Upgrade CAN Gateway/Battery drain
adso
Ai incercat sa codezi RNS ca avand rear camera?
Modificat de Al Bundy
Am mai gasit ceva interesant pe Ross Tech
The Gateway (aka. Diagnostic Interface for Databus OR CAN-Gateway) is responsible for passing Messages from one Control Module to another, older versions of the Gateways were not compatible and caused the Databus to stay active even with the Ignition turned OFF which resulted in excessive Battery Draw and failure. To identify if your Gateway is compatible, check the (Software) Part Number and the Software Version of the Control Module shown in the Identification provided by VCDS (for example in an Auto-Scan).
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0178
In this Example the Software Part Number is 1K0-907-530-K and the Software Version is 0178, now check the following List if your Gateway is considered NOT compatible - all part numbers NOT listed here can be considered compatible.
Control Module Part Number Software Version Compatible Notes
1K0-907-530-A 0020 No Update available
1K0-907-530-B 0050/0070 No Update available
1K0-907-530-C 0080 No Update available
1K0-907-530-D 0100 No Update available
1K0-907-530-E 0110 No Update available
1K0-907-530-F 0120 No Update available
1K0-907-530-G 0130/0140 No Update available
1K0-907-530-H 0150 No Update available
1K0-907-530-J 0160 No Update available
1K0-907-530-K 0021 No Replacement only
1K0-907-530-K 0170 No Update available
1K0-907-530-K 0178 Yes -
1K0-907-530-P 0191/0192 No Replacement only
All Modules which Part Number has not been listed in the Table above are considered to be compatible. Those Part Numbers & Software Versions listed with the Note "Update available" can be updated to 1K0-907-530-K @ 0178, this often saves Money/Work which a Replacement of the Module would cause. The Update is NOT available in the US, all Rest of World VW (see TPI 2017949, 2018155, 2022606), Seat and Skoda Dealers should have access to it.
Modificat de Clodius
Tocmai vin de la o discutie cu un consilier service Brady care insista ca nu este nevoie sa se schimbe Can Gateway-ul ci doar sa se faca update de firmware fie la RNS fie la Gateway (sau chiar ambele)
Sa ne spui si noua cat costa update-ul la reprezentanta :D
Zicea ca undeva in jur de 100 RON, insa nu s-a uitat in calculator sa-mi spuna exact
Am facut niste poze vreau sa stiu daca pot face ca pe rns-ul meu sa vad masina cu senzori , si ce trebuie sa fac ca nu mai imi vede in bord ''Radio si Audio'' Parca erau inainte de umbla eu , acum am doar "MFD si Setup" ..Can Geteway .vag Number : 1K0 907 530 Q Current Cooding: E9817F0FC042021302
SI LA RADIO: VAG NUMBER 1Z0 035 680 A RNS-MID CURRENT cODING: 040004400001003300
post-95991-0-66090500-1327431254_thumb.p
post-95991-0-88447400-1327431263_thumb.j
Ai pornit radio ca sa afiseze AUDIO?
Si cam pe unde ai umblat in setari?
RNS stie sa afiseze optic, gateway-ul trebuie sa fie de la S in sus, si trebuie schimbata actuala unitate PDC de pe masina ta. Tu presupun ca ai RS dinainte de FL, nu ?
Da am rs , si cu radio pornit binenteles ! Nu mai stiu pe unde ....:(( ..mersi
Ma gandesc foarte serios sa cumpar cu Can Gateway nou de aici. Costa 69 EUR + 12 transportul. Se mai baga cineva la un "group buy"?
Dar tu pentru ce vrei sa cumperi nou ??
Daca te uitai cu o pagina in urma ai fi vazut ca mi-am luat o navigatie Skoda Columbus si am varianta F de Gateway ceea ce inseamna aproape sigur problema legata de descarcarea bateriei. Asadar imi trebuie o varianta mai noua.
De ce vreau nou, pt ca merita diferenta de 50-100 lei fata de una de la dezmembrari
Intreb aici : La scanare am un modul Can Gateway si nush ce e ala,ce inseamna ce face la ce foloseste???Din cate am citit in acest topic observ ca are treaba cu dotarile masinii in a le recunoaste si controla???
Am cautat si pe google dar n-am fost multumit de ce am gasit si de aceea am intrebat de specialisti...in principiu intelesesem ce e doar aveam nevoie de mai multe lamuriri o confirmare.Ms oricum.
Din pacate consilierul e posibil sa fie specialist in vanzari, nu in inginerie. In baza de update nu exista fisier de update de firmware pt CAN cu terminatia F.
Mi-am luat pana la urma 7N0 907 530 C. O sa vina peste o saptamana impreuna cu navigatia asa ca o sa le montez pe toate odata,
Am citit ca modulul ar putea fi in 2 locuri, sper sa nu-mi puna probleme gasirea lui:
1. In spatele climatronicului
2. In spatele cutiei de sigurante.
Este deasupra pedalei de acceleratie, prins de panoul lateral de la housingul climei.
Si ce anume desfac? De unde am acces la el?
Deasupra pedalierului ai o izolatie asemanatoare cu cea de la filtrul de polen.Daca o inlaturi ajungi la ce ai tu nevoie
CA sa dai aia de acolo jos, trebuie dat plasticul de sub bord, izolatia de care spui tu si conducta de aer care sufla catre picioare.
Zi-mi si mie te rog de unde ai luat can-ul si la ce bani?
Cu o pagina in urma scriam de un site din Polonia, il poti lua de acolo cu 69 EUR + 12 EUR transportul: http://www.carsystem...30ad,id285.html
Daca-mi spuneai mai inainte, eu creasem un topic si de "group buy"
Din pacate am vazut tarziu si acum trebuie sa imi caut si eu unul.
Modificat de Ph3t0n88
  • vdragos a deschis acest topic
