Probleme electronice la bord(Leon)
yonuttz
Problema este urmatoarea: Masiina este un seat leon diesel 1.9 tdi,  se aprind toate becurile in bord si licare. Masina porneste o secunda si se opreste. Lucrul asta s-a intamplat dupa ce a stat mai mult timp cu bateria moarta, nepornita. Aveti vreo idee? Atasez si o scanare:Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00046 615 1234567
   VCID: 2B5F7608891E2F6
01314 - Engine Control Module
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 1L AIRBAG VW5  0A   0004
   Coding: 12620
   Shop #: WSC 00046
   VCID: 356B50700F5A696
2 Faults Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
            49-00 - No Communications
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 S
   Component: 41 Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00046
   VCID: 4E991F9C8ACC3AE
   Subsystem 1 - Part No: 1J1959801C
   Component: 41 Tőrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 41 Tőrsteuerger. BF0002r
3 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
            25-10 - Unknown Switch Condition - Intermittent
00953 - Interior Light Time limit
00933 - Electric Window Motor; Passenger Side (V148)
            62-00 - No or Incorrect Adjustment
End   ---------------------------------------------------------------------
Acelasi lucru mi-l face si mie la un passat 1.9 tdi! Numai ca mie nu imi porneste deloc, in schimb licare toate beculetele cand dau sa o ponesc! A stat o luna cu o baterie descarcata conectata si asa imi face! Sper sa aflam un raspuns, eu ma gandeam la releul de pornire
In general,daca tii o baterie descarcata atat de mult timp ea se sulfateaza,adica placile de plumb se acopera cu un strat de cristale de sulf.iar asta duce la imposibiliatea electronilor din electrolit sa mai circule. Cand incarci o astfel de baterie,ea ajunge repede la tensiunea nominala,dar nu e in stare sa tina si curentul de pornire,de aici apare simptomul " se aprind toate becurile in bord si licare.". In cazul asta se schimba bateria apoi se sterg erorile. Alta cauza posibila ar fi chiar partea electrica de la contactul cu cheie,ar putea fi murdar cu pilitura rezultata din frecare,pilitura ce conduce curentul dar are o rezistenta mare de contact,explicatie posibila pentru:
@yonuttz,.nici imobilizatorul nu pare sa functioneze,intrucat desi porneste,motorul se opreste dupa o secunda
Concluzie: incercati cu alta baterie si daca aveti aceleasi probleme,curatati/schimbati partea electrica a contactului de pornire si stergeti erorile.
Multumesc pentru raspuns. partea cu bateria am incercat-o si chiar ma gandeam la partea electrica a contactului. Dupa simtome cred ca e afectat si imobilizatorul, cum zici tu. Orice alta parere, poate sa mai intalnit cineva cu problema asta si poate spune cum a facut sigur e bine venit sa si-o spuna
Las-o cu plusul de la baterie luat peste noapte sau juma' de ora acolo si pe urma incearca iar. E posibil sa se fi pierdut codarea instrumentului de bord datorita faptului ca bateria n-a mai avut curent poate nici sa tina display-ul din bord aprins. Ma gandesc si eu, iar daca s-a intamplat asa cum cred atunci de-aici vine si interventia imobilizatorului pentru ca nu e scris bordul pe Ecu. Nu ma pricep deloc la chestii d-astea, insa am facut o paralela cu ce mi-a zis cineva cand vroiam sa schimb ceasurile pentru a pune computer de bord pe Leon.
Eu zic ca merita sa incerci intai asta pana sa te apuci sa desfaci contactul. Ce mai ai pe-acolo cu Abs-ul si Asr-ul ar trebui sa dispara de la sine dupa ce reusesti sa pornesti masina si sa mergi cateva sute de metri cu ea.
Voi nu vedeti ca lipsesc multe module la diagnoza, ecu nu e, cangateway nu e. Eu banuiesc o siguranta aresa sau un releu ce nu lucreaza. pana nu vine cu un AUTOSCAN complet, nu am cum sa-l ajut,.
O sa fac o scanare si eu , sper sa aflu care este buba!
salut! stie cnv ce inseamna martorul EPC, imi ramane aprins cand pun contactul dar se stinge dupa ce pornesc motorul..
Este perfect normal, tine de electronica motorului.
