Passat 3b 1.9 TDI White :)
norbysr
Va prezint prima mea masina un :
Volkswagen Passat 3b 1.9 TDI AJM 116 cp 300.000km+
an fabricatie 1999 noiembrie
dotari :
Jante 18 MAM 8 5x112 et 35 8j 215 40 fata / 225 35 spate
suspensie sport reglabila AP
Faruri Dayline
Bara fata clean
urmeaza bara spate si bandouri
X0A = National sales program Germany
B0A = Component parts set without country-specific design requirement
C0U = Alloy wheels 7.5J x 17
G0C = 5-speed manual transmission
H6S = Tires 195/65 R15 V
J0R = Battery 380 A (80 Ah)
M3L = 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0
Q2J = Comfort front seats
1AJ = Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
1G2 = Steel spare wheel with original equipment tires
1MY = Steering wheel for air bag system
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
T4N = 4-cylinder diesel engine 1.9 L unit 038.A
3FE = Electric slide/tilt sunroof with sun screen/sunblind
3S2 = Black roof rails
STC = code not found :-(
QG2 = No possibility of activating service interval prolongation
8AD = Radio "gamma"
8GL = Alternator 120 A
8RM = 8 speakers (passive)
1LB = Disc brakes, front
0JG = Weight category front axle weight range 7
0YE = Weight range 5 installation control only, no requirement forecast
1BA = Standard suspension/shock absorption
Modificarile facute de mine sunt :
Catalizator scos
Suspensie reglabile AP
Jante mam 18
Bara fata clean
Faruri Dayline
Urmeaza sa vopsesc pragurile alb si bara spate clean
post-134280-0-06590400-1396353897_thumb.
post-134280-0-38472400-1396353897_thumb.
post-134280-0-97008200-1396353897_thumb.
post-134280-0-61254400-1396353898_thumb.
post-134280-0-26662100-1396353954_thumb.
post-134280-0-42876600-1396353969_thumb.
Modificat de norbysr
Foarte frumos passatul sa il stapanesti sanatos si sa te vedem cat mai curand pe la concursuri de frumusete :)
gctinvalentin
Frumos sa il stapanesti sanatos si cati mai multi km fara evenimente.
Masina a avut un inceput bun dar pare neterminata.Bara fata nu are bandou iar bandourile de pe restul masinii nu au fost scoase.Bara din fata este vopsita integral alb dar pragurile si fusta spate sunt negre.La fel si cu bandoul spate care a ramas nevopsit.Nu o lua in nume de rau dar parca ai inceput ceva in fiecare parte a masinii dar nu ai si terminat nici o parte.
Oricum bafta cu proiectul.
Modificat de TheOne06
doar complicatii am avut cu masina vroiam sa vand sa iau un facelift so fac pe aia acuma am ramas la asta ca nare nimic in plus cel facelift fata de a mea doar 131cp.... prima data am vopsit bandourile din bara nu mio placut , dupa ce am inceput sa vopsesc bandourile din bara spate am zis ca mai bine le scot si le fac asa , nu prea am timp sa fac totul deodata dar incet incet va prinde viata masina , saptamana viitoare revopsesc bara fata , pragurle si scot bandourile bara spate sa fie clean look , iar la anul scot bandourile din usi si plafon si vopsesc toata masina alba , capota a fost lovit e alta culoare bara fata iar alta culoare nu a iesit cum am vrut eu ... anu asta asa va ramane masina clean look bara fata spate
