Showing results for tags 'modul abs'.
Masina: passat 6 trepte, motor avf, an 2001. Problema: stau aprinse in permanenta iconita pentru abs si cea pentru esp, iar semnul exclamarii pentru frana de mana clipeste continuu. Masina porneste si merge. Am facut o scanare cu vag-com si in plus fata de erorile vechi, am erori pe modulul de abs care necesita recodarea modulului abs. am incercat sa fac recodarea, dar NU MERGE. nu primeste noile valori. mai jos sunt toate erorile gasite, va rog sa ma ajutati sa recodez corect modulul abs. VAG-COM Version: Release 311.2-N Ursu Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 Address 01 ------------------------------------------------------- Controller: 038 906 019 DS Component: 1,9l R4 EDC 0000SG 1348 Coding: 00002 Shop #: WSC 00028 WVWZZZ3BZ1P104488 VWZ7Z0Y3198548 2 Faults Found: 18043 - Powertrain Data Bus: Missing Message from A/C Controller P1635 - 35-10 - - - Intermittent 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 8D0 907 389 D Component: ABS/ESP front D56 Coding: 00000 Shop #: WSC 00000 2 Faults Found: 01044 - Control Module Incorrectly Coded 35-00 - - 00778 - Steering Angle Sensor (G85) 66-10 - Not Matched - Intermittent Address 08 ------------------------------------------------------- Controller: 3B1 907 044 H Component: CLIMATRONIC B5GP 0003 Coding: 17000 Shop #: WSC 00028 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 49-00 - No Communications 01341 - Control Module in Instrument Panel On Comfort CAN (J285) 49-00 - No Communications 01336 - Data Bus for Comfort System 49-00 - No Communications Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 825 A Component: KOMBI+WEGFAHRSP VDO V13 Coding: 05125 Shop #: WSC 00012 WVWZZZ3BZ1P104488 VWZ7Z0Y3198548 1 Fault Found: 01336 - Data Bus for Comfort System 49-10 - No Communications - Intermittent Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00028 5 Faults Found: 01336 - Data Bus for Comfort System 49-10 - No Communications - Intermittent 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent 01333 - Door Control Module: Rear Left (J388) 49-10 - No Communications - Intermittent 01334 - Door Control Module: Rear Right (J398) 49-10 - No Communications - Intermittent 00463 - Control Module for Digital Sound Package (J525) 49-10 - No Communications - Intermittent Address 46 ------------------------------------------------------- Controller: 1C0 959 799 B Component: 03 Komfortgerát HLO 0001 Coding: 00258 Shop #: WSC 00028 6 Faults Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation 01334 - Door Control Module: Rear Right (J398) 49-00 - No Communications 01333 - Door Control Module: Rear Left (J388) 49-00 - No Communications 01332 - Door Control Module: Passenger Side (J387) 49-00 - No Communications 01331 - Door Control Module: Driver Side (J386) 49-00 - No Communications 01299 - Diagnostic Interface for Data Bus (J533) 49-00 - No Communications End -------------------------------------------------------
