Volkswagen Golf Sportsvan concept. Viitorul Golf Plus
DANNY VW
Toate detaliile in articolul de mai jos:
Volkswagen has released preliminary details and a photo gallery with the Golf Sportsvan concept.
Described as a compact minivan, the Golf Sportsvan is pretty much a preview of the upcoming Golf Plus which our spies have already caught testing. The concept is 134mm longer than the previous Golf Plus and 83mm longer than the five-door Golf hatchback. In addition, the wheelbase has been extended by 48mm compared to the regular Golf VII and it's also 126mm taller and 8mm wider which has made the cabin roomier.
Cargo capacity now stands at 498 liters which means it has 74 liters more to offer than its predecessor. The rear bench has a 60:40 split and can slide fore and aft by 180mm to provide an extra 87 liters of storage space. In addition, the front passenger seat can be folded forward flat to enable a load space of 2484mm.
Volkswagen says the concept has been developed to work with an array of six engine, with outputs ranging from 85 HP (63 kW) to 150 HP (110 kW). The most frugal version is the 1.6 TDI BlueMotion with 110 HP (81 kW) which enables the Golf Sportsvan to have a fuel consumption of 3.7 liters / 100 km (63.5 mpg UK or 76.3 mpg US) with CO2 emissions of 95 g/km.
Various safety and assistance systems have been incorporated in this concept, such as Blind Spot Monitor with Rear Traffic Alert, Adaptive Cruise Control, City Emergency Braking, lane-keeping assistant and emergency braking function, just to name a few.
More info will be released at next week's Frankfurt Motor Show.
Source: Volkswagen
post-1756-0-06504800-1378639915_thumb.jp
post-1756-0-34400600-1378639936_thumb.jp
post-1756-0-74170400-1378639956_thumb.jp
  • Replies 59
  • voinea
    16
  • TudorM
    10
  • soila
    4
  • Hayate
    4
Inseamna ca asa va arata si interiorul urmatoarei generatii de Tiguan.
Eu tot as merge ori pe Hatch-ul normal, ori pe Variant. Eu zic ca profilul sigur nu va arata asa.
Ar fi perfect daca ar pastra numele de Plus.
Mult mai mic. Pana la sharan mai e Touran ce poate avea 7 locuri
Creste destul de mult in dimensiuni fata de generatia anterioara:
"The concept is 134mm longer than the previous Golf Plus and 83mm longer than the five-door Golf hatchback. In addition, the wheelbase has been extended by 48mm compared to the regular Golf VII and it's also 126mm taller and 8mm wider which has made the cabin roomier.
Cargo capacity now stands at 498 liters which means it has 74 liters more to offer than its predecessor. The rear bench has a 60:40 split and can slide fore and aft by 180mm to provide an extra 87 liters of storage space. In addition, the front passenger seat can be folded forward flat to enable a load space of 2484mm."
Eu zic ca arata f bine la interior, un progres clar fata de varianta precedenta.
Interesanta evolutie a golfului plus. Denumirea insa nu o inteleg, ca nu-i nici sportiva la 150 hp nici dubita... mai bine era golf plus.
In engleza "van" se refera si la monovolume. Ca nu e sportsvan, ai dreptate. :)
Conform prezentarii de la Frankfurt acest model se va numi Golf Sportsvan de acum inainte.
Poate s-au hotarat sa renunte la Plus si la Touran si sa le bage intr-un singur model... Cam pe acolo pare modelul asta!
touran-ul e mult mai mare decat asta...
nu cred ca renunta la gama touran/sharan
in germania numai din astea vezi, si break-uri multe
nemtii sunt mai practici, nu sunt fuduli ca romanii care vor numai berline si limuzine :))
Ce treaba are design-ul cu fudulia? Omului ii place in 3 volume, isi ia in 3 volume (si asta venind de la cineva cu hatchback). Uita-te in state, acolo nici nu se pune problema de break-uri, nu se vand deloc si au limuzina pe primul loc.
Si nici Touran-ul nu-i asa mare, are 4,44m lungime deci iese mai scurt decat noul Sportsvan.
Asta vroiam sa zic, ca Touran-ul e mai mic decat asta, desi e doar in stadiu de concept momentan.
Daca Plus-ul a crescut cat un Touran, in cazul in care cele doua modele nu se fac unul singur, Touran-ul ajunge cu 7 locuri si cat un Sharan? :)
Ramane un punct de discutie interesant relatia Golf Sportsvan/Touran/Tiguan. Oficiali VW au vorbit clar de generatie noua de Touran pentru 2014 si Tiguan (bazat pe Plus/Sportsvan) pentru 2015. Deci modelul Touran sigur nu dispare, sa vedem in ce categorie o sa intre.
asa si audi A8 are 5 m lungime, dar tot 5 oameni incap in ea, si tot bagaje pentru 3 dintre ei incap in porbagaj
in golf plus nu incape cat incape intr-un touran.. asta sa fie clar de la inceput :d asta venind de la cineva care are Transporter, golful e de fudulie, masina de oras :)
o poza care face toti banii
Fara suparare, dar cred ca tu nu esti constient de conotatiile cuvantului "fudulie" si cam cum ii portretizezi prin generalizare pe toti care nu au aceleasi conceptii de viata cu tine. :) Si nici n-a zis nimeni ca Sportsvan are portbagaj mai mare decat Touran (487 vs 800 si ceva). Incepem sa facem comparatii fara rost (ce treaba are A8 in discutia asta?).
Suntem multi posesori de hatchback de toate marcile prin Europa si alte continente. Chiar si tu ai Golf 4. Suntem toti fuduli? :)
esti tare rau offtopic, si nu inteleg de ce...
colegul mai sus zicea ca golful sportsvan poate inlocuieste touran-ul, si eu am zis ca nu prea are cum, ca e un segment important, mai ales ca in germania se cumpara foarte multe...
de aici si pana la fudulia si legatura cu hatchback... e distanta lunga, si in aer si pe uscat :D
Modificat de alios
Tu ai facut remarca asta de doua ori, daca eu sunt off-topic rau... :)
Si eu ce am zis legat de Touran? Exact acelasi lucru ca si tine. Pe scurt, ne certam degeaba. Trecem mai departe.
Modificat de TudorM
sa rad ca sa nu plang :)) ortografia a fost buna ? am pus punctul bine la final ? hai ca nu te lasi :)
in fine, ideea era ca: golf sportvan nu poate inlocui touran, parere personala.
Modificat de alios
Acum are ceva aparte, nu e doar drag&drop de pe Golf 7.
Modificat de The_Ego
sunt deja pe mobile.de cateva Sportsvan 1.6TDI si 1.4TSI. Singurul 2.0TDI 150cp + DSG este :
http://suchen.mobile.de/auto-inserat/vw-golf-sportsvan-comfortline-bmt-2-0-tdi-dsg-xenon-ahlen/188730175.html?lang=en&utm_source=DirectMail&utm_medium=textlink&utm_campaign=Recommend_DES
29.600euro pret NET. Sa vedem la vara cum stau treburile la masinile cu 3-6000km :)
  • loghy a închis acest topic
