Probleme alarma / Inchidere centralizata si nu numai
Andrusa
Salutare! Sper ca nu am gresit deschizand un nou topic, am tot cautat un topic in care sa fie tratate problemele mele dar nu am gasit exact ce cautam.
Atasez un log si rog colegii care au experienta sau stiu cum sa ma ajute... sa o faca.
Masina are alarma de fabrica. Daca apas pe lock... se aude BEEP alarma dar nu incuie portierele dar se aprinde ledul rosu intermitent din portiera sofer. Din interior se pot incuia din switch-ul de pe portiera sofer, la fel si din cheie, fizic din broasca exterioara.
Oricare portiera as deschide-o sau portbagajul... se aprinde in bord martorul ca s-a deschis si se aprinde si lumina in habitaclu.
Nici nu ma avertizeaza ca am uitat luminile aprinse daca scot cheia din contact si deschid portiera sofer, nu scoate acel sunet buzzer-ul.
Daca are cineva o idee... saru'mana !
Saturday,16,April,2016,01:58:04:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3BZ4P099163   License Plate:
Mileage: 234530km-145730mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ4P099163   Mileage: 234530km/145730miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 KD
   Component: 1,9l R4 EDC 0000SG  4897
   Coding: 00003
   Shop #: WSC 00028
   VCID: 63C54907F1A06306E91-4A3A
   WVWZZZ3BZ4P099163     VWZ7Z0C8129121
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      3428
   Coding: 04255
   Shop #: WSC 00028
   VCID: 26431013C212D62ECEF-5072
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 K
   Component: CLIMATRONIC B5GP    0010
   Coding: 17000
   Shop #: WSC 00028
   VCID: 29591B2FD30CF956E3D-5000
2 Faults Found:
            35-10 - - - Intermittent
01336 - Data Bus for Comfort System
            80-00 - Single-Wire Operation
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 C
   Component: 08 AIRBAG VW61 04   0003
   Coding: 12344
   Shop #: WSC 00028
   VCID: 24470A1BB42E243ED0B-5000
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 829 A
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 07115
   Shop #: WSC 00000
4 Faults Found:
            37-10 - Faulty - Intermittent
01330 - Central Control Module for Central Convenience (J393)
00476 - Control Module for Fuel Pump (J538)
            49-00 - No Communications
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0EFB64BB056489EE43-5000
9 Faults Found:
01320 - Control Module for Climatronic (J255)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 6X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1C1959801
   Component: 6X Tőrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 6X Tőrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 6X Tőrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 6X Tőrsteuer.HR KLO 0202
8 Faults Found:
01131 - Control Circuit for Turn Signals
            25-10 - Unknown Switch Condition - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
End   ---------------------------------------------------------------------
Posibil modul confort cu probleme sau lipituri reci pe placa.Trebuie desfacut si verificat.
Ok. Multumesc. O sa desfac si modulul de confort. Sper sa ii dau de capat...
Am verificat modul confort. Arata impecabil. Nu are nici o urma de oxidare pe pinii mufelor sau pe placa. Am verificat si releul de pe acea placa si cupleaza. Din masina pot incuia portierele de pe butonul lock/unlock doors. Dar din cheie incuie doar portiera sofer. De pe telecomanda cupleaza alarma dar nu actioneaza in nici un fel asupra inchiderii centralizate. Se aude goarna si la armare si la dezarmare dar nu actioneaza motorasele de incuiere.
salut,
Am activat optiunea de blocare a usilor automat la depasirea vitezei de 15 KM/h si dupa cateva saptamani am observat ca atunci cand descui usile si nu pun contactul, ele se incuie automat. Nu imi dau seama daca are sau nu legatura cu activarea facuta de mine si nu gasesc o alta optiune pentru a dezactiva blocarea usilor automata atunci cand nu bag cheia in contact.
Aveti idee cum se rezolva? Poate are legatura cu eroarea de mai jos?
   Component: 03 Komfortgerát HLO 0004
   Coding: 00259
   Shop #: WSC 00028
   Part No: 1C1959801
   Component: 03 Tõrsteuer.FS KLO 0202
   Part No: 1C1959802
   Component: 03 Tõrsteuer.BF KLO 0202
   Part No: 1C0959811
   Component: 03 Tõrsteuer.HL KLO 0202
   Part No: 1C0959812
   Component: 03 Tõrsteuer.HR KLO 0202
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Modificat de C o s m i n
mutat
Broasca usii sofer are lipituri reci si/sau switch defect, astfel ca modulul confort nu vede usa deschisa si incuie usile la loc.
Multumesc pentru raspuns. O duc la doctor
exact - altfel, e normal sa faca asa, dar cand nu deschizi usa  - yala de la sofer are clar lipituri reci, avand in vedere eroarea stocata
Eu am scos broasca am spalat cu spray contact microswitchi ul,am desfacut broasca,ma rog partea electrica si fata de cea originala,an 97,este mai simplista,adica are cu 4 parca mai putine switchiuri,pe placa in interior.Mentionez,ca broasca schimbata este din 2002.La inceput a functionat bine,adica se inchideau toate cele 4 din telecomanda,de fapt alarma.Apoi dupa cateva zile,ia revenit melicul,si usa in cauza,de la pasager,la armare din telecomanda ramane deschisa.Am citit pe forum,ca poate nu se pupa broasca cu modulul confort la cod!?
