zorg
masina VW golf 3 1.9tdi an 1994. la relanti si daca incerc sa tin turatia constanta in orice treapta de viteza trepideaza masina. ca si cum ar merge intrerupt. vag-com-ul a dat urmatoarele erori. cineva mia zis ca ii pompa de injectie defecta. niste pareri.
Modificat de Cobra999
am masurat senzoru de turatie si ii in parametrii normali 1200ohmi.
am scos si mufa de la debitmetru de aer si masina merge la fel nu se modifica cu nimica. sa fie stricat debitmetru?
In mod sigur e dus. Incearca cu altul de la alta masina si vezi daca la fel face.
Stiti cumva unde pot face o diagnosticare VAG COM in Brasov?
de ceva vreme pe bord imi apare volanul rosu fara buzz si se intimpla cam odata la 3 saptamini si ori dispare el singur sau il sterg eu cu vag com.Pe vag com am gasit eroarea 00566 - Steering Assistance.De la ce poate fi?
00566 - Steering Assistance Operation
00566 - Steering Assistance Operation: Implausible Signal
Possible Causes
  • Fuse(s) faulty
  • Battery Voltage too Low
  • Pump Unit faulty
Possible Solutions
  • Check Fuse(s)
  • Check Power Supply/Battery
  • Check Pump Unit
    • Use Meas. Blocks
Special Notes
  • For Seat Cordoba/Ibiza (6L), Skoda Fabia (6Y) and VW Polo (9N) see MVB 002.
Modificat de pronet
cine ma poate ajuta la log acesta .prima eroare este bujia incandescenta,dar al 2 nu stiu ce e[turbo ,egr a fost curat
VCDS Version: Release 908.0
Data version: 20090830
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Control Module Part Number: 03G 906 016 EH HW: 028 101 145 0
Component and/or Version: R4 2,0L EDC G000SG 7214
Software Coding: 0000072
Work Shop Code: WSC 00066 001 57865
2 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - - - Intermittent
Freeze Frame:
RPM: 819 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00001100
Temperature: 16.2
Verifica turbina - in special actuatorul si geometria variabila.
16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
Possible Symptoms
  • Boost pressure too high
  • Reduced power output
<a name="Possible_Causes" id="Possible_Causes" style="text-decoration: none; color: rgb(0, 43, 184); background-image: none; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: initial; background-position: initial initial; background-repeat: initial initial; ">
Possible Causes
  • Hoses incorrect connected, disconnected, blocked or leaking
  • Malfunction N75
Possible Solutions
  • Check charge pressure control
  • Check Solenoid Valve for Boost Pressure Control (N75)
Possible Symptoms
Possible Causes
Malfunction N75
Possible Solutions
Verifica valva N75, actuatorul de la turbo si furtunele de vacum,bafta.
Vezi aici
Am inteles pronet si multumesc pentru promptitudine.Deci sa inteleg ca probail e din cauza bateriei care e pe duca sau siguranta care sti cumva unde e situata?
Tind sa cred ca e din cauza bateriei. Pentru siguranta vezi aici sau pentru mai multe despre masina ta aici
Multumesc pronet.Am facut azi un test.Adica eu de cite ori porneam masina adica puneam contactul se aprindeau farurile.Am stins toti consumatori posibili la pornire si nu mai apare volanul rosu.Si asta am facut de mai multe ori.Am sa schimb si bateria sa fiu sigur suta la suta.Multumesc mult oricum
Modificat de flotouran95
Mi-am luat de curand un Golf 4 1.9 TDI 90 cai, motoru ALH.
N-am apucat sa-i fac schimburile de ulei/filtre/distributie.
Am facut 200 km cu ea, dupa care mi-a aparut martorul de motorina pe bord, am mai mers 5 km si mi-a murit acolo. Nu mai porneste.
Am observat ca pompa de injectie nu mai trage. Am desfacut filtrul de motorina, nu pare murdar, am desfacut si rezervorul, nu am vazut nici o pompa, doar un senzor de motorina. furtunele sunt curate, pot trage/sufla prin ele.
I-am facut o diagnoza VAG si imi da astea:
Monday,22,November,2010,20:03:46:60804
VCDS Version: Release 10.6.0
Address 01: Engine Labels: 038-906-012-AGR.lbl
Control Module Part Number: 038 906 012 FA
Component and/or Version: 1,9l EDC 0000SG 3349
Software Coding: 00002
Work Shop Code: WSC 01266
Additional Info: WVWZZZ1JZ3W607279 VWZ7Z0C7506233
VCID: 54ACF9A68E93
1 Fault Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-10 - - - Intermittent
Aveti vreo idee de cum pot rezolva asta?
Am mai cautat pe forum si am vzt ca nu e o problema critica, altii au problema asta, dar le merge masina.
Mie nu-mi porneste. Cand dau la automat, motoru se invarte, dar nu trage motorina.
Eroarea prezentata nu are treaba cu pornirea motorului. Ea se refera la clapeta de stop (cutt off valve) - are treaba numai cu oprirea lina a motorului. Tie iti smuceste cand se opreste? Verifica pompa de injectie daca zici ca nu trage motorina. Schimba si filtrul de motorina. Iti ajunge motorina la filtru? Era motorina in el?
19561/P3105/012549 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
Possible Symptoms
  • Engines shakes at shutdown
Possible Causes
  • Wiring Open Circuit or Short to Ground
  • Valve for Intake Manifold Flap (N239) faulty
Possible Solutions
  • Check Wiring for Open Circuit or Short to Ground
  • Check Valve for Intake Manifold Flap (N239) > Output Test
Modificat de pronet
era/e motorina in filtru. trece prin el. daca incerc sa trag, merge.
nu smucea cand opream motorul. cum acum nu mai porneste, nu stiu :-??
Vezi sa nu ai clapeta de shut/off blocata.
S-au mai intalnit asemenea cazuri.
Iar daca nu e blocata - cand da cineva la automat fii cu ochii pe ea sa nu lucreze.
stiu ca daca o apas cu mana se duce inauntru. o sa verific maine ce face cand ii dau la automat.
Ce ar trebui sa faca? si daca e blocata, cum o rezolv?
va salut, subscriu si eu pe aici desi speram sa nu...
am mai scris eu ca am o buba cu trapa.. si de data asta a crapat de tot si odata cu ea si geamurile fata
descriere : - aveam trapa deschisa , eram seara in oras , am vrut sa o inchid si nu a vrut, am incercat si geamurile sa le deschid .. si degeaba. am scos/bagat cheia in contact.. degeaba.. am stat in noaptea aceea (duminica asta) cu trapa semi-deschisa.
tentativa de rezolare: am facut o testare cu VAG-COMul .. si am 2 erori la trapa si 2 la Webasto (l-am folosit la inceputul anului si a fost ok).
erorile:
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortger
Log-B 92 BIF-WAUZZZ8E84A161906-186000km-115575mi.txt
Salut
Poate te ajuta explicatiile...
00532 - Supply Voltage B+: Signal too Low
Possible Causes
* Wiring/Connectors from/to Control Module faulty
* Power Supply (Battery/Generator) faulty
Possible Solutions
* Check/Repair Wiring/Connectors from/to Control Module
* Check Power Supply (Battery/Generator)
Special Notes
* When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
* When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
* Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
* Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
Error Code : 01330
Controller for Comfort System (J393)
Intermittent Additional information on the error codes. Intermittent
The error indicates that he could get no communication with the Central Convenience Module (Module 46). So there is probably nothing wrong,
also because the error as "intermittent" (the error is only occasionally).Keep an eye on the coming week, so read here regularly.
cristi_61 - Intra pe Centrala de confort si verifica in blocuri de masura pe canal 16 sau 26 si zi-mi ce iti apare acolo .
Din ce-mi aduc aminte ai ajuns si la mine cu masina, NU ?
Am masurat tensiunile de alimentare pe modulele din usi si pe cel de confort, tensiunile sunt corecte. Comunicatia pe CAN intre usi si confort e OK. SIngura neconcordanta e ca in blocurile de masura unde vad functionarea butoanelor de pe usa, adica reglaj geamuri si oglinzi , functionarea lor nu e redata in campurile corespunzatoare din blocurile de masura ci in alte campuri, ex: daca oglinzile er fi trebuit sa le vad in blocul 5 camp 2 eu le vad in bloc 6 camp 1, sau ceva de genul asta. Ma gandesc ca modulul de confort e dus pe partea de software. Nu am avut un alt modul de rezerva sa testez. Poate ne intalnim cand e si Turbocip sa luam modulul de pe masina lui sa ne convingem, sau sa facem comparatie intre blocurile de masura de pe cele 2 masini.
da corect, poate o rezolvam cumva.. vine iarna si nu am webasto :frigbaitata:
va multumesc pentru sfaturi si ajutor
  • Aerofan pinned this topic
    • adrian001
    • spido
