Probleme A1
cogdao
  • 3 years later...
Salutare
In urma cu ceva timp am achizitionat un Audi A1 1.4 tfsi an 2011 122 cp s-tronic . Masina a avut o avarie la roata stanga. Eroarea care imi apare ii asa:
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            012 - Electrical Fault in Circuit
Am schimbat senzorul , ca orice om, si surpriza eroare tot apare.
Tin sa precizez ca am eroare la ABS si in modulul Auto Trans :
006279 - Wheel-Speed Signal from
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 58
                    Reset counter: 10
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.04
                    Time: 06:19:15
006013 - Dual Clutch
               P177D - 000 - Torque too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 17
                    Reset counter: 10
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.15
                    Time: 15:37:15
Ceva parari?
Senzorul montat,  e ceva ok? Ai pus codul care trebuie? Vad ca ai alta eroare acum vs eroarea initiala
Prima eroare e in modul Abs iar cealalta in modulul Auto Trans. Senzorul e nou luat dupa seria de sasiu.
Mentionez ca nu am miscat masina din loc, doar am montat , sters erorile si am reverificat.
Postez toate erorile :
                Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP82.clb
Control Module Part Number: 6R0 907 379 BB    HW: 6R0 907 379 AH
  Component and/or Version: ESP8.2i front H07 0001
           Software Coding: 310448E9417600B68C2D12E982D800510D00
            Work Shop Code: WSC 00046 000 00000
                      VCID: 7F0A9BD3EAEEDBC624-802A
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 0
                    Fault Frequency: 64
                    Reset counter: 244
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.04
                    Time: 06:19:14
             Freeze Frame:
                    Hex Value: 0x0440
                    Hex Value: 0x8000
                    Hex Value: 0x36B1
                    Hex Value: 0x06A0
                    Hex Value: 0x3671
                    Hex Value: 0x867B
                    Hex Value: 0x70F9
Saturday,26,February,2022,16:16:42:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
                Address 02: Auto Trans       Labels: 0AM-927-769.clb
Control Module Part Number: 0AM 300 050 N    HW: 0AM 927 769 D
  Component and/or Version: GSG DSG AG7     411 9030
           Software Coding: 0000020
            Work Shop Code: WSC 33870 001 1048576
                      VCID: 346084FF5428C89E89-5000
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 58
                    Reset counter: 10
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.04
                    Time: 06:19:15
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 17
                    Reset counter: 10
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.15
                    Time: 15:37:15
Daca ai tot eroare de circuit electric, verifica intai cablajul intre pompa si senzor
Cum sa il verific?. Pot sa-l masor? Am citit undeva pe forum ca senzorul se poate masura, dar circuitul?
Masori continuitatea circuitului, cu multimetrul. De la pin 1 si pin 2 din senzor, la pinii aferenti din pompa
Am rezolvat eroarea cu ABS-u ( era firul intrerupt intradevar) dar a ramas eroarea pe cutie :
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 17
                    Reset counter: 10
                    Mileage: 177854 km
                    Time Indication: 0
                    Date: 2021.10.15
                    Time: 15:37:15
 In R intra , merge ok , dar in Drive smuceste tare si nu intra in viteza. Dupa imi apare eroarea de mai sus.
O parere?
Necesita schimbate ambreiajele. Cost pentru DQ200, in reprezentanta 5000 lei, service reparatii cutii 3500 aproximativ.
