Webasto Thermo Top V 5Kw
ovizel
Salutare tuturor!
De cateva zile ma confrunt cu o problemă. Instalația din fabrică Webasto a inceput sa dea erori.
Las mai jos un log cu unitatea blocata, cu eroarea pe Maxi-Dot Error: Aux. heater
Log VCDS
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 E
   Component: Standheizer     043 4709
   Revision: 00043000    Serial number: 09021534000000
   Coding: 0021012
   Shop #: WSC 33361 790 00000
   VCID: 3261713DADCAB5B1A9F-8067
5 Faults Found:
01408 - Under-Voltage Shut-Off (fixed Value)
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 7
                    Fault Frequency: 3
                    Reset counter: 179
                    Time Indication: 0
             Freeze Frame:
                        Full Throt
                    Temperature: 47.0°C
                    Temperature: -48.0°C
                    Voltage: 11.20 V
00664 - Fuel gauge
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 7
                    Fault Frequency: 14
                    Reset counter: 194
                    Mileage: 237590 km
                    Time Indication: 0
                    Date: 2018.12.18
                    Time: 15:42:52
01407 - Flame Extinguished
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 191
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 22.0°C
                    Voltage: 11.92 V
01406 - No Flame
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 196
                    Mileage: 240081 km
                    Time Indication: 0
                    Date: 2019.02.21
                    Time: 06:54:49
             Freeze Frame:
                        Start
                    Temperature: 38.0°C
                    Temperature: 36.0°C
                    Voltage: 14.09 V
02251 - Heater Unit Locked
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 240486 km
                    Time Indication: 0
                    Date: 2019.02.24
                    Time: 12:31:09
Apoi, dupa deblocarea unității cu cifra 1, cum s-a mai discutat pe unele secțiuni a forumului, am sters erorile si am pornit Webasto
După o incercare de pornire  de aproximativ 2 minute, la pozitionarea langa masina se aude cum ca ceva vrea sa se aprindă dar parca flacara este inabusita.
Mai jos log-ul cu acest comportament
                Address 18: Aux. Heat       Labels: 1K0-815-007.CLB
Control Module Part Number: 5K0 963 272 E
  Component and/or Version: Standheizer     043 4709
           Software Coding: 0021012
            Work Shop Code: WSC 33361 790 00000
01406 - No Flame
            000 -  -
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 51.0°C
                    Voltage: 11.78 V
Nu am incercat inca sa amorsez pompa de motorina, insa, dupa cum arata logurile, oare care ar putea fi problema?
Mentionez ca totul a inceput cu scoaterea de fum alb si oprirea Webasto. La momentul erorilor, la comutarea manuala de la butonul dedicat, led-ul se aprindea cateva 1 secunda apoi se stingea, pana cand unitatea s-a blocat.
De asemenea, la cat de greu urca temperatura la apa, la acest moment banuiesc ca am termostatul blocat pe deschis.
Astept niste pareri avizate, eventual o recomandare de service sau persoane care se pricep la Webasto, de preferat in Cluj-Napoca
Toate bune tuturor!
Incearca sa schimbi acumulatorul masinii..vad ca e descarcata-11.78v,dar cel mai probabil bujia webasto e defecta..
  • 6 months later...
Buna tuturor! Mi-am cumpărat a doua telecomanda pt webasto, mă poate ajuta cineva cu sincronizarea acesteia? Multumesc.
Aici este aria tehnica. Aria de anunturi si prestari servicii este in alta zona a forumului. Multumesc.
Va salut. Am un superb 2.0 tdi, cfgb, 4x4, 170 cp prevazut cu webasto. Cand am cumparat o anul trecut si am constatat ca are webasto, tot atunci am constatat ca nu functioneaza...?. Am pus vcds si pompa recirculare blocata, plus siguranta de pe baterie arsa. Am schimbat siguranta, sters eroarea, deblocat pompa cu valoarea 1(zic eu deblocat) dar tot nu functiona...se aprinde butonul 2 3 sec si se stinge. Am lasat o asa.... Acum ceva vreme tot vedeam o eroare pe can...modul codat incorect...l am intrebat pe florin si mi a zis sa verific ce module am bifate sau nu. Si...intr adevar modulul 18 aux heat nu era bifat. Dupa acestea am sters si eroarea definitiv si imi apare si in mfd functia aux heating...cu toate functiile...programare, mod, etc. (pana acum nu aparea) Acum cd dau drumul la aer...apas butonul de aux het imi apare pe display si ramane aprins, nu se mai stinge. Vcds nu l am mai pus. Acum, cum pot sa mi dau seama daca functioneaza? Sau functioneaza de vreme ce mi apare pe display activ? Nu l am lasat prea mult sa mearga k ma gandesc ca e si cald acum. Sa mai verific ceva? Multumesc si astept raspunsurile d voastre. Scuze pt povestea prea lunga...?
Dacă la tine dimineata e destul de rece, trebuie sa functioneze
Florin, pai e cam ca la bucuresti si la slobozia ?. Deci sa astept sezonul rece? Altfel, n ar tre sa fie probleme? Multumesc.
Ma ajutati, va rog, cu o parere asupra urmatorului log?
Control Module Part Number: 7N0 963 272 C
  Component and/or Version: Standheizer     044 4840
2 Faults Found:
01410 - Heater Over-Temp
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 250
                    Time Indication: 0
             Freeze Frame:
                        After-Run
                    Temperature: 148.0∞C
                    Temperature: -48.0∞C
                    Voltage: 12.21 V
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 250
                    Time Indication: 0
Multumesc mult.
Am prins afara o temperatura de 3,5 grade. Adevarat, motorul era relativ cald 80-85 grade, cat se racise in urma unei pauze de aproximativ 20 minute la temperatura ambientala specificata. Am incercat pornirea incalzirii din telecomanda, a functionat 2 minute si s-a oprit. Pompele se aud, miros de motorina arsa se simte, fumul specific in schimb nu l-am vazut.
Aveti vreo idee avand in vedere si logul de mai sus?
