Golf 6 - Probleme / discutii alarma OE
ShadoWzZ
Salut, de curand am observat ca alarma masinii nu mai functioneaza.
Am facut un scan cu VCDS is erorile de pe centrala sunt urmatoarele:
Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 084     HW: 1K0 937 084
  Component and/or Version: BCM PQ35  B   020 0358
           Software Coding: 46180A388021E3C040080080040008E447600088524D8920648020000000
            Work Shop Code: WSC 01357 011 00200
                      VCID: EBDEF0C61A526646CA7
3 Faults Found
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 166900 km
                    Time Indication: 0
                    Date: 2008.14.22
                    Time: 20:49:03
             Freeze Frame
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03156 - Sensor for Anti-Theft System (G578)
             Freeze Frame
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 166900 km
                    Time Indication: 0
                    Date: 2008.14.22
                    Time: 20:49:03
             Freeze Frame
                        Term 15 On
                    Voltage: 13.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
03020 - Local databus 2
            012 - Electrical Fault in Circuit
             Freeze Frame
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 166900 km
                    Time Indication: 0
                    Date: 2008.14.22
                    Time: 20:49:12
             Freeze Frame
                        Term 15 On
                    Voltage: 13.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Astazi a pornit alarma random, cand am iesit din masina, cand am pornit motorul, cand am deblocat-o, etc.
Va rog ajutati-ma. Multumesc.
  • Replies 85
  • Al Bundy
    16
  • F l o r i n
    12
  • Mistery
    12
  • bor@
    9
Am citit povestea tipului de aici:
http://www.golfgtiforum.nl/forum/viewtopic.php?f=14&t=1727
Are exact aceeasi problema ca mine, culmea din cauza xenon-ului AM a avut problema aceasta.
Mentionez ca am xenon AM de vreo 2-3 luni.
Kit-ul xenon este acesta. Tind sa cred ca este ballast analogic, nu digital. (Cele analogice creeaza interferente)
Se pare ca ai un integrat dus din centrala electrica.
inainte de asta verifica siguranta de alimentare a senzorilor si a goarnei, dar slabe sanse.
Asta se intampla din cauza csenoanelor chinezesti.
La sigurante totul este ok.
Foarte fain... Chiar ma gandeam la un timp sa imi pun centrala HL, uite ca mi se va indeplini dorinta...
Xenoanele sunt cele mai scumpe de pe piata romaneasca dar vad ca tot degeaba...
Bundy, ma poti ajuta in cautarea unei centrale hl ? Sa suporte si led taillights ?
Am gasit undeva la 600-700 lei
degeaba... din pacate chinezariile au riscurile lor.
Care este diferenta intre bcm-urile 1k0 xxx xxx si 5k0 xxx xxx, in afara de carcasa de plastic.
Tot nelamurit sunt cu litera de dupa cod: 1K0937087R, 1K0937087AB, etc. Ce reprezinta, trebuie sa ma orientez dupa litera ?  :tuktuk:
Aici sunt mai multe modele de bcm.
Daca ar fi, aceasta as comanda-o.
Multumesc pentru ajutor.
Modificat de pecalin
Cu cat mai noua cu atat mai bine, ia -o pe cea de pe carsystems.pl/
  • 5 months later...
Salut!
Am si eu o eroare la alarma de fabrica la un Golf 6 fabricat in 2009.
Scanarea arata in felul urmator:
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 48180A3A9825F3C040080080140001E445510088536D8960648000000000
   Shop #: WSC 01357 011 00200
   VCID: EDD1AF3F3464A576CF5-80B8
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 25020  21  0501
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 170309 05  54  0402
   Coding: 0330AD
10 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 110
                    Mileage: 79361 km
                    Time Indication: 0
                    Date: 2010.14.11
                    Time: 13:15:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 110
                    Mileage: 79361 km
                    Time Indication: 0
                    Date: 2010.14.11
                    Time: 13:15:17
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.90 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 111
                    Reset counter: 73
                    Mileage: 79361 km
                    Time Indication: 0
                    Date: 2010.14.11
                    Time: 13:15:19
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.85 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 21
                    Reset counter: 99
                    Mileage: 80841 km
                    Time Indication: 0
                    Date: 2011.14.16
                    Time: 08:47:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Am inteles ca "goarna" are o baterie proprie ce ar putea sa fie descarcata. Exista o asemenea varianta?
da, se mai strica - nu se descarca, dar nu numai asta e problema lor - am gasit defecte, la care acumulatorul era intact.
DA, cu modificarea fizica si din soft a eepromului modulului confort.
Imi poti da mai multe detalii te rog? Eu am pe masina din semnatura h8 si am luat de pe un passat h12 , ma intereseaza ce pasi trebuie urmati pentru a functiona.Am vazut ca la mine vin doar 2 fire in goarna pe cand la h12 vin 3 , cel rosu cu galben e in plus fata de h8 si presupun ca trebuie legat la +. In rest celelalte 2 le pot lega pe cele care vin in h8? Ce adrese se modifica in modul si cu ce interfata se modifica aceste adrese?
in ce consta diferenta in functionalitate dintre h8 si h12 de vrei sa faci schimbarea asta?
Nimic in plus, decat sunetul - daca te referi strict la partea de inlocuire a acesteia.
Se modifica cu Vds Pro...si interfata seriala...si port nativ serial la laptop.
Pe ce adresa, 25 sau 35 si ce anume modiific? Dar legaturile sunt asa cum am zis mai sus?
Te referi pe ce modul ? Pe 46.....din pacate nu am la mine documentatia, te pot ajuta abia sapt voiitoare
wrote 112 in the horn mode addresses (4367,4368 and 4369)
Si legaturile le faci asa, ca in schema de mai jos. Alimentarea goarnei o iei de la sig S111.
Modificat de Al Bundy
Multumesc mult baieti , ma apuc de treaba cat de curand si daca o sa intampin probleme o sa revin iarasi cu intrebari.
Cu plus ul  dacă ma leg la mufa care duce la Sig111 pe piciorușul 4 e ok?
care piciorus 4 ?
Ala din mufa. Pe care trebuie sa ma leg? pe cel  cu siguranta de 15 albastra sau din cablul rosu care mufa care duce la releul 53?
pe cel cu siguranta, normal.
Am legat cablul maro și cel galben-negru la firele existente din alarma h8 și cel galben -rosu la Sig111, am modificat adresele și tot nu merge. Mai trebuie modificat ceva?
Modificat de bor@
firul negru-galben l-ai mutat de pe pin 11 pe pin 3 in mufa de la modulul de confort ?
