zorg
Schimba switchul de frana.
S-a rezolvat: Swithul era intradevar de vina -> dat jos switch, desfacut, curatat contacte, montat la loc, pus la loc - si totul ok acum.
10x :D
Salut, ma poate ajuta si pe mine cineva cu un sfat legat de erorea de mai jos?
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1A Komfortger
@ iulygolf:
00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition
Possible Causes
Terminal 15 OK, but Terminal S not OK
Fuse(s) faulty
Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
Possible Solutions
Check Terminal S
Check Fuse(s)
Check/Repair Wiring/Connector(s) from/to Ignition/Starter Switch (D)
Check/Replace Ignition/Starter Switch (D)
mai fa un log ca acum ai probleme cu turbina... a depasit presiune specificata cu mult..
am facut log;culmea,dupa ce am curatat admisia,egr,furtune vacum schimbate,am inceput sa iau limp;inainte nu sa intamplat :D
1.zip
incearca sa faci un log atunci cand e predispus sa dea limp.... ca im momentul acutual e perfect.
La una intalniri, colegul nostru "animalutz" a avut amabilitatea sa-mi faca o scanare la Sharan, si au rezultat urmatoarele erori:
VAG-COM Version: Release 607.3-UD
Sunday,11,October,2009,12:40:18
Chassis Type: 7M - VW Sharan
Scan: 01 02 03 08 09 15 16 17 18 19 22 25 29 36 37 39 45 46 55 56
76
VIN Number: WVWZZZ7MZ2V033392
Address 01: Engine
Part No: 038 906 019 FC
Component: 1,9l R4 EDC G401AG 1458
Coding: 00001
Shop #: WSC 10115
WVWZZZ7MZ2V033392 VWZ1Z0A1888132
1 Fault Found:
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 02: Auto Trans
Part No: 09B 927 750
Component: AG5 Getriebe 09B 0220
1 Fault Found:
01166 - Engine Torque Signal
16-10 - Signal Outside Specifications - Intermittent
Address 03: ABS Brakes
Part No: 7M3 907 379 B
Component: ESP 20 CAN V005
Coding: 18952
Shop #: WSC 00020
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
Address 08: Auto HVAC
Part No: 7M3 907 040 B
Component: CLIMATRONIC MPV GP 0003
Coding: 00010
Shop #: WSC 00020
No fault code found.
Address 09: Cent. Elect.
Part No: 7M3 962 258 S
Component: Multifunkt.Einh 0001
Coding: 04097
Shop #: WSC 00000
1 Fault Found:
01135 - Interior Monitoring Sensors
Address 15: Airbags
Part No: 1C0 909 605
Component: 0Q AIRBAG VW51 0G 0004
Coding: 12369
Shop #: WSC 00020
Address 16: Steering wheel
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 00000
Address 17: Instruments
Part No: 7M3 920 840 NX
Component: KOMBIINSTRUMENT VDO V59
Coding: 29111
Shop #: WSC 00006
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 78271
Address 25: Immobilizer
Part No: 7M3 953 257
Component: IMMO 0008
Coding: 00003
Shop #: WSC 00000
Address 29: Left Light
Part No: 7M3 907 391
Component: EVG GDL + AutoLWR 0003
Coding: 00005
Shop #: WSC 00020
Address 37: Navigation
Part No: 3B0 919 887 E
Component: Navigation BNO 0304
Coding: 00002
Shop #: WSC 78271
1 Fault Found:
01311 - Information Data Bus
49-00 - No Communications
Address 39: Right Light
Coding: 00005
Shop #: WSC 00020
Address 56: Radio
Part No: 3B0 035 186 D
Component: Radio BNO 0304
Coding: 00400
Shop #: WSC 00000
1 Fault Found:
00853 - Loudspeaker(s); Rear
36-10 - Open Circuit - Intermittent
Address 76: Park Assist
Part No: 7M3 919 283
Component: Parkingsyst. SH RDW D02
Coding: 01117
Shop #: WSC 00000
6 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
37-00 - Faulty
01548 - Sensor for Parking Aid; Rear Right (G206)
31-00 - Open or Short to Ground
01626 - Sensor for Parking-Aid; Front Right (G252)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
01629 - Sensor for Parking-Aid; Front Left (G255)
End ----------------------------------------------------------------------------
Ma poate ajuta cineva cu descifrarea erorilor de pe acest log ?
Problema cea mai importanta e la cutia tiptronic. Are o "smuncitura" la trecerea din viteza 2 in 3.
Din ce sa discutat pana acum AICI cred ca e un solenoid defect...sau mai multe !
E drept ca scanarea a fost facuta pe loc, poate trebuia facuta in mers in asa fel incat sa schimbe cutia toate treptele si poate atunci ar fi inregistrat care electrovalva nu merge bine.
Dar totusi cred ca eroarea ar fi trebuit sa ramana stocata in ECU, insa nu a fost gasita.
Cutia are pe valve body, 9 solenoide (electrovalve) cu coduri si culori diferite ( poza de jos)
Stie cineva cum se poate identificata care anume nu functioneaza corect ?
Modificat de remier
am facut log pana la 170 cu trepta a cincia,mai mult nu am avut unde;nu a vrut sa mai ia limp;pareri va rog
New_Folder.zip
Mie mi-a intrat in limp mode la demaraj in forta cand eram intr-o depasire in panta.
Apoi nu mai vroia sa traga de loc motorul, abia mergeam cu 50 la ora.
Taraindu-ma asa am ajuns in Fagaras la un service si mi-a explicat un ardelean cumsecade ca in astfel de momente de fortare a masinii, calculatorul intra in functiune si trece in limp mode pentru a proteja motorul.
Mi-a spus sa o las 10 minute cu motorul oprit si apoi o sa mearga din nou normal, asa a fost, si de atunci nu am mai patit asa ceva.
Deci analizeaza cand a aparut la tine fenomenul si daca e ceva similar.
Nu cred ca o sa poti sa o bagi voit in limp mode accelerand lin chiar mai sus de 180 / km ora
Modificat de remier
e perfect acum.... posibil sa nu mai ai probleme ceva timp....
Daca a intanlit cineva aceasta eroare la scanarea cu Vag-com-ul, l-as ruga sa ma lamureasca sa pe mine, pentru ca nu am gasit mai nimic care sa ma lamureasca...
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E95A095142 Mileage: 204540km/127095miles
Address 01: Engine Labels: 03G-906-016-BKE.lbl
Part No SW: 03G 906 016 HA HW: 028 101 221 9
Component: R4 1,9L EDC 0000SG 7000
Revision: 12345678 Serial number: AUZ6Z0D0299539
Coding: 0000071
Shop #: WSC 00000 785 00200
1 Fault Found:
17058 - Can't Decode, CODE File Not Loaded!
P0674 - 000 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
RPM: 0 /min
Torque: 44.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000100
Temperature: 13.5
Salut
Posibil sa nu fie inregistrata interfata...
17058/P0674/001652 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
Possible Symptoms
* No Pre-Glow Period
* Poor Cold Starting
Possible Causes
* Glow Plug Wiring faulty
* Glow Plug faulty
Possible Solutions
* Check Glow Plug Wiring
* Check Glow Plug
@ bogdanboob - bujia nr.4
Possible Symptoms
No Pre-Glow Period
Poor Cold Starting
Possible Causes
Glow Plug faulty
Possible Solutions
Check Glow Plug
LE am postat odata cu colegul cuiuda
Modificat de pronet
Multumesc, m-am gandit si eu la bujie incandescenta arsa, dar acum am confirmarea voastra...
Multumesc...
jale mare, allroad-ul nu se ridica deloc, martorul galben aprins in bord pt suspensii...
cam asta imi da pe vcds:
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 67083
8 Faults Found:
00807 - Suspension Strut Valve; Left Rear (N150)
00808 - Suspension Strut Valve; Right Rear (N151)
00805 - Suspension Strut Valve; Left Front (N148)
00806 - Suspension Strut Valve; Right Front (N149)
01397 - Venting Solenoid for Level Control (N111)
01772 - Signal from Level Control Pressure Sensor (G291)
01316 - ABS Control Module
79-00 - Please Check Fault Codes
01773 - Level Control Accumulator Valve (N311)
Cine a mai patit-o poate imi da un indiciu, fac cinste maxima.
foarte ciudat... cauta calculatoru si vezi sa nu fie vreo mufa scoasa :blah_:
Poate sa ma ajute si pe mine cineva cu raspunsuri la log-ul facut in Post #2257 din pag 113 ?
Log ?Care log?Eu nu vad niciunul acolo ...decat niste erori postate de tine .Ai incercat sa le stergi sa vezi daca mai apar ?Unele apar de la mufe scoase in timp ce ai contactul pus,contacte imperfecte ...Mai fa o scanare acum (presupun ca ti-a sters erorile dupa ce a scanat ?!) si vezi ce erori mai apar. :blah_:
;) daca vii maine la intalnire sigur gasesti pe cineva cu un Vag.
Log ?Care log?Eu nu vad niciunul acolo ...decat niste erori postate de tine .Ai incercat sa le stergi sa vezi daca mai apar ?Unele apar de la mufe scoase in timp ce ai contactul pus,contacte imperfecte ...Mai fa o scanare acum (presupun ca ti-a sters erorile dupa ce a scanat ?!) si vezi ce erori mai apar. :icon_thumright:
:offtopic: daca vii maine la intalnire sigur gasesti pe cineva cu un Vag.
erorile sunt cele care au iesit la scanare, le-a sters si au aparut iar >>>
mai vb maine la Polivalenta :icon_thumright:
logvwsharan.txt
Modificat de remier
Pune si logul facut de mine azi ca vreau sa-l studiez si eu si nu-l mai am, ca l-am sters.
Acesta e log-ul facut in mers cu masina.
Abia cand am plecat de la intalnire spre casa a aparut acel soc violent intre viteza 2 si 3, pe care as fi vrut sa-l simti si sa fie inregistrat de VCDS. Poate cu alta ocazie, ieri nu era destul de "incinsa" cutia sa se poata manifesta defectul.
Inca odata multumesc !
LOG_02_004_007_008_2003.xls
ma ajuta si pe mine cineva cu ceea ce indica vagul ca eu nu stiu sa interpretez dar stiu ca nu vrea sa mai porneasca si atunci cind ii dau cheie scoate fum mult alb si in seara asta un amic a venit cu laptopul si asta a rezultat
Salut va scriu si eu pentru ca, cred ca mi-am stricat interfata vag-com 704. A venit acum un prieten si am coborat repede jos si am uitat sa dau disable la wireless. In timp ce era pe auto-scan dupa 1 min. mi-a aparut eroarea ,,this operation requires a licensed interface" sau ceva de genul si s-a oprit. L-am reinstalat dar degebea ... Nu am facut up-date la soft sau ceva ... Se mai poate face ceva ? Si-a copiat oare vreun fisier pe undeva care imi da eroarea asta ? Sa incerc cu un alt laptop sau e gata interfata ?
Modificat de Mad Cow
Address 47: Sound System
Control Module Part Number: 8T0 035 223 T
Component and/or Version: DSP Prem H14 0400
Software Coding: 020101
Work Shop Code: WSC 12336
1 Fault Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 43703 km
Time Indication: 0
Date: 2009.10.29
Time: 19:34:28
Freeze Frame:
Voltage: 11.80 V
Temperature: 44.0
Gaseai raspunsul daca dadeai un search...
Si eu am avut interfata "stearsa", dar am reusit sa o rescriu. Uite un link cu un tutorial si niste fisiere. Urmeaza pasii de acolo. Eu asa am rescris-o.
P.S. Eu nu opresc niciodata WLAN-ul la laptop. Am un vecin care mi-a dat parola si reteaua lui acopera parcarea. Mai caut info/rezolvari pentru erori direct din masina :)
De cateva zile mi se deschide portbagajul singur, din senin.
Address 46: Central Conv.
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 0Z Komfortger
Modificat de AaronNel
  • Aerofan pinned this topic
    • samiii
