Update de soft motor stock
impuls
Imi puteti spune si mie daca exista update
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 997 056 M    HW: Hardware No
   Component: MED9.5.10       G00 9265
   Revision: 00000000    Serial number: VWZ7Z0D9703855
   Coding: 0000072
   Shop #: WSC 10115 599 96719
   VCID: 3777339C46B345A6659-8062
No fault code found.
Readiness: 1110 0101
Multumesc anticipat.
Zi buna.
mitubisi75: pe ECU este versiunea finala.
goguXXL: pe ECU este versiunea finala.
virgil09: pe ECU este versiunea finala.
Buna
imi poate spune cineva daca exista o versiune mai noua fata de ce am eu acum ?
Address 01: Engine(BKD)        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 HF    HW: 028 101 139 1
   Component: R4 2,0L EDC G000SG  8658
   Revision: 12345678    Serial number: SKZ7Z0D2760057
   Coding: 0000072
   Shop #: WSC 79481 150 01977
   VCID: 6ED328337962DE6E76F-803B
Nu a aparut nici un update pana acum.
Va salut, as fi interesat de o actualizare de soft pentru acest motor:
   Part No SW: 03C 906 056 BA    HW: Hardware No
   Component: MED9.5.10        00 5697
   Revision: 00000000    Serial number: VWZ7Z0D9458154
   Coding: 0000072
   Shop #: WSC 01392 785 00200
   VCID: 63CFB7CCA2AB7906E91-8036
Daca exista update, imi puteti si ce probleme ar rezolva? Mersi.
Buna ziua.pentru acest motor exista actualizare ?
2.0l R4/4V TF H08 0002
vwmkv: exista update.
becali22: e necesara o scanare motor pt. verificare.
Salut Draganuta,  imi poti spune te rog si mie despre motorul meu?
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 B    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 8831
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114016032400080000
   Shop #: WSC 44989 123 06724
   ASAM Dataset: EV_ECM16TDI02103L906023B 003007
   ROD: EV_ECM16TDI02103L906023A_VW32.rod
   VCID: 254B9A612404D2093CD-8070
48 minutes ago, Iceheat said:
Exista 9971.
Eu am 9972 pe CAYC...
Imi puteti spune si mie va rog daca exista update? Va multumesc!
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 CA
   Component: SIMOS71 1.6l 2V     5755
   Revision: --H04---    Serial number: VWZ7Z0D0700337
   Coding: 0000071
   Shop #: WSC 00923 233 62364
   VCID: 60CF460BB3B6781EF43-8035
kollaristvan91
Salut Draganuta,
pentru acest 1.4 BCA, ai informatii despre vreun update?
Address 01: Engine       Labels: 036-906-032-AXP.lbl
Control Module Part Number: 036 906 032 BA    HW: xxxxxxxxxxx
Component and/or Version: BOSCH ME7.5.10  G   7292
Software Coding: 0000071
Work Shop Code: WSC 01279 785 00200
VCID: 50BA52275AE3C682CF40A65-8004
Iti multumesc!
image.jpegBuna seara.pentru acest motor exista actualizare?
Pe masina este ultima versiune de soft.
clau_vw_tdi
Va deranjez si eu cu o intrebare ?  La ce ajuta update-ul software ?  Multumesc anticipat
kollaristvan91
Cărui post ai adresat răspunsul?
becali22: Pe masina este ultima versiune de soft.
kollaristvan91: Exista update.
Salut baieti.
Mi-ati putea ajuta si pe mine cu un raspuns.
Am tot auzit in stanga si in dreapta de updaturi la soft si imbunatatirea performantelor masinii si m-am gandit sa incerc si eu.
Datele masinii sunt:
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 CN
   Component:  MARELLI 4MV       3957
   Coding: 00031
   Shop #: WSC 47163
   VCID: 60CF460BE0B6781EF43-4A9C
   WVWZZZ1JZ2W130629     VWZ7Z0A3770368
Pt. motorul tau, exista update de software.
Ms mult.
Asta se poate face exclusiv la reprezentanta sau se poate încerca si la service uri autorizate mai mari?
P.S. imi poti da si nr de update? Nu de alta dar să fiu sigur că pune ultima versiune. Weekend plăcut.
Exista un update pentru motorul meu? Și un număr de update ca sa verific la reprezentata dacă e acela. Mulțumesc :)
Revin :
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 PM    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  1136
   Revision: --H07---    Serial number: VWX7Z0GD3NJ9FM
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 79F311AC309683F7BE-802C
Readiness: 0 0 0 0 0
Exista o versiune mai noua?
1.9 TDI BXE
Stie cineva care ar fi diferentele intre variantele de soft 2472 si 6213 la un CFFB?
Buna!
Exista vreun update de soft pt datele de mai jos ?
Masina: Skoda Octavia  1.6 CAYC motor.
