Reglare ora A6 C5
munuk
Buna ziua! As dori sa aflu cum se regleaza ora si data pentru un A6 C5 Allroad, caruia nu-i merge antena GPS. Va multumesc!
nu merge din butonul de pe ceasurile de bord?
incearca procedura asta gasita pe net :press the CAR button on the console
next press SET UP (also on the console button) - this comes up with a message of no further settings available.
However,in the top RH quarter of the screen, SETTINGS shows. press the appropriate button on the console to select.
This will bring up the following options on the main screen:
Menu language
measurement units
time settings
Select time settings and you should be where you need to be to change either the time, date or the format of either.
