nu am gasit nici un topic pe aceste probleme din acest motiv am inceput un altul,   Dupa schimbare motor au aparut ceva probleme ..masina porneste ...motorul este mai accelerat, dar in bord bujia clipeste, pedala acceleratie nu functioneaza, si am folosi un VCDS 10 parca, acestea sunt problemele care au aparut(vezi log), mentionez ca becuri frana functioneaza pe spate, dar am schimbat microintreupatorul si...acelasi lucru la diagnoza! ceva sfaturi de la cei care au mai patit!??? multumesc anticipat!   Chassis Type: 7D - VW Transporter Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56      Mileage: 352240km/218871miles ------------------------------------------------------------------------------- Address 01: Engine        Labels: 074-906-021-ACV.lbl    Part No: 074 906 021 A    Component:  2,5l R5 EDC   00SG  1909      Coding: 00002    Shop #: WSC 02760      VCID: 0E19C5CD4AB2C868A30  5 Faults Found: 00777 - Accelerator Position Sensor (G79)             27-10 - Implausible Signal - Intermittent 00539 - Fuel Temperature Sensor (G81)             30-00 - Open or Short to Plus 00522 - Engine Coolant Temperature Sensor (G62)             30-00 - Open or Short to Plus 00527 - Intake Manifold Temperature Sensor (G72)             30-00 - Open or Short to Plus 00741 - Brake Pedal Monitoring             27-00 - Implausible Signal Readiness: N/A
