Ce Tip De Probleme Aveti? Doar B6!
bogdancu24
Ce tip de probleme aveti ? doar B6 !!!
885 voturi
  1. 1. Selectati problemele pe care le-ati avut la Passatul B6
    • Probleme de motor
      354
    • Probleme de caroserie
      36
    • Probleme de vopsea
      129
    • Probleme de butoane
      116
    • Probleme de suporturi
      22
    • Probleme de suspensie
      85
    • Probleme de directie
      68
    • Probleme la sistemul de franare
      51
    • Probleme la sistemul de iluminare
      58
    • Probleme de confort
      58
    • Probleme la sistemul de sigurantza
      26
    • Probleme la sistemul de climatizare
      85
    • Nu am nici o problema
      234
Dacav pana acum mergea....nu are treaba cu modalitatea de conectare....
Functioneaza asa de cand am luat masina...de 11 luni, din pacate.
Am o problema...pornire greoaie si la cald si la rece,uneori se opreste in mers,pur si simplu,nu se accelereaza,are simptome sa „moară” motorul...nu se alimenteaza,cred...am schimbat ieri bateria si nimic...ajutor va rog.am facut  o diagnoza si am urmatoarele:
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9248
   Revision: --H06---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 80093 222 69422
   VCID: 7AFB1463352A82CEDA7-802F
4 Faults Found:
000387 - Fuel Temp. Sensor A (G81)
               P0183 - 000 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 188328 km
                    Time Indication: 0
                    Date: 2015.09.30
                    Time: 10:08:17
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.31 V
                    Temperature: 38.7°C
                    Temperature: 55.8°C
                    Temperature: 38.7°C
006470 - Control Module 1 for Coolant Fan
               P1946 - 000 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 188372 km
                    Time Indication: 0
                    Date: 2015.10.04
                    Time: 18:39:53
             Freeze Frame:
                    RPM: 1554 /min
                    Speed: 23.0 km/h
                    Load: 7.5 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Temperature: 76.5°C
                    Duty Cycle: 9.7 %
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 188399 km
                    Time Indication: 0
                    Date: 2015.10.07
                    Time: 11:18:31
             Freeze Frame:
                    RPM: 798 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Inj. Quantity: 2.96 mg/str
                    Temperature: 38.7°C
                    (no units): 0.0
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 189025 km
                    Time Indication: 0
                    Date: 2015.11.06
                    Time: 10:11:06
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Temperature: 38.7°C
                    (no units): 0.0
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930631400788
   Coding: 0000014
   Shop #: WSC 00028 028 00001
   VCID: 285F1E2B9B06C05EFC3-807D
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 224
                    Mileage: 187665 km
                    Time Indication: 0
                    Date: 2015.09.01
                    Time: 09:38:41
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1123
   Revision: 31008001    Serial number: 00000091469113
   Coding: 0000182
   VCID: 3D71DF7F648475F6BF5-8068
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 212
                    Mileage: 188499 km
                    Time Indication: 0
                    Date: 2015.10.15
                    Time: 18:09:55
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004579763
   Coding: E1800F0700041A00470A00000F00000000095D435C0001
   VCID: 6CD7223B4F7E2C7E58B-8039
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 031006 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     081106 014  1201
   Coding: 00208933
   Shop #: WSC 00028
2 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 188789 km
                    Time Indication: 0
                    Date: 2015.10.24
                    Time: 18:21:00
             Freeze Frame:
                        ON
                    Voltage: 10.90 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 188974 km
                    Time Indication: 0
                    Date: 2015.11.04
                    Time: 07:30:00
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0000182
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 212
                    Mileage: 188499 km
                    Time Indication: 0
                    Date: 2015.10.15
                    Time: 18:09:55
Ti s-a raspuns la proceduri vag-com. In plus ar trebui verificata si pompa de combustibil. Posibil merge intrerupt.
Cam multe erori ai pe mașina. Cred ca este căzu sa te duci la un service....
salut! nu m-i s-a raspuns concret in sectiunea Proceduri vag com...vreau un raspuns concret pentru fiecare eroare...daca am cerut ajutor aici...inseamna ca nu am gasit o rezolvare buna la mine...am incredere in parerile voastre si de aia cer ajutor de aici...multumesc mult si scz pt deranj.
Bine ai procesat! Acel topic este citit de userii x,y si z si acest topic este citit doar de q, w, si e.
Inainte de a mai posta te rog sa citesti si sa respecti regulamentul vwforum!
eroare de pe Engine nu are legatura cu pompa ci este de la senzorul de temperatura carburant - aflat pe motor - trebuie verificat cablajul acestuia, deseori se intrerupe circuitul
Buna ziua. Imi poate spune cineva unde este situata mai exact mufa clapetei ShuttOff? Este vorba de mufa din dreapta EGR-ului? Multumesc.
mufa clapetei v157 - este in fata la motor, intre el si radiator, ai clapeta
Aceasta este, nu?
Daca merg 2-3 zile cu mufa scoasa, imi afecteaza cu ceva masina? Multumesc din nou.
da, aceea este. Poti merge, daca-i musai....
dumitrualexander
La masina din semnatura mi s-a aprins astazi in bord martorul de check engine fara ca masina sa aiba vreun simptom. Nu a aparut niciun mesaj suplimentar in bord, nu a pierdut putere, nu a devenit zgomotoasa si consumul a ramas la fel.
I-am facut o diagnoza si mi-a dat urmatoarea eroare:
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
P2098 - 002 - Too Lean - MIL ON
Masina e cea din semnatura, VW Passat B6 2.0 FSI BLR
Are cineva idee de la ce ar putea fi?
Am resetat eroarea si a disparut.
Salutare colegi,
Astazi am schimbat bateria la masina, cea de fabrica a rezistat 6 ani, Varta de 61A.
Am schimbat-o tot cu o Varta, dar de 77A.
Dupa ce am schimbat-o si am pornit masina, am dat o scanare pe VCDS sa sterg toate erorile, dar mi-a ramas eroare la senzorii de parcare, care numai merg.
Inainte de a ma lasa bateria au mers fara probleme, chiar si in ziua in care am pornit masina prin cabluri de la alta baterie n-am avut probleme.
Cand apas pe buton imi face flash-uri si beep-ăie, pe ecran nu-mi apare nici OPS.
Am senzori fata - spate OEM.
post-140911-0-58730800-1447268188_thumb.
Iti trebuie alt modul,la cel de pe masina s-a "prajit" softul
Modificat de EEXCALADE
Si acest modul de unde il pot lua ? Si cat ar ajunge.
Si cum de s-a prajit asa de-odata, doar ca am schimbat bateria ?
J446 se afla in portbagaj in partea dreapta, un cod din etka ar fi 3C8919475A (ultima versiune) ,pret aprox 700 ron nou.Cauta sh
Se putea strica si fara sa umbli la baterie.
O alta varianta ar fi rescrierea softului.
Ok, merci mult, trebuie sa iau o versiune anume de an ?
Sau pot lua orice modul compatibil ?
Si mi se pare ciudat asa de-odata sa se duca, n-am avut deloc probleme cu el, iar la masina nu s-a umblat cat a stat descarcata, pana mi-a venit comanda de baterie.
Poti cauta un kit retrofit ops update. Ajungi la aprox 250 ron.
Problema la Passat B6 2.0 Bluetdi 2010, scoate un zgomot intermitent, ca si cum ar fi scos un surub si s-ar lovi de ceva. Asta doar la rece, cand se incalzeste, se opreste zgomotul
Salutare colegi,
da, asa se intampla cu ele  - probabil variatia de tensiune l-a dat peste cap.
trebuie inlocuit.
si retrofit... si update...  :winter:  e pe treaba...
mergi la un mecanic sa o asculte, ca sa stii daca poti sta linistit sau ai ceva de remediat - din pacate nu ne putem da cu parerea, daca nu o auzim.....
Am o vaga parere ca ar fi de la volant, dar nu sunt sigur de asta...
se modifica sunetul cand apesi pedala de ambreiaj ? daca da, se poate sa fie de la volant
