Showing results for tags 'ssi eroare la pompa de apa?'.
buna seara. dupa aprinderea martorului de check engine,s a efectuat o scanare,si au rezultat urmatoarele probleme: Monday,10,October,2011,22:35:14:13557 VCDS Version: Beta 11.8.0 Address 25: Immobilizer Labels: 3C0-959-433-25.clb Control Module Part Number: 3C0 959 433 R HW: 3C0 959 433 R Component and/or Version: IMMO 042 0383 Software Coding: Work Shop Code: WSC 131071 1023 2097151 Additional Info: 3C0905861G ELV 027 0380 Additional Info: Geraet 2097151 VCID: 3972C64C0E43 1 Fault Found: 02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 190 Mileage: 32594 km Time Indication: 0 Date: 2011.10.09 Time: 22:56:39 Monday,10,October,2011,22:35:47:13557 VCDS Version: Beta 11.8.0 Address 01: Engine Labels: 03L-906-022-CBA.clb Control Module Part Number: 03L 906 022 EM HW: 03L 907 309 Component and/or Version: R4 2,0L EDC G000SG 3502 Software Coding: 0000172 Work Shop Code: WSC 84224 792 674566 VCID: 74EC377869A1 1 Fault Found: 009754 - Coolant Pump 2: Open Circuit P261A - 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 32583 km Time Indication: 0 Date: 2011.10.09 Time: 22:24:08 Freeze Frame: RPM: 1564 /min Speed: 21.0 km/h Voltage: 13.83 V Lambda: 95.5 % Bin. Bits: 10011111 Bin. Bits: 00000000 Temperature: 89.1°C Readiness: 1 1 0 0 0 daca s a discutat rog mutarea topicului,am cautat,dar nu imi e familiara sectiunea de B6! astept parerile voastre! multumesc!
