Sign in to follow this
Tiesto24
Diagnoza New Beetle
Recommended Posts
F l o r i n
incearca si cu alta interfata..
Share this post
Link to post
Share on other sites
h0m3s1ck
Salut @Petre08.
Explicatii "beton", hai sa o luam cu inceputul:
-> motor
*17925/P1517/005399: Power Supply Relay for ECU (J271 or J363): Electrical Malfunction (http://wiki.ross-tech.com/wiki/index.php/17925/P1517)
Possible Causes: Power Supply Relay for Engine Control Module (J271 or J363) faulty; Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271 or J363) fault
Possible Solutions: Check/Replace Power Supply Relay for Engine Control Module (J271 or J363); Check Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271 or J363); Check/Replace Engine Control Module (J220)
*16891/P0507/001287 - Idle Control System RPM: Higher than Expected (http://wiki.ross-tech.com/wiki/index.php/16891/P0507/001287)
Possible Symptoms: Malfunction Indicator Lamp (MIL) active
Possible Causes: Throttle Valve Control Module (J338) dirty/faulty; Wiring/Connector(s) from/to Throttle Valve Control Module (J338); Vacuum Leak
Possible Solutions: Check Throttle Valve Control Module (J338); Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338); Check Intake System for Leaks
*17978/P1570/005488 - Engine Start Blocked by Immobilizer (http://wiki.ross-tech.com/wiki/index.php/17978/P1570/005488)
Possible Symptoms: Engine starting but stalling immediately
Possible Causes: Key(s) not matched; Instrument Cluster not matched; Engine Control Unit (ECU) not matched; Engine Control Unit (ECU) Power Supply faulty
Possible Solutions: Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some); Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module); Match Key(s)/Instrument Cluster/Engine Control Unit (ECU); Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes: In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related; May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module; If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, on rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example); Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
-> Pentru radio as verifica cablurile de la boxele din spate si cablurile din mufa lui si implicit mufa pe care as da-o cu spray de contacte.
-> Legat de cheia de service din bord: eu nu am reusit sa fac SRI direct din VCDS la new beetle meu asa ca il fac intrand in [17 - Instruments], [Adaptation - 10] si in canalul 02 modific valoarea 1 in 0 (http://www.ross-tech.com/vag-com/cars/vw_sri.html)
Daca as fi in locul tau as face cum a scris mai sus @Al Bundy, adica sa sterg toate erorile si sa vad care mai apar, dupa aia as verifica bateria si cat incarca alternatorul de la masina, dupa releiele daca sunt la locul lor si daca fac contact si integritatea cablurilor (ideal ar fi ajutorul unui electrician auto bun), apoi as da jos de pe masina clapeta de acceleratie si as curata-o si i-as da mufa cu spray de contacte, as verifica admisia sa nu traga aer "fals" adica sa nu aiba fisuri sau rupturi si la sfarsit as reimperechea cheile cu imobilizatorul. Problemele tale pot sa fie de la lucruri simple adica contacte proaste, plastice si furtune crapate, pana la module de control stricate sau scurt electric undeva. La imobilizator pot sa-ti spun din experienta proprie ca am scapat doar dupa ce am reimperechiat cheile.
Spor la verificari si daca rezolvi problemele spune-ne si noua cum ai facut.
Share this post
Link to post
Petre08
Mulțumesc mult pt răspuns am sa va anunț cum am făcut dar deocamdată am șters erorile si nu au mai apărut dacă apar va anunț cât despre radio am sa verific firelesi mufa
Share this post
Link to post
Petre08
dupa ce am sters erorile de la engine i-am dat un scan si imi apare asa
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: WVWZZZ1YZ6M322359   Mileage: 95760km/59502miles
Address 01: Engine        Labels: 06A-906-033-AVU.lbl
   Part No: 06A 906 033 DP
   Component: SIMOS33 1.6l 2V 00HS9970
   Coding: 00031
   Shop #: WSC 01976
   VCID: 70EF364B3056C89E643-5072
   WVWZZZ1YZ6M322359     VWZ5Z0F1278203
No fault code found.
Readiness: 1110 1101
ce vrea sa spuna Readiness .1110 1101 va multumesc
Share this post
Link to post
Al Bundy
Inseamna ca nu ai coduri de eroare si este OK>
Share this post
Link to post
Petre08
salut baieti azi mi s-a aprins in bord becul de la airbag si imi da eroarea asta
                Address 15: Airbags       Labels: 1T0-909-605.lbl
Control Module Part Number: 6Q0 909 605 AL
  Component and/or Version: 03 AIRBAG VW71      0711
           Software Coding: 0012339
            Work Shop Code: WSC 00066 000 00000
                      VCID: 8109E38FDBFC51161BD-5072
2 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            001 - Upper Limit Exceeded
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
tin sa spun ca a aparut dupa ce am umblat pe la mufele de la boxe ca nu imi mergea pe spate si dupa ce am desfacut la boxa in spate am vazut ca era si mufa de la senzorul de prezenta care este pe plasticul de la stalp scoasa si am bagat-0 la loc va multumesc
Share this post
Link to post
F l o r i n
care mufa ai gasit-o scoasa, era cea din centura... ?
oricum, problema este din centura sofer.... acolo vezi sa fie bine bagata mufa - in centura - cea galbena.
Share this post
Link to post
Petre08
Nu era cea de la pulsantul acela din stâlp de alarma dar probabil ca am atins si pe acolo pe la centura am sa verific mersi mult
Share this post
Link to post
F l o r i n
verifica.... cel mai probabil ai deranjat mufa de la centura - verifica sa fie bine bagata, dupa care stergi eroarea. Daca nu se sterge, intareste contactele la mufa care intra in centura... si incearca iar sa stergi eroarea.
Share this post
Link to post
Al Bundy
2 Faults Found:
Verifica mufa de la centura de pe stalp.
Edited by Al Bundy
Share this post
Link to post
Bumblebeemmm
Am un New Beetle 1999, am facut un test si a dat asta de mai jos, vreau sa il repar singur asa ca orice idee mar ajuta
PS. nu sunt familiarizat cu forumu, nu prea stiu unde sa postez
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,26,February,2019,16:05:23:62939
Chassis Type: 9C - VW New Beetle (1999 > 2010)
   Mileage: 192930km/119881miles
Address 01: Engine        Labels: 06A-906-018-AQY.lbl
   Part No: 06A 906 018 AD
   Component: 2.0l R4/2V  MOTR HS V04
   Coding: 00000
   Shop #: WSC 00066
   VCID: 64C74A1BF4AE643E10B-49D8
8 Faults Found:
16806 - Main Catalyst; Bank 1
            P0422 - 35-00 - Efficiency Below Threshold
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-10 -  - Intermittent
16686 - Cylinder 2
            P0302 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
16500 - Engine Coolant Temp. Sensor (G62)
            P0116 - 35-10 - Implausible Signal - Intermittent
17708 - Misfire Detected. Probable Reason
            P1300 - 35-10 - Low Fuel - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 1J0 907 379 S
   Component: ESP     20    CAN  V010
   Coding: 00209
   Shop #: WSC 00066
   VCID: 4189A38F4B7C1116DBD-4A3A
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            35-00 - -
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 609
   Component:  D AIRBAG VW3 SG   0002
   Coding: 00068
   Shop #: WSC 00066
   VCID: ECD7A23B9C7EAC7ED8B-4A3A
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1C0-919-xx0.lbl
   Part No: 1C0 919 861 C
   Component: KOMBI+WEGFAHRS. M73 V23
   Coding: 00142
   Shop #: WSC 00000
   VCID: 29591B2FD30CF956E3D-4A3A
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0WD102062
   Ident.-Nr. Wegfahrs.:VWZ5Z0WD102062
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 5Y Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00066
   VCID: 8407EA9B94EE443E30B-4A3A
   Subsystem 1 - Part No: 1J2959802C
   Component: 5Y Tőrsteuerger. FS0001r
   Subsystem 2 - Part No: 1J2959801D
   Component: Beif. antwortet nicht
5 Faults Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
            25-10 - Unknown Switch Condition - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
            25-00 - Unknown Switch Condition
01329 - Convenience System Data Bus in Emergency Mode
            35-00 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 - -
End   ---------------------------------------------------------------------
Share this post
Link to post
piny
Le-ai sters si ai scanat încă odată?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
Important Information
Acest site folosește cookie-uri. Continuarea navigării reprezintă acceptul dvs. pentru această folosință. Pentru mai multe detalii privind gestionarea preferințelor privind cookie-uri, vedeți Politica de utillizare cookie-uri
