Resetare indicator de service (bordcomputer)
eugend
SERVICE REMINDER INDICATOR (SRI) DISPLAY
CABRIO, GOLF III, GTI, JETTA III (1993-95) JETTA (1996)
1) One of four service codes may be displayed on instrument
cluster according to mileage driven. Each service code displayed
determines type or level of maintenance required. Service code will
flash for approximately 3 seconds in odometer display window as
ignition is turned on. When servicing becomes due (every 7500 miles),
appropriate service code will flash for approximately 60 seconds. The
four service codes available for display are as follows:
* IN 00 (No Service Necessary)
* OEL (Oil Change Service) Every 7500 Miles
* IN 01 (Inspection Service) Every 15,000 Miles
* IN 02 (Additional Servicing Work) Every 30,000 Miles
2) After performing required maintenance, each effected
service code displayed must be reset individually. For example, at 15,
000 miles service codes OEL and IN 01 will both need to be reset.
3) To reset service codes, turn ignition on. Press and hold
odometer reset button located below speedometer. While holding button,
press clock reset button (lower button for digital clock) located to
left of fuel gauge. Release buttons. Programming mode is now
activated. Service code OEL1.S (distance counter) should be displayed.
4) Press clock reset button once more. 7500 miles should now
be indicated on display. Desired mileage for reset may be attained by
pressing clock reset button. Mileage displayed will decrease in
increments of 500 miles each time button is pressed. This feature
should only be used to calibrate mileage when instrument cluster is
replaced. When desired mileage is displayed, press odometer reset
button.
5) Service code OEL2.S (time counter) should be displayed.
Press clock reset button. 6 (months) will be indicated on display.
Time counter for next oil change may be set by pressing clock reset
button if instrument cluster was replaced. When desired time is
displayed, press odometer reset button.
6) Service code IN 01.S (time counter) should be displayed.
Press clock reset button. 12 (months) will be indicated on display.
Time counter for next maintenance interval may be set by pressing
clock reset button if instrument cluster was replaced. When desired
time is displayed, press odometer reset button.
7) Service code IN 02.S (distance counter) should be
displayed. Press clock reset button. 30,000 (miles) will be indicated
on display. Desired mileage for reset may be attained by pressing
clock reset button. Mileage displayed will decrease in increments of
500 miles each time button is pressed. This feature should only be
used to calibrate mileage when instrument cluster is replaced. When
desired mileage is displayed, turn ignition off. Programming is now
stored in memory.
  • Replies 84
  • eugend
    5
  • Stelian99
    4
  • FANEX
    4
  • Focusdesign 1.9 GTD
    4
Partea faina este sa setezi cu VAG-com-ul intervalele de service.
De exemplu la mine imi apare reminder-ul pt schimbul de ulei la 15000. Si eu vreau la 7.500 :x
nu se poate face asta la golf III.
VAG-COM-ul nu se poate conecta la grupul 17 Instruments.
Numai bine
Stie cineva cum se poate face treaba asta (fara VAG-COM) la un Golf IV. M-a rugat un prieten sa va intreb.
De incercat (la Passat merge):
Cu contactul scos (cheia in pozitia off) se apasa si se mentine apasat reset totalizor partial (buton dreapta). Se pune contactul si apoi se roteste butonul de ajustare al ceasului spre dreapta (sensul acelor de ceasornic) si se mentine 5 secunde. Gata cu reset-ul remind-erului service.
THX! O sa incercam, daca merge, va anunt!
PANA IN CE MOMENT SE MANTINE APASAT BUTONUL DREAPTA ?
Fata de punerea contactului si actionarea butonului din stanga.
Am resetat si eu remind-erul de service
Eugend, nu poti seta service oil la golf 3? Vezi ca folosesti si butoanele de ceas si merge.
VAG-COM are butoane de ceas? Curios... al meu n-are :censur:
Am inteles eu gresit. Credeam ca nu poate sa modifice intervalele de service din bord, de acolo. Ca mie mi le-a modificat cineva folosind butonul de trip si butoanele cu care reglezi ora. Nu ma refeream la Vag-Com :censur:
PustiulK, citeste ce a scris eugend (primul post pe pagina).
La A4 nu stii cumva cum reusesc sa fac treaba asta?
Am incercat cum ai zis tu, dar la masina mea butonul de la ceas nu se roteste (ceasul se regleaza prin tragere de buton).
Vreo idee?
eugend
merci merge, am reusit la masina din semnatura.
mi-a cerut unu 500k sa-mi reseteze ce am facut eu in 30sec ,............
merci;)
Vreo idee?
trebuie sa tragi de buton.
am verificat eu pe A4 si merge
Pe ce A4 ai incercat? (din ce an?) Concluzia mea, dupa ce am cautat pe audiworld, este ca pana in '98 (?) nu merge decat cu vag-com
La A6 merge?
Pentru resetarea servic.... se poate folosi aceeasi combinatie de taste ca la Passat?
da, poate pe un AUDI A4 fabricat dupa 2000.AM tras ieri toata ziua de buton, si tot scrie OIL cand pun contactul...:lol:
A4 din '99
Sal
Tocmai am resetat si eu service-ul la golf 3. Imi poate spune cineva cum pot face sa setez eu intervalul de km cand sa ma anunte. De ex la ulei sa ma anunte dupa 10,000 nu dupa 15,000. Shtiu ca se poate, dar nu shtiu cum, pe ce butoane sa apas.
10x.
Bordurile MotoMeter au intervalele fixe, nu se poate seta intervalul, la VDO cu butonul care l-ai resetet daca-l mai apesi vei putea seta aceste intervale.
Pai shtiu ca se pot modifica intervalele de service. Dar nu shtiu cum sa le pun, pt ca apar mai multe intervale. De ex cum fac sa imi apara oel la 10.000 de km?
Going to race!
Intervalul pentru schimbat uleiul este de 15k km la motoarele pe benzina. Just curious: de ce vrei sa-l schimbi?
