Showing results for tags 'contact pornire ventilator clima'.
Salut! am o problema la masina din profil si sper sa gasesc rezolvare. Atunci cand pun contactul fara sa pornesc motorul porneste ventilatorul mic (cel de la clima) precizez ca, clima in masina e inchisa. Am facut o scanare cu vagcomu-ul si am gasit urmatoarele : Tuesday,13,December,2016,13:37:11:62939 Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.lbl 2 Faults Found: 17994 - Engine Mount Solenoid Valves (N144/N145) P1586 - 35-10 - Short to Plus - Intermittent 17664 - Engine Coolant Temp Sensor (G62) P1256 - 35-10 - Open or Short to Plus - Intermittent Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Component: ABS/ESP front 1726 Coding: 04255 Shop #: WSC 06435 VCID: E5C1D71F7F949D36875-5072 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent ------------------------------------------------------------------------------ Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00041 Shop #: WSC 01211 VCID: 3C77D27B2C9E7CFE88B-4A9C 1 Fault Found: 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0604 Coding: 00001 Shop #: WSC 00000 VCID: EBD5A1279970AB46D11-5072 2 Faults Found: 01463 - Alarm triggered by Sensor for anti-theft alarm System 43-00 - Closed 01462 - Anti-theft alarm ultra sonic Sensor (G209) 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BC Component: Komfortgerát T3B 1110 Coding: 06891 Shop #: WSC 01211 VCID: 73E539474140F386991-4A3A Subsystem 1 - Part No: 8E2959802B Component: Tõrsteuer.FS BRM 0002 Subsystem 2 - Part No: 8E2959801B Component: Tõrsteuer.BF BRM 0002 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0002 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0002 13 Faults Found: 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 00955 - Key 1 35-00 - - 01559 - Drivers Door 61-00 - Won't De-Safe 01331 - Door Control Module; Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent 01560 - Passenger Door 61-10 - Won't De-Safe - Intermittent 01332 - Door Control Module; Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent 01561 - Rear Left Door 61-00 - Won't De-Safe 01333 - Door Control Module; Rear Left (J388) 53-10 - Supply Voltage Too Low - Intermittent 01562 - Rear Right Door 61-00 - Won't De-Safe 01334 - Door Control Module; Rear Right (J389) 53-10 - Supply Voltage Too Low - Intermittent End --------------------------------------------------------------------- dupa stergerea erorilor am ramas doar cu astea 1 Fault Found: 17994 - Engine Mount Solenoid Valves (N144/N145) P1586 - 35-10 - Short to Plus - Intermittent Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BC Component: Komfortgerát T3B 1110 Coding: 06891 Shop #: WSC 01211 VCID: 73E539474140F386991-4A9C Subsystem 1 - Part No: 8E2959802B Component: Tõrsteuer.FS BRM 0002 Subsystem 2 - Part No: 8E2959801B Component: Tõrsteuer.BF BRM 0002 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0002 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0002 3 Faults Found: 01559 - Drivers Door 61-00 - Won't De-Safe 01560 - Passenger Door 61-00 - Won't De-Safe 01562 - Rear Right Door 61-00 - Won't De-Safe
