ca ar fi normal de la tachetii hidraulici si cand am pus-o pe tester mi-a aparut eroarea 17415- torque difference cylinder 4 p1007-35-10-limit value exceeded-intermittent Readiness:0000 0000, daca ma poate ajuta cineva cu traducerea multumesc anticipat
Possible Causes
  • Injector(s) leaky/dirty
  • Compression loss
Possible Solutions
  • Check Injector(s)
  • Check Compression
F l o r i n
In teorie poate sa fie un injector murdar sau uzat sau o problema de compresie pe cilindrul respectiv. Schimba injectorul de pe cilindrul cu probleme cu altul de pe masina si vezi daca se muta eroarea. Daca da, e de la injector, daca nu, problema e mecanica.... supape, compresie, etc...
  • Aerofan pinned this topic
    • adrian001
    • danyl
