footwell lights - nu se mai aprind
Laurentiuu
Am instalat ieri footwell lights. Tras fire, activat in vag com: Footwells installed si Footwels with terminal 48d active. In momentul in care am deschis usa s-au aprins( asta ziua). Seara incerc sa vad cum functioneaza si dimmingul din meniul MFD. Era setat pe on la 30%, luminile nu stateau aprinse, maresc pana la 50% se aprind. am mers cativa km cu ele asa ( in timpul asta se mai stingeau si se aprindeau singure) apoi s-au stins de tot. deschid usa, nu se mai aprind la 100% nici cand deschid usa. m-am chinuit cu vag com, le-am dezactivat, le-am activat din nou dar nimic. centrala refuza sa mai dea 12V pe pinul 50 din mufa B. vreo idee ce poate fii? mai jos un auto scan.
Thursday,02,May,2013,11:57:45:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61 62 72 77
VIN: WVWZZZ3CZCP027499
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H25 7852
   Revision: 41H25---    Serial number: VWZCZ000000000
   Coding: 00190012042401080000
   Shop #: WSC 00028 028 00306
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BF.rod
   VCID: 6FE7CD65B6862D1
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V4DB 0022
   Revision: --H07---    Serial number: 00000004617222
   Coding: 0002480
   Shop #: WSC 00028 028 00001
   VCID: 6DDBD76D748ADF1
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0004004803
   Shop #: WSC 00028 028 00020
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW46.rod
   VCID: 7F071D25E6E65D1
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000180080310081E447716488416C81606480C7200041
   VCID: 3B7F2935BA7E811
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419
   Component: Wischer 30081  10  0603
   Coding: 00B795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 260911 05  54  0403
   Coding: 06302A
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PJVG9XR
   Coding: 0012337
   VCID: 4C9D7AE92FD0369
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110826301309
   Coding: 4180250000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS_VW46.rod
   VCID: 74EDC209DFA00E9
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 D    HW: 3AA 920 870 D
   Component: KOMBI         H03 0607
   Serial number: 00000000000000
   Coding: 160D00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 336F01159A2E491
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 150911F1001825
   Coding: 461006
   VCID: 387536398B48AA9
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: F6E9780181DC9C9
   Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003532671
   Coding: 0200B7
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356B3F0D945A571
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 3C0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002455659
   Coding: 000090
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 1002
   Revision: 1AH03733    Serial number: 00112570221001
   Coding: 0000258
   VCID: 3C7D2A297F70869
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0634
   Coding: 18910A000286403F00021F1FFC084F0B607C01
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H40 1620
   Coding: 00000008
   VCID: EFE74D653E86AD1
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003548219
   Coding: 0200B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 36693801895C5C9
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 3C0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002463794
   Coding: 000090
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000251199
   Coding: 0022167
   VCID: 356B3F0D5C5A571
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  031 0075
   Revision: 00000001    Serial number: VWZ1Z2L3198431
   Coding: 05000400040010
   VCID: 72E1C411ADB4009
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H40 1620
   Coding: 030B185A
   VCID: F1E34B1D28B2BB1
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660873615
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA_VW46.rod
   VCID: 2649E84159FC2C9
End   ---------------------------------------------------------------------
Modificat de Laurentiuu
S-au ars becurile?
Publicat (modificat)
nu. am alimentat separat si toate cele 4 lumini merg. in adv mass blocks la footwell lights am valoarea 0%, adica centrala nu activeaza iesirea respectiva.
Ai becuri normale sau pe led?
becuri normale
Siguranta arsa?
siguranta arsa nu da eroare la scan? si banuiesc ca nu are siguranta separat pentru footwell lights. care este siguranta ca nu am cartonasul cu descrierile?
Nu exista siguranta separata pentru footlights (schema sigurante). Iti apare optiunea in meniu light&? Codarea este cea corecta din cate am vazut: pe 09 Central electr. Byte 20 Enable bit 0 si Byte 12 Enable Bit 5.
da. apare in meniu la setari dar nu se intampla nimic. in adv mass blocks pe footwell lights tot 0% apare chiar daca in MFD setez la 100% si luminile pe pozitii.
DIY-ul e pentru lampi normale sau pentru cele cu led? Ai activat pe undeva chestia asta?
am verificat toate sigurantele si sunt in regula. care DIY?
pentru lampi normale.
Ciudat este ca in prima faza au mers in momentul in care deschideam usile. cand am incercat dimmingul din mfd au incetat sa mai functioneze.
daca nu mai merg asa poate stie cineva unde sa le leg ca sa se aprina odata cu luminile de la plafoniera
Unde ai legat firul de masa? Pate nu mai face contact cum trebuie. Verifica si treaba asta!
am verificat. problema este la cecm. ea nu mai da semnalul. am legat luminile de la picioare la plafoniera pana ii dau de cap.
salut! am pus si eu la numarul de inmatriculare ledurile de pe o bara spate highline. normal am eroare in bord de bec ars la nr!:) pot sa fac ceva sa scap de eroare, sau imi pun becurile mele normale? multumesc
incearca sa codezi cu bec cu led, la nr spate.
Asta daca suporta centrala si daca executa functia.
Daca nu, rezistente de anulare a erorii.
Modificat de Al Bundy
corect.... fiind 2011 cu BCM - nu are centrala ca la modelul vechi - e posibil sa suporte. Vezi lucrul asta, cand ai masina....
pai si cum se codeaza? multumesc
Cu VCDS-ul, pe 9-centrala electrica, in Long Coding helper
@Laurentiuu
Ai mai rezolvat problema cu footwell lights? Exact acelasi fenomen s-a intamplat si la mine (Passat CC 2011).
Initial nu am codat "Footwell lights with terminal 58d activ" si luminile se aprindeau cand deschideam portiera. Dupa ce am codat cu "terminal 58d activ" au aparut in meniul de bord dar se aprindeau si se stingeau. Pana s-au stins de tot si nu se mai apind deloc.
Initial am avut eroarea asta:
00061 - Footwell Lights
            007 - Short to Ground - Intermittent
Dar acum dupa ce nu se mai aprind deloc nu mai am nici o eroare!
Deocamdata e prea frig si prea multa zapada ca sa umblu la ele... voi vedea mai spre primavara!
incearca sa codezi iar, cu o interfata originala.
pare ca la tine e o problema fizica. Trebuie verificat cablajul si becurile. Daca este totul ok, este din BCM. Trebuie verificat, banuiesc ca la fire, becuri, nu ai umblat....
M-am gandit si la varianta ca interfata e problema dar momentan nu am solutii.
Pana sa codez chestia cu "terminal 58d activ" au functionat perfect cateva luni bune dar nu aveam optiunea in BC. Dupa ce am codat chestia cu "58d activ" s-a intamplat exact fenomenul descris de Laurentiuu: functionau la deschiderea portierei dar se stingeau in mers ... pana s-au stins de tot si moarte au ramas.
Revin dupa cateva teste!
Dupa ce am scos minusul de la baterie luminile s-au aprins. Am recodat "terminal 58d activ" si am constatat urmatoarele: daca din BC reglez intensitatea luminilor peste 70% ele stau aprinse fara probleme. Daca dau intensitatea sub 70%, cand le aprind pe pozitii incep sa clipeasca pana se sting. E ca si cum nu reuseste sa le tina o tensiune mai mica de 12V (banuiesc ca dimmingul ii scade tensiunea).
Folosesc becuri normale NU leduri. Am incercat si codarea cu "Monitoring: footwell lights inactive (LED)" si acelasi comportament.
Ceva pareri?
