AC/Climatronic - probleme
Andrew
O sa-i fac si o scanare... cat despre codare i-am trecut 2 la sfarsit acolo unde scrie "Current coding: 00000000002"
si am mai scris iar la "WorkShop Code (0-99999): am scris 05311. Aici aveam valoarea 00000     la Importer # (0-999): am scris 115.     Equipt # (0-262143): 08193.
Valorile astea le-am trecut dupa un alt Passat CC.
Am gresit ceva de nu merg si celelalte functii? Nu merge funtia AUTO si DUAL, celelalte functii merg.
e buna codarea.
Fa o scanare sa vedem ce erori ai.
Ok, Florin. O sa-i fac scanare si pe urma postez.
Mersi pentru ajutor. :icon_thumleft:  :icon_thumleft:  :icon_thumleft:
Florin, am facut un auto-scan la masina respectiva si am gasit doar eroarile de mai jos:
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5D-Operations -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: -----------    HW: -----------
   Component: Climatronic   1010
   Revision: --------
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW46.rod
   VCID: EFE74D653686AD1
3 Faults Found:
9479443 - Control Circuit for Front Right Seat Heater
          B10A5 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 115250 km
                    Date: 2043.14.30
                    Time: 21:04:34
9479699 - Control Circuit for Front Left Seat Heater
          B10A6 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 102
                    Mileage: 116399 km
                    Date: 2044.14.21
                    Time: 20:38:45
13636352 - Control Module Not Coded
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 65
                    Mileage: 113197 km
                    Date: 2043.14.20
                    Time: 22:29:08
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008863721
   Coding: E3E20F8B00041A0047978F0017000000000BFB4764400165170000000000
   Shop #: WSC 05124 000 00000
   VCID: 336F0115522E491
   Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 210708 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     170908 054  0402
   Coding: 00471277
   Shop #: WSC 05124
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 118321 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.00 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 799 G    HW: 3C0 959 799 G
   Component:    IMMO         070 0383
   Revision: 00070000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: 3D7B272D646A8F1
   Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
01176 - Key
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 1
                    Fault Frequency: 33
                    Reset counter: 198
                    Mileage: 104500 km
                    Time Indication: 0
                    Date: 2101.14.07
                    Time: 17:00:25
ce naiba are?
Pana iti zice Florin, imi dau si eu cu parea.
Nu ai incalzire in scaune, dar este codat climatrronicul cu incalzire in scaune, sau ai butoane de inalzire in scaune pe climatronic, si in scaune fizic lispesc.
Si nu este codat, ai CODING: 0000000000
A zis Florin la un moment dat sa pui 2 in coada.
Eroare cu comunicarea la Senzorul de Lumina/Ploaie.
Probleme cu cheia.
Asta cred ca numai la reprezentata se rezolva.
Daca am gresit cu ceva, sigur ne zice Florin.
Eroarea la senzorul de lumină se poate ignora.
Sent from my S500 using Tapatalk 4 Beta
   Revision: --------
   Coding: 0000000000
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 115250 km
                    Date: 2043.14.30
                    Time: 21:04:34
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 102
                    Mileage: 116399 km
                    Date: 2044.14.21
                    Time: 20:38:45
          U1013 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 65
                    Mileage: 113197 km
                    Date: 2043.14.20
                    Time: 22:29:08
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00471277
   Shop #: WSC 05124
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 118321 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.00 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01176 - Key
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 33
                    Reset counter: 198
                    Mileage: 104500 km
                    Time Indication: 0
                    Date: 2101.14.07
                    Time: 17:00:25
ce naiba are?
banuiesc ca modulul este nou.... luat pe sub mana, cum s-ar spune.... ca vad ca nu este softat...... nu are soft pe el, normal ca nu merge.
daca vrei mi-l poti trimite sa ti-l fac eu.
spor !
humerg, Valentin, Florin: -  va multumesc pentru raspunsuri.
humerg - masina nu are incalzire in scaune, cat despre codare, i-am pus si cifra 2 la sfarsit si am bagat si celelalte coduri (am scris in postul anterior).
Florin - masina nu este a mea, este CC-ul unui var si o sa-i propun sa iti trimita panoul ca sa il codezi.
A tinut mortis sa isi puna panoul asta de clima mai nou si nu ii merg functiile de la AUTO si DUAL.
nu sa il codez.... ci trebuie scris soft-ul.... nu are soft pe el, de asta nu merge.
asa...sa il codezi.
Salut.
Am si eu vesnica problema cu blocarea clapetei de recirculare a aerului.Am fost la PBN la diagnoza  si mi-au spus ca motorasul are o pb electrica si trebuie inlocuit. Din pb celorlalti am dedus ca este V113, insa de la PBN am reusit sa smulg doar codul piesei: 3C1907511H.
Pretul piesei  comunicat este de 390 RON + TVA insa la manopera am ramas si eu  fara aer: aproximativ 2 000 RON!!! Trebuie dat jos bordul, golita instalatia, explicatii stintifice de altfel  etc... Vorba romanului: nu e prost cine cere, e prost cine da! Am plecat cu pb nerezolvata si am inceput sa caut piesa la dezmembrari. Pretul manoperei insa mi se pare o exagerare, ca sa nu spun jaf  pe fata.
Va rog sa ma ajutati cu urmatoarele lamuriri:
- daca scot motorasul si blochez clapeta pe deschis, mai functioneaza aerul? logic ar fi sa functioneze...
- chiar necesita demontarea bordului? din explicatii/poze reiese ca este cel mai accesibil, dai torpedoul jos si il accesezi simplu, n-ar trebui sa ia mai mult de 1h sa zicem;
- imi puteti recomanda un service in Bucuresti serios care stie sa faca operatiunea, care nu e pus pe jefuit romani in zile cu soare?
va multumesc pentru ajutor
Eu am primit o oferta mai ok de la un service tot din grupul vw, mai exact 400 ron motorasul si 600 ron montajul. Iti trimit pm cu service-ul sa nu se considere reclama.
Sent from my GT-I9300 using Tapatalk 4 Beta
am un prieten care nu si-a facut pana acum cont din pacate si ma gandeam sa-l ajut ..pana atunci . are un Passat din 2010 bluemotion si are o problema cu AC ( nu are climatronic ) mi-s spus ca nu baga aer la sofer ( grila stanga langa usa si grila din mijloc - ce-a dinspre sofer) in rest e ok . ce credeti ca poate avea ? pe cele doua grille baga cald .
a umblat la un buton din torpedou .. cel care da drumu la frig in acesta . are vreo importanta ?
Modificat de 1980cristi
Nu are legatura. Cel mai bine sa faca o diagnoza si sa vada exact ce are. Posibil probleme la Motor for Temperature Flap left.
Are siguranta separata pe stanga dreapta?
Nu, nu are siguranta separata.... ci servomotorul de pe partea respectiva, are probleme. Se face un test pe ele, eventual o setare de baza - sa vedem daca isi revine. Daca nu, trebuie inlocuit.
ma poti ajuta ? ai idee cam cat costa un servomotor ? sau macar sa stiu ce sa caut ?
o mica nelamurire la raspunsul tau florin .  daca e blocat sau stricat nu ramane blocat pe rece fiind vara ?nu stiu intreb si eu ...
mai rar sa se blocheze si sa-si revina... de obicei se cam deterioreaza rotitele de plastic din interior. Trebuie o scanare sa fim sigur ca asta este.
ca pret, orientativ - nou OEM - 400-500 lei.
Si cum ne putem vedea ..daca ma poti ajuta
Salut.
Ai rezolvat?
Nu am rezolvat inca pt ca a trebuit sa plec in concediu si nici nu am gasit piesa inca la dezmembrari.
carpeala  a fost simpla, am scos mufa motorasului cind clapa de recirculare era deschisa!
recomand aceasta solutie si celor care sunt in criza de timp.
Nu e mare diferenta fata de cum mergea inainte(parca baga mai mult rece acum) si pb ca o sa-l las asa pina gasesc piesa le dezmembrari la un pret convenabil.
Nu mai am o urgenta acum.
Gasirea unui service rezonabil ramine insa pe lista.
Multumesc de intrebare.
Am rezolvat problema cu incarcare de freon.multumesc lui florin pentru promptitudine!
Va salut
Am urmatoarea problema cu un Passat B6 din 2008 1.9 tdi:Masina a stat parcata 3 ore dupa care la urmatoarea pornire nu a mai mers aerul conditionat- nu mai baga rece absolut deloc, doar aer cu temperatura mediului ambiant.
Am verificat cu vagcom-ul si nu am nici o eroare. Am verificat si parametrii: presiunea freonului o indica undeva intre 8.4-9 bari cu motorul caldut, indiferent daca AC-ul era ON sau OFF. Am verificat si supapele de inalta si joasa si intradevar are freon. Senzorul de temperatura exterioara indica bine.
Comanda pe mufa de la compresor primesc iar pe diagnoza imi indica o tensiune de 0,82A si 1100 rot/min
Am citit topicul dar nu m-am lamurit ce ar putea fii. As vrea sa verific si senzorul G65 (desi nu imi apare nici o eroare pe el) dar nu stiu unde e situat.
Am inteles ca exista o varianta de a cupla compresorul direct doar de test?Am atasat o poza cu codul compresorului
Va multumesc anticipat
post-94571-0-44590700-1374757074_thumb.j
    • livescu
