abs si triunghi galben aprins passat 3bg, an 2001
zorex75
Buna ziua, de curand mi s-a stricat alternatorul si de atunci mi-au aparut in bord cei doi martori , abs si triunghiul galben.Dupa ce am schimbat alternatorul martorii nu au disparut, si in plus cand plec de pe loc se aude un sunet ascutit ca un tiuit intermitent vreo 3-4 ori, iar martorul franei de mana se aprinde si se stinge de cateva ori.Am verificat sigurantele din partea stanga  si sunt ok.M-am uitat  sub volan dar nu stiu care este releul abs-ului, ca sunt mai multe acolo:).
Eroarea e asta::
    01200 - ABS Valves Supply Voltage
    35-00 - -
Mai jos las un log :
Tuesday,19,September,2017,13:41:45:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ2E265332 Mileage: 177180km/110094miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 ER
    Component: 1,9l R4 EDC 0000SG 1466
    Coding: 00005
    Shop #: WSC 05314
    VCID: 6BDFD975199ED11
    WVWZZZ3BZ2E265332 VWZ7Z0A4352625
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 3428
    Coding: 04255
    Shop #: WSC 12345
    VCID: 254BEF4DBFFA271
    35-00 - -
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0004
    Coding: 17000
    Shop #: WSC 05311
    VCID: 2855E679C8E83A9
    2 Faults Found:
    01272 - Positioning Motor for Central Flap (V70)
    37-00 - Faulty
    37-00 - Faulty
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 C
    Component: 08 AIRBAG VW6 04 0004
    Coding: 12344
    Shop #: WSC 05311
    VCID: 377735051556A51
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 807 A
    Component: KOMBI+WEGFAHRSP VDO V06
    Coding: 05125
    Shop #: WSC 00000
    VCID: 2045FE59A0D8C29
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    VCID: F0E54E19B0B8B29
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 10 Komfortgerát HLO 0003
    Coding: 00259
    Shop #: WSC 05311
    VCID: 36693801125C5C9
    Subsystem 1 - Part No: 1C1959801
    Component: 10 Tõrsteuer.FS KLO 0002
    Subsystem 2 - Part No: 1C1959802
    Component: 10 Tõrsteuer.BF KLO 0002
    Subsystem 3 - Part No: 1C0959811
    Component: 10 Tõrsteuer.HL KLO 0002
    Subsystem 4 - Part No: 1C0959812
    Component: 10 Tõrsteuer.HR KLO 0002
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1J0 035 186 E
    Component: Radio BNO 0006
    Coding: 05403
    Shop #: WSC 05311
    VCID: 2757E545C5F6351
    00856 - Radio Antenna
    36-00 - Open Circuit
    End ---------------------------------------------------------------------
Log-WVWZZZ3BZ2E265332-177180km-110094mi.txt
  • C o s m i n a închis acest topic
