My Comfort Coupe(CC)1.8 TSI-160CP
GP-05-GB
Va salut
Sa imi prezint si eu CC-ul
An fabricatie 16/04/2009 1.8 TSI-160 CP cutie manuala ,ultimul servis10/2/2014 in present masina are 40 mi/mile
culoare silver reflex metalizat
Jante interlagos 18"
panoramic sunroof.
factory tint windows
cruise control
anti-dazzle mirror
boot lid release
tank flap release
electric windows
electric and heated mirrors
3 way climatronic
electric sun blind(for the rear window)
Tyre monitor display
background lighting(red)
insulating glass(windscreen)
rain sensor
parking sensor(front/rear)
RCD 510 Radio DAB/CD/MP3/6CD-Changer/Aux/Traffic information program/...etc..etc..
NU ma intereseaza navigatia pentru ca nu primeste toate post cod-urile!!!
NU ma intereseaza pielea,m-am saturat sa o sterg lunar(se zgarie,crapa..etc).. :)
Btw nu ma intrebati de ce este volanul pe "partea gresita"!!..locuiesc in uk... :)
post-137593-0-18432700-1402162550_thumb.
post-137593-0-69139100-1402162619_thumb.
post-137593-0-46833500-1402162640_thumb.
post-137593-0-18928200-1402162658_thumb.
post-137593-0-61193500-1402162699_thumb.
post-137593-0-58081400-1402162777_thumb.
post-137593-0-71357000-1402162936_thumb.
Modificat de GP-05-GB
mai multe poze..
post-137593-0-08303700-1402166834_thumb.
post-137593-0-51768900-1402166848_thumb.
post-137593-0-98644700-1402166874_thumb.
post-137593-0-89789900-1402166929_thumb.
post-137593-0-26486100-1402166950_thumb.
post-137593-0-75704700-1402167283_thumb.
post-137593-0-03512900-1402167300_thumb.
post-137593-0-55330500-1402167322_thumb.
post-137593-0-43721400-1402167681_thumb.
post-137593-0-12918000-1402167695_thumb.
post-137593-0-21670400-1402167710_thumb.
post-137593-0-62949600-1402167727_thumb.
post-137593-0-84211400-1402167749_thumb.
Foarte frumoasa masina, si vad ca e si ingrijita.
Nici de dotari nu duci lipsa, are ceva totusi. Motorul este unu destul de ok zic eu, are ceva vlaga in el..cu o resoftare ajungi pe la 200+ CP si cred ca o sa iti placa mult cum trage :)
Acuma stau sa ma intreb, ca...cum de la CC-uri nu le-o pus lupa in faruri, ca B6-le au.
Frumoasa masina si cele mai frumoase jante (parerea mea) care merg pe CC le ai tu :).
@xDaniel - ieri am vazut un frumos Touareg R Line alb 2012 cu faruri normale...deci nu ma mira ca sunt si CC-uri care nu au...dar oricand se poate face un retrofit.
CustomPerformance
Arata bine masina, jantele intradevar sunt perfecte pe masina. Ce planuri ai pentru ea?
Va multumesc pentru comentari
Sincer sambata trecuta am cumparat masina,cred ca este prea devreme sa ma gandesc la planuri de viitor...:)
Probabil un remmaping by REVO(trebuie sa ma documentez pentru ca s-ar putea sa "obosesc" ambreajul).Astept citeva pareri de la cei care deja au facut!?
In legatura cu farurile chiar nu ma interesat ca au sau nu lupa...btw o sa fac un upgrade cu Philips diamond vision.(H7).Xenonul ramane o "fita" avem drumuri si autostrazi ok
Astazi am facut interiorul si am vazut ca am si SD card reader!!.....
Daca inlocuiesc becurile din interior(cele de la nr.) cu LED-uri imi apare eroare bec ars in bord???
 va doresc drumuri bune
salut.
sa-l stapanesti sanatos !
becurile de interior - o sa ai erori doar la scanare.... pe bord nu.
becurile de la exterior = de la numar - trebuie sa pui unele asa zise -can bus - ele o sa pacaleasca sistemul, ca sa nu ai erori in bord si sa le tina aprinse.
Poti incerca becuri asa numite Blue...daca chiar nu vrei Xenon.
Eu mi-am pus Osram Cool Blue Intense, si se vede diferenta cat de cat...Dar o sa imi pun xenon luna asta.
Eu am facut videoul, cu diferenta intre Cool Blue si Stock.
post-104622-0-67025100-1402307632_thumb.
Modificat de xDaniel
dar tu ai lupa, CC-ul nu are in varianta de baza cum o are el, nici eu nu inteleg de ce au fost configurate asa astea de 1.8, aici am vazut multe in configuratia asta dar doar cu motorul de 1.8, tot ce e 2.0 sau 3.6 vin standard cu xenon, piele, navi, etc...
GP-05-GB  - xenonul eu il consider un safety feature, nu prea il vad ca fita. Poti pune LED-uri CANbus si nu vei avea erori.
Modificat de mik15
Mersi pentru ajutor
@xDaniel am folosit pe citeva masini Osram, stiu este o mare diferenta...singura problema se ard prea repede
Cum am spus merg pe Philips Diamond Vision(revin cu citeva poze sau un filmulet)
@mik15 ma repet sunt foarte putini cei care aleg Xenonul in uk.In orase se foloseste iluminatul public,iar o mare parte din strazi/autostrazi la fel sunt iluminate.
Pentru romania clar NU este o "FITA"stiu bine cum sunt drumurile acasa si felul cum se circula, ca sa nu mai zic ca intilnesti toate animalele domestice pe drum!!!..:)
@Florin cheers bro.
Cei care aveti motorizare 1.8 TSI-160cp.
-cam cit ulei completati intre servisuri(eu am Castrol EDGE-5w-30)
-la citi km se schimba curea ,intinzatorul(in present am 40mi/mile-64 mi/km.)
-daca in Romania la full service se schimba filtru de benzina
-pe capacul de la rezervor producatotul recomanda benzina 95!!..ce parere aveti?,
mersi anticipat
Da vad ca e liniste totala...... :D Nu mai este in trend motorul 1.8TSI!!.Cine ma ajuta si pe mine cu part nr. pentru pedalele din aluminium,as vrea sa le command de la unul din dealer VW. Thanks.. :icon_thumleft:
Incearca in aria tehnica pentru raspunsuri vis-a-vis de motorizare, iar pentru coduri, exista sectiune separata, tot aici pe forum.
On topic: Frumoasa masina, sa o stapanesti sanatos!
daca prin curea si intinzator de referi la distrubutie, motoarele TSI o au pe lant, deci nu mai e nevoie de schimbat distributia. Sincer sa fiu la Passat nici nu m-am uitat daca manca sau nu ulei, insa cum e comun TSI-urilor, cu siguranta iti va manca cel putin un 500gr la 10k km, best case scenario, GTI-ul manca mai mult dar lua si mai multa alergatura. Pe capacul de la rezervor este trecut tipul de benzina de la care pleci in alegere, adica 95 este minim, poti pune linistit un 98 sau mai mult, eu puneam doar 98 fiind cea mai buna aici, nu exista 99 sau 100. Ca si ulei cei de la VW foloseau 5w40 aici, iar intervalul de schimb al filtrului de benzina este trecut in cartea service.
In seara asta am aflat ca am pe masina static cornering lighting :tuktuk: ...asta este daca nu ma prins noaptea pe sosea pina acum!
Ramane sa verific maine ce fel de becuri sunt?....cred ca H7
Mersi @cogdao & @ mik15 :icon_thumleft:
Am parcurs 4218km cu 339,38Litri benzina,asta inseamna un consum de 8Litri/100km
70% din drum pe autostrada si 30%prin localitati(asta este naveta pe care o fac zilnic)
bezina super 97 vad ca cu asta se simte cel mai bine :D
R: ~ 0.5 litri. pot merge 15.000 km si fara sa completez, dar  pe la 10.000 scade sub 50% si atunci pun restul de 0.5 l cat mi-a ramas de la revizie ca sa mai ridic nivelul peste 50%.
R: distributia e pe lant. nu trebuie schimbata, dar trebuie verificata vizual sa zicem 1 data la 2 ani.
atentie totusi: exista inca 2 curele care angreneaza diverse componente, si care se schimba ca orice alta curea: cureaua de distributie si cureaua de transmisie.
R: filtrul de benzina nu se schimba teoretic la acest motor. e localizat undeva pe langa rezervor, si e cam complicata demontarea lui. practic, il poti schimba daca vrei.
R: motorul merge ok cu 95. cu cea de 100, motorul parca merge mai rotund/suna mai frumos, desi ca performante e cam la fel. de asemenea, si consumul e mai mic cu ~ 0.5 litri/100km cu cea de 100. ca si concluzie personala, e ok sa faci un plin cu benz de 100 o data la cateva luni. in rest, e buna si cea de 95, diferenta de pret dintre cele 2 sortimente e maricica, si nu se justifica cea de 100 doar pt ca motorul suna mai bine.
  • 11 months later...
Va salut
urmatorul servis il am in ianuarie,as vrea sa trec pe CASTROL EDGE 5W30 LL FST Titanium.
Ce parere aveti?...a folosit cineva acest ulei pana acum!
post-137593-0-14878300-1447274166_thumb.
Salut.Felicitari pentru achizitie si multi km fara probleme!
Eu folosesc Mobile 1 ESP Formula 5w-30 pentru ca asta aveam in ea cand am cumparat-o, am continuat si eu cu acelasi ulei.La urmatorul schimb o sa trec cel mai probabil pe Motul Specific, desi nu am nimic contra Mobile 1.Iti trebuie un ulei care sa fie compatibil cu norma VW 504 00 .Asta e 507 00.Am cam 11.000 km de cand l-am schimbat si am completat cam 1 litru,dar eu am si o problema de etanseitate la baia de ulei.E usor umeda.
In rest din punct de vedere al motorului si cutiei de viteze totul ok pana acum(a cumparat-o la 113.000km si acum am 139.000 km),dar daca citesti rubrica mea de prezentare o sa vezi ca a mea a avut o interventie majora la motor din cauza distributiei care s-a decalat(intinzatorul),mare vina avand si vechiul proprietar.De asemenea am umparat-o cu  remapare de la MTM la 215 cp.Sincer trage foarte bine si e o placere sa o conduc pe autostrada datorita reprizelor bune si elasticitatii motorului.Schimb foarte rar din treapta a 6-a si obtin performante decente.Daca retrogradez si o tin peste 3500 rpm e foarte rapida.Ca si consum mediu la pompa sunt undeva la 10,5 l/100km cu benzina de 98 50% oras 50% si e destul de aglomerat orasul.
In rest mai am o mica problema la esapament care nu cred ca e din cauza resoftarii dar o sa ma ocup de ea cand o sa ma mai duc cu masina in tara.Imi apare o eroare de catalizator din cand in cand ,care nu influenteaza cu nimic mersul masinii.
Daca vrei sa mai schimbam impresii despre motoare mai ales,pentru ca majoritatea proprietarilor au diesel, scrie-mi pe privat.
Multa bafta!
Salut Bogdan
Uleiul  este in norma VW 505.00  507.00 am inteles ca nu este nici o problema sa il folosesc.
Eu nu completez mai mult de 200-300 grame intre servisuri...si am in masina Castrol Edge FST.
Din contra am citit ca noul Edge LL FST boost with titanium este si mai performant,de ce sa trec pe Motul!!???
Probleme cu masina?..NU.. in afara de citva "greierasi" prin interior,un motor super REUSIT distributie pe lant.
O sa folosesc noul Castrol Edge LL FST Titanium la anul in ianuarie cind am servisul.am vorbit cu unul din dealer VW a zis ca este ok :icon_thumright:
post-137593-0-70163000-1447443687_thumb.
post-137593-0-26420700-1447443722_thumb.
Va salut am o problema care a aparut pe neasteptate cu Auto-Hold!!..Am apasat butonul auto-hold la semafor,iar dupa citeva secunde ledul indicator sa stins dintr-o data!!..dupa care a trecut automat pe frana de mana(sa apris butonul de la frana electo-mecanica)Am incercat de citeva ori sa folosesc AUTO-HOLD dar nu mai functioneaza!..A mai intimpinat cineva aceiasi problema,sau aveti idee ce sa intimplat?
