Pioneer DEH-P80MP
X-Ecutor
De 2 saptamani masina mea are un Pioneer DEH-P80MP.
Mai jos sunt specificatiile pentru 'piesa' asta :) :
Putere 4x60W,
MOSFET,
FM 24/MW 6/LW 6,
RDS,
Radio Text,
CD Text,
Memorare titluri descriptive CD,
D4Q-Sistem amplificare a semnalului radio,
CD-R, CD-RW,
Egalizator,
EEQ - Plus,
Iesire separata subwoofer,
3 preout,
CD changer control,
DAB Tuner control,
TV control,
Telecomandabil,
Intrare handsfree,
volum rotativ,
fata detasabila
CD-R, CD-RW, CD-text, MP3, WMA
Daca mai are cineva mp3 playeru asta sau cineva care l-a mai butonat: cum il mut sa scoata pe 60W?
Pentru ca acum cand rotesc butonul de volum imi arata ca e pe 40W :(.
Am incercat tot si cu manual si fara manual!
Multumesc anticipat pentru sfaturi!
Features - Audio / Amplifier DEH-P80MP
Continuous output power (DIN45324, +B=14.4 V) 4 x 36 W
Max. preout voltage (V / Ohms) 6,5
HPF Yes
LPF Yes
EEQ Plus Yes
5-mode preset equaliser Yes
Custom preset equaliser Yes
3-band parametric equaliser Yes
Source Equalisation Memory Yes
Selectable Loudness Yes
EQ-EX Yes
SFEQ (Sound Focus Equaliser) Yes
ASL (Automatic Sound Leveliser) Yes
L/R level meter Yes
Level Indicator Yes
Fader Yes
Specifications - FM DEH-P80MP
Frequency range 87,5 - 108 MHz
Usable sensitivity (75 ohms) 8 (0,7) dBf/µV
S/N ratio 75 dB
Frequency response 30 - 15.000 Hz
Stereo separation 45 dB
Specifications - MW DEH-P80MP
Frequency range 531 - 1.602 kHz
Usable sensitivity 18 µV
Specifications - LW DEH-P80MP
Frequency range 153 - 281 kHz
Usable sensitivity 30 µV
Specifications - CD DEH-P80MP
Frequency Characteristics 5 - 20.000 Hz
S/N ratio 94 dB/1 kHz
Dynamic range 92 dB/1 kHz
Specifications - General DEH-P80MP
Chassis size (W x H x D) 178 x 50 x 160 mm
nNu cred ca scoate 60W dupa spusele celor de la pioneer
http://www.pioneer.eu/eur/product_detail.j...onomy_id=25-121
Ca sa iti faci o parere referitor la puterea debitata poti sa te uti de cati amperi e siguranta de protectie de pe aparat. si P(putere)= V(tensine alimentare _--13,8V)* I^2(valorea specificata pe siguranta).
P se imparte la 4 pentru a vedea cati W corespund unui difuzor.
:) Parerea mea!
exista un swich in spatele aparatului si e valabil doar pentru CD, nu pentru Radio.
Ai grija ca se recomanda alimentarea direct de la baterie in modul 60W.
Multumesc la toti :)!
Am sa le iau pe toate la rand sa vedem ce iese!
Revin cu raspunsul!
B)-->
QUOTE(Catalin B @ Jun 22 2006, 06:19 PM) <{POST_SNAPBACK}>
nu stiam de chestia asta... :) oricum il asteptam pe x-ecutor sa vedem ce a facut
Mai intarzii putin, masina e la vopsit (spoiler spate) maine o iau si o sa verific!
LE: nu are switch in spate, cred ca pur si simplu nu scoate 60, desi pe cutie si manual scrie ca poate.
Pentru al muta pe 60W exista un swich undeva pe carcasa unit-ului care comuta intre 40-60W, dar cum a spus Catalin B ai nevoie de o alimentare mai sanatoasa pentru el. Producatorul recomanda o linie de 10Ah pe alimentare dar la mine este legat pe instalatia originala a mashini si este in modul de 60W si nu are nici o problema de vreo 8 luni.
probleme nu cred ca are, insa cand e dat al volum mai maricel nu cumva :( scade intensitatea becurilor din fata casetofonului(palpaie).
In situatia asta as recomanda folosirea unui cablu de alimentare >>mai sanatos<< de 2,5mm2 sectiune.
Nu, chiar la asta am fost si eu atent la ineput dar nu se intampla
