Codari VCDS Leon 5F
Clodius
Salut! Am gasit pe un site englezesc codari pt Leon 5F. O parte din astea le-am facut si eu. Mare grija ce activati si cum pt a nu va crea neplaceri
Visual parking aid (daca aveti senzori de parcare acustici spate si vreti sa aveti si vizuali)
  1.  Select STG 10 (parking aid)
  2. Select function 16 - STG access authorization
  3. Enter access code 71679
  4. Function 07 - STG coding
  5. Select Byte 2
  6. Bit 0 - visual display parking sensors - Activate
Rain Closing
1. Select 09 – Cent. Elect.
2. Select 16 – Security Access
3. Enter Unlock Code 31347 - Click DO IT! And yes if it brings up other boxes
4. Select 10 - Adaptation
5. Select from drop down - (14)-Access control 2-Regenschlieben
6. Adjust value to permanent- Click DO IT! And yes if it brings up other boxes
7. Stay on same page and from the drop down select - (26) Access Control 2 Control menu select Rain Close
8. Adjust Value to active - Click DO IT! And yes if it brings up other boxes
MFD Carbon look
1. Select 17 - Instruments
2. Select 10 -Adaptation
3. Select from drop down - Displaydarstellung
4. Set value to Version 2 - Click DO IT! and Yes to the other boxes that pop up
Mirrors fold pressing the lock fob once (not having to hold it);
Select 09
Function 16
Function 10
Select (22) access control mode 2 radio Spiegelanklappung
choose ' by look command via remote control key'
Staging / Needle Sweep
2. Select 07 – Coding
3. Select Long Coding Helper
4. Move to Byte 1
4. Enable Bit 0
Lap Timer
4. Move to Byte 1
5. Enable Bit 3
Air Blower
1. Select 08 – Auto HVAC
4. Move to Byte 11
5. Bit 6 - Enable Blower Status Display in AUTO mode active
Activation of rear lights as DRL’s
3. Input Security Code 31347 Click DO IT! And yes if it brings up other boxes
4. Select 10 – Adapation
5. Choose from drop down – (6)-Tagfahrlicht-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
6. Set Value to Active - Click DO IT! And yes if it brings up other boxes
5. Choose from drop down - (9)-Leuchte23SL HLC10 light function D23
6. Set value to – Tagfahrlicht / DRL’s
7. Click DO IT! And yes to the other boxes that pop up
8. Stay in the same page
9. Choose from drop down – (9)- Leuchte24SL HRA65 light function D24
10. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
11. Stay in the same page
12. Choose from drop down – (9)- Leuchte26NSL LA72-light function D26
13. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
14. Stay in the same page
15. Choose from drop down – (9)- Leuchte27NSL RC6-light function D27
16. Set value to - Tagfahrlicht / DRL’s - Click DO IT! And yes if it brings up other boxes
Activation of the fog lights (NSW) and Cornering
The onboard supply control unit, you have the option of the Seat Leon 5F fog lights (NSW) to activate additional as cornering. With active low beam, the respective front fog lamp is thus driven in accordance with steering angle and thus provides additional illumination when turning.
3. Enter Unlock Code 31347 active - Click DO IT! And yes if it brings up other boxes
4. Select 10 -Adaptations
5. From drop down select - (5) Leuchte12NL LB45-lichtfunktion B 12
6. Set Value to Abbiegelicht links active - Click DO IT! And yes if it brings up other boxes
7. Staying on same page select - (5) Leuchte13NL RB45-lichtfunktion B 13
8. Set Value to Abbiegelicht rechts active - Click DO IT! And yes if it brings up other boxes
MFD Carbon look - este aplicabil numai la MFD-urile color, nu? ?
da, numai la cele color
  On 27.06.2019 at 6:31, b23840 a scris:
Expand
Dar se poate seta background-ul "carbon" si la Media System sau Navigatie.
@Clodius toate astea le-am facut acum aproape 4 ani dar am stat ceva sa le caut. Ai facut bine ca le-ai adunat pe toate aici, multumim! :)
@Rave ai avut probleme cu ledurile spate dupa ce ai activat "Activation of rear lights as DRL’s"?
Nu, nu am avut probleme cu niciuna din aceste adaptari, nici macar cu oglinzile care se pliau la fiecare incuiere. Si, personal, cred ca masina trebuia sa vina din fabrica cu ledurile spate active pe DRL, completeaza foarte bine fata si arata foarte bine. Plus ca fac masina ceva mai vizibila mereu :)
@Rave daca eu doar acum mi-am luat Leon, ce sa fac? ;)
Inca ma gandesc daca sa activez DRL pe spate. Trebuie sa caut, dar parca era si o codare ca atunci cand esti in P (sau in neutru pt cutiile manuale) sa se dezactiveze DRL-ul
Pentru "Activation of rear lights as DRL’s" , mai sus prezentata, sunt 2 variante de codare? Sau este o codare cu 2 pasi?
Daca sunt 2 variante, cum imi pot da seama care se aplica masinii mele?
Multumesc frumos!
  On 27.06.2019 at 18:00, Clodius a scris:
Expand
Merge DRL Off la activare frana de mana.
E fain sa stingi DRL cu frana de mana.
  • 10 months later...
A reușit cineva așa activeze coming home și leaving home pe Leon 2014 fără senzor de lumină?
Am masina din semnatura, un Leon ST cu motorizare 2.0TDI , MY2016 cu ecranul MIB2 mai mare de 6.5 inci la care deja se poate activa Android auto dar pana acum intotdeauna mi s-a spus ca doar reprezentanta o poate face din varii motive, am fost la ei, dar cer 850 lei pe codare, bani pe care nici din principiu nu le voi da niciodata ! As veni cu intrebarea, totusi nu ar fi nimeni care se pricepe la asa ceva, de preferabil in zona Clujului.
Va multumesc anticipat de ajutor!
Salut.Am din fabrica oglinzi electrice se pliaza tinand apasat mai mult si se depliaza la descjiderea din cheie..Am tot cautat codarile de a se deplia doar la punerea contactului..si nu  am gasit(vazusem ceva gen ptr.tiguan insa nu se aplica la seat leon 5f 2014..oglinzile o iau razna adica se deschid si repliaza daca deschid din cheie..dupa care la.punerea contactului se depliaza🙆)Merge cu vcds-ul sau doar rescriere soft. Multumesc
Eu nu am reușit să le fac să se deschidă la punerea contactului, orice codare am încercat au luat-o razna cum ai spus. Daca afli codarea te rog sa mă anunți.
  On 27.09.2022 at 6:06, vaja a scris:
Expand
Pe al meu Leon face-lift la fel aveam, am făcut codarea asta iar acum se depliaza doar când pun contactul.
https://postimg.cc/wtGK65nM
