Buna ziua,   La o alta masina decat cea din semnatura (VW Polo 1.4 FSI, an fabr 2005, 160000 km, 84 CP) se observa o functionare neregulata a motorului. Scanand am obtinut urmatoarele erori:     VAG-COM Version: Release  311.2-N Control Module Part Number: 03C 997 013      Component and/or Version: MED7.5.11           9500           Software Coding: 00071            Work Shop Code: WSC 44458           Additional Info: WVWZZZ9NZ6D027931     VWZ7Z0E21842999 Faults Found:18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal        P1914 - 35-00 - -17479 - NOx Sensor (G295) Heater Control: Implausible Signal        P1071 - 35-10 - - - Intermittent16575 - Fuel Pressure Sensor (G247): Implausible Signal        P0191 - 35-10 - - - Intermittent17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation        P1340 - 35-00 - -16712 - Knock Sensor 1 (G61): Signal too High        P0328 - 35-00 - -17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded        P1325 - 35-00 - -17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded        P1327 - 35-00 - -17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded        P1326 - 35-00 - -17736 - Knock-Control: Cylinder 4: Regulation Limit Exceeded        P1328 - 35-10 - - - Intermittent Masina este in Cluj (cart Zorilor), apartine unui prieten al meu. Rugam ajutor.Faults.txt
