Codari (Tiguan AD1)
bavady
Din ce imi amintesc, cu VCDS a functionat fara nicio problema. OBDeleven nu am folosit.
On 30.08.2023 at 16:38, PavelO a scris:
Salut. M-a mancat ”la portofel” sa imi doresc neaparat sa imi activez aceasta functie, cu OBDeleven. Merg toti pasii pana la Module A5 - Front Sensor Driver Assistance Select Coding, and then select Byte 16, activate Bit 4”. In momentul in care tin apasat pentru activare, cu motorul pornit imi da o eroare cum ca nu poate salva cu motorul pornit. Dupa ce opresc motorul si incerc sa salvez, imi da eroare ”something went wrong, try again later”. Am incercat sa restartez sistemul, restart la telefon, deconectat, reconectat etc samd. Aveti vreo idee despre ce as putea face/ cum as putea rezolva?
2. aveti cumva vreo lista updatata despe codari obdeleven/ ceva interesant si util/ vreun link cu o chestie updatata?
Merci!
Ai introdus si security access code 20103?
Eu nu am incercat (inca) dar in lista de codari salvate vad ca e asa:
1. Control Module 5F
2. Security Access – Access Code 20103
3. Adaptations
4. Car_Functions_List_BAP_Gen2: traffic_sign_recognition_0x21 not activated -> activated
5. Car_Function_Adaptations_Gen2: menu_display_road_sign_identification not activated -> activated
6. Select menu_display_road_sign_identification (OR menu_display_traffic_sign_recognition), set to Enabled
7. Long Coding
8. Byte 24, activate Bit 6
9. Control Module A5
10. Security Access – Access Code 20103
11. Long Coding
12. Byte 16, activate Bit 4
13. Control Module 17
14. Long Coding
15. Byte 5, active bit 2
16. Control Module A5
17. Security Access – Access Code 20103
18. Adaptations
19. Road sign detection fusion mode: Road Sign Fusion -> Road Sign Detection.
20. Press and hold infotainment device power button to reboot the infotainment system.
Unii zic ca la final au dezactivat apoi bit6 de la byte 24.
Uite si un video aici:
https://www.youtube.com/watch?v=RAj_IuqF6Bg&ab_channel=LaymanDIY
REGULAMENTUL INTERZICE CITAREA POSTARII ANTERIOARE !
introdus si cod. aceeasi chestie. aceeasi eroare, ”something went wrong”, doar la acelasi byte 16. restul toate sunt rezolvate/modificate...
Buna ziua
Sunt nou pe acest forum abia învăț să mă comport și aș avea o întrebare pt cunoscători și anume dețin un Tiguan 2017 2.0tdi 190 cp și aș dori să i activez Voice comander cu vcds ul daca știe cineva cum se procedează .
vă mulțumesc.
  • R_a_z_v_a_n changed the title to Voice comander - Tiguan 2017
Salut. Se poate activa VIM cu OBD11 pe un Discover Pro instalat pe Tiguan 2020?
Din ce am înțeles cu VCDS nu se poate.
Mulțumesc.
La feedback pentru cei interesati: merge activat VIM cu OBD11 pe Discover Pro.
Buna ziua,
Am reusit sa activez dupa un an de testari si camere sticate functiile swaps in camerele 2021-2025 2Q0980653 prin inserarea unei chei publice in ele.
Totodata pot crea fisiere dataset custom pentru modificarea timpului de punere maini pe volan, activare lane assist de la 5kmh, activare ALG de la 0kmh si FLA de la 15kmh.
Se pot folosi tutoriarele lui Max, doar ca nu este totul precizat acolo. Mai trebuie pus creierul la munca
Atentie! Aveti grija ca orice greseala in fisiere la scriere va duce la inutilizarea camerei si va trebui sa cumparati alta noua!!!
https://www.drive2.ru/b/696873494415150543/
Nu imi scrieti sa fac publice fisierele.
  • Andrei_72 changed the title to Codari (Tiguan AD1)
  • 7 months later...
Buna. Ce versiune de VCDS este potrivita pentru VW Tiguan Allspace diesel din 2022, va rog?
Cel original functioneaza fara nicio problema, pe masina ta
Scuza-mi ignoranta... la ce te referi cand spui ''cel original'' si unde se poate achizitiona?
Modificat de petervirtual
Depinde ce cauți tu. Vrei vcds original pe care trebuie sa îl conectezi la laptop sau obdeleven pe care îl poți conecta la telefon pentru chestii simple?
Cauta pe google ambele opțiuni (vcds original sau obdeleven).
Poti achizitiona de la @voinea
