Probleme pornire passat bmr
BV20GiG
Salutare colegi ,
De cateva zile nu pot sa pornesc masina . Pun cheia in contact , dar cand apas pe ea doar se aude un clik...Initial am crezut ca e imbilizatorul (pe 21.12 cand am plecat la munca mi s-a aprins cu rosu, dar dupa repornirea masinii nu a mai existat eroarea )
Am facut un test cu vcds 12.12
Gateway Installation List:  3C0 907 530 C
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5D-Operations -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Tuesday,01,January,2019,17:18:23:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3CZ7E240115   License Plate:
Mileage: 217880km-135384mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 5D 62 69
          72 76 77
VIN: WVWZZZ3CZ7E240115   Mileage: 217880km/135384miles
01-Engine -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EM    HW: 03G 906 018 EM
   Component: R4 2.0l PPD1.2 G    4369
   Revision: --H42---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 80093 222 69422
   VCID: 74E73A5B174EF4BE80B-8021
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775331474
   Coding: 0030010
   Shop #: WSC 78417 146 86641
   VCID: DBB5F1E71AD0DBC6211-808E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 BB    HW: 3C0 907 044 BB
   Component: ClimatronicPQ46 112 0606
   Revision: 00112021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 62CB4C03BDBA6A0EE27-8037
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   032 2522
   Revision: 12032000    Serial number: 003B1P7ZGETC
   Coding: 0012354
   Shop #: WSC 05311 000 00000
   VCID: 306FF64BA3D6889E243-8065
   Subsystem 1 - Serial number: 6332MSME19226151
   Subsystem 2 - Serial number: 6342MSME187F4A3F
   Subsystem 3 - Serial number: 6351HTS65JHO8A67
   Subsystem 4 - Serial number: 6361HTS6LNFGERM6
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C9953507AG
   Coding: 0000312
   VCID: 3663C05341B2A6AE7EF-8063
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00000 011 2053004
   VCID: E1C9C30F38BCF1167BD-80B4
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C0742600B2
   Coding: 7DFD9C44E62002
   VCID: 2149030FF83C3116BBD-8074
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 3979CB6F70AC49D693D-806C
   Subsystem 1 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation        Labels: None
   VCID: 55A167DFBCF48DB6975
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000034678411
   Coding: 0000181
   VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
            000 - -
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030E763004941570084F0E707C00
   Subsystem 1 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000155878421
   Coding: 0000180
   VCID: 3C77D27B7F9E7CFE88B-8069
Address 53: Parking Brake        Labels: None
   Part No SW: 3C5 907 801 @    HW: 3F0 907 804 E
   Component: EPB %VC8HC053   016 0003
   Revision:   013 %
   Coding: 0000011
   Shop #: WSC 12881 144 86641
   VCID: 24470A1BE72E243ED0B-8071
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2301953
   VCID: 326BFC43ADDABA8E527-8067
   Subsystem 1 - Part No: 7L6 941 329
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
Address 56: Radio        Labels: None
No Faults Found
Address 5D: Operations        Labels: 3C0-035-151.lbl
   Part No SW: 3C0 035 151 C    HW: 3C0 035 151 C
   Component: J738            011 0018
   Revision: 00011000
   VCID: 183F2EEB2B6670DE4C3-804D
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1119
   Revision: 11006001    Serial number: 00000001635277
   Coding: 0000144
   VCID: 3D71DF7F648475F6BF5-8068
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000126927748
   Coding: 0100000100000000
   VCID: 2F6DF5377EE897663D9-807A
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1119
   Revision: 11006001    Serial number: 00000001650667
   Coding: 0000144
   VCID: 3E73D87369826EEEA6F-806B
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90630711409526
   Coding: 0010024
   VCID: 29591B2F800CF956E3D-807C
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 7L6 035 730     HW: 7L6 035 730
   Component: Telefon             2209
   Revision: 00011000    Serial number: 0000000020445
   Coding: 0020055
   VCID: EBD5A127CA70AB46D11-80BE
1 Fault Found:
00992 - Consumption Cut-Off Active
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 217889 km
                    Time Indication: 0
                    Date: 2018.12.25
                    Time: 00:36:14
End   ---------------------------------------------------------------------
Tuesday,01,January,2019,17:27:26:62939
Ieri am resetat alte 2 erori , care nu mai apar monentan in test
2 Faults Found:
005488 - Engine Start Blocked by Immobilizer
               P1570 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00001000
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 37
                    Mileage: 217864 km
                    Time Indication: 0
                    Date: 2018.12.21
                    Time: 23:33:52
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.64 V
                    Bin. Bits: 00011001
                    Bin. Bits: 00000000
000665 - Boost Pressure Regulation
               P0299 - 006 - Control Range Not Reached - Intermittent
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 14
                    Mileage: 217630 km
                    Time Indication: 0
                    Date: 2018.12.16
                    Time: 15:27:06
             Freeze Frame:
                    RPM: 2592 /min
                    Torque: 240.0 Nm
                    Speed: 139.0 km/h
                        68.25 %
                    Voltage: 14.35 V
                    Pressure: 2066.1 mbar
                    Pressure: 1576.2 mbar
Modificat de BV20GiG
Verifica/inlocuieste acumulatorul si tine usa soferului deschisa cand faci scanarea.
La un service/electrician auto cu tester de acumulatori.Incearca sa iei curent cu cabluri de la alta masina si vezi daca invarte/porneste.Atentie la polaritatea cablurilor!
Am scos bornele , am dat curent de la alta masina , dar tot nu invarte . Dupa multe incercari am reusit sa descarc bateria complet si sa mi se aprinda intermitent toti martorii din bord . Aceleasi erori persista si dupa "n"-scanari si stergeri de erori .
Modificat de Manuel N.
Nu mai folosi quote. Se sanctioneaza. Citeste regulamentul.
Eu nu inteleg nimic.
Ai dar curent direct la bornele tale cu bateria deconectata?
Pune o baterie buna pe masina si vezi daca invarte.
Nu , bateria era cu bornele puse cand am dat curent . Am scos bornele in ideea ca poate se reseteaza ceva . Nu invarte nimic , doar se aprind martorii din bord si se aude un ticait . Nu cred ca problema e de la baterie , iar electromotorul a fost reparat acum 2 luni .
Nu mai folosi quote. Se sanctioneaza. Citeste regulamentul. First/last warning!
Deci electromotorul a fost reparat de mantuiala. Daca ai umblat recent la o piesa si dupa aceea ai probleme cu ea e primul lucru pe care il verifici.
Deci...clar,nu putem repara masina omului pe forum.Invarte..nu invarte...arunca bendix..nu arunca..Cauta pe cineva dispus sa te ajute...care se pricepe..ca-i mai bine.
Problemele pot fi mai multe...acumulator,electromotor,contact,releu,blocator coloana,modul confort..etc.Deci, fara cunostinte minime de electrica...masinuta va prinde primavara in parcare.
Hai La multi Ani!
daca se aude ticait la motor.... inseamna ca problema este la electromotor - verifica cablajul, etc, daca nu, mergi iar cu el la refacut
Am dat azi de electricianul care mi-a reparat electromotorul . Maine dimineata o urc pe platforma si o duc la el .
@BV20GiG ceva rezultate? o problema similara am si eu la un passat b7, cam cu aceleasi coduri de erori (modul CAN si confort, precum si contact inlocuite, dar face la fel: porneste, sta 1 secunda, apoi se opreste)
La tine e altceva...nu e similar.E o problema de imobilizator..fie in ELV fie in partea de confort din Bcm(mai rar) sau chiar o cheie defecta.Ai incercat pornirea cu cealalta cheie?
Bcm la acest model, nu are parte de immo în el.
Da, am schimbat demaror`ul . Acum porneste si sper sa mearga fara evenimente :D
no, bine ca ai rezolvat-o
  • 5 years later...
V as ruga sa mutați postarea daca e greșit, problema e la un passat b6 2.0 D Bmr la pornire mai ales la rece scoate 2 3 secunde un zgomot ca si cum ai strecura ceva..oare ce poste fi?
