kadettro
Probleme MMI
Recommended Posts
gabryell_08
Stie cineva cum pot sa fac un upgrade la Hartile pentru Navi MMI(cu 2 slot SD) - pentru A6 model C7 2012?
Share this post
Link to post
Share on other sites
bZ1
E un coleg aici pe forum care face, cauta in aria comerciala.
Share this post
Link to post
skalari77
Salutare! De curand m-am facut proprietar pe un Audi A6 4B din 2004 si ne avand cunostinte suficiente despre sistemul de navigatie nu ma descurc cu el.Cineva care se pricepe daca mi-ar da niste sfaturi legat de acest subiect ,as multumi frumos. As dori sa stiu cat mai multe despre aceasta dotare a masinii, ce anume poate sa faca si ce ii lipseste. Atasez si niste poze.
post-163559-0-25457000-1453036497_thumb.
post-163559-0-65639300-1453036497_thumb.
post-163559-0-80345900-1453036497_thumb.
  • Upvote 1
Share this post
Link to post
svg_gabriel10
Va salut! Imi poate spune cineva ce tip de MMI are masina diagnosticata (Audi A6 3.0 din 2005) si ce versiune/model de harta trebuie? Colegul meu vrea sa faca update la harti dar nu ne dam seama ce CD/DVD sa cautam si ce versiune...in functie de SW/FW de la aparat.
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 4F0 910 401 L    HW: 4F0 907 401 A
   Component: 3.0L V6TDI  0000AG  0040
   Revision: --H01---    Serial number:
   Coding: 0011772
   Shop #: WSC 02334 785 00200
   VCID: 254BE9D4EC1FC736C75-8070
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 C
   Component: MNS ECE         H43 0850
   Revision: 00000000    Serial number: 353IY047566941
   Shop #: WSC 02335 785 00200
   VCID: 3B7F2FAC7A9B61C6811-806E
No fault code found.
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBD6014177
   Shop #: WSC 00000 000 00000
   VCID: 1C3DCC30DF5506FE68B-8049
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 G    HW: 4F0 035 223
   Component: Amp.-ASK        H09 0350
   Revision: 15S00001    Serial number: 00109040024332
   Coding: 0000008
   VCID: 2241F2C8FD31300EA27-8077
Share this post
Link to post
26amg
Salutare tuturor. As veni cu o intrebare..  De o saptamana am achizitionat un audi a6 (s6 b4) motor de 1.9 din 2003.. si as vrea sa schimb casetofonul cu un dvd, dar locasul este mic. Intrebarea este ... se poate face vreo modificare ca sa intre un dvd cu gps si mp3 sau unele modele au locasul mai mare. Modelul meu este ca si a colegului Skalari77 (din pacate nu am poze deoarece sunt plecat de 2 zile din oras si abia ma intorc in (4 -5 zile). Iar am gasit un model asemanator ca si a meu dar acesta are in plus butoanele de la scaunele incalzite dar are si un dvd. (A 2 poza este modelul exact ca si a meu)
Edited by 26amg
atasare poza
Share this post
Link to post
F l o r i n
Da, se poate face trecearea la 2 Din.
Share this post
Link to post
26amg
Adica la 2 Din ??explic,ami te rog sa inteleg(sunt pe din afara cu acesti termeni)
Share this post
Link to post
Alex123
Salut , am si eu o problema . La un audi A6 C7 sa stins Navigația si consola , nu mai merge nimic , nici muzica nimic din mmi si display-ul este stins si nu mai coboară jos . Din ce cauza a rămas asa ? Daca stie cineva unde sa ma îndrume . Înainte sa se întâmple asta am facut curat înăuntru . Va mulțumesc
Share this post
Link to post
26amg
salutare. as aveni cu o intrebare... (am schimbat radioul masini cu un rns-d iar cand am bagat codul pin mi.a scris safty pin not conected... ma.m documentat si am observat din alte discuti ca trebuie sa alimentez pinu safe cu 12+ asa am si facut iar rns-d a mers.. dar problema este ca luminile de la butoane nu se aprind deodata cu cele de la clima.. nu se aprind deloc.. ma.m interesat din discuti si tot asa am vazut ca trebuie sa montez o mufa extra )de unde pot eu sa montez aceea mufa... sacum ar trebui sa o leg? tot cu un fir +12v? este vb de mufa incercuita cu rosu
Share this post
Link to post
F l o r i n
ala e pin, nu mufa - il iei de la un buton iluminat, fir gri/albastru
Share this post
Link to post
26amg
multumesc frumos de raspuns florin.
acuma am ajuns acasa si cand sa ma uit la culorile pinurilor am asa....
tel mute- albastru cu maro
gala - alb cu verde
s kont - rosu gros
k bus - verde cu albastru
la safe - am tras plus de langa el
si mai am soarele ala mic care lipseste.. defapt am mentionat....
de unde sa trag fir ca nu am gri cu albastru... multumesc frumos de ajutor
Share this post
Link to post
F l o r i n
orice buton iluminat, din bord - sau de la butonul de lumini
Share this post
Link to post
26amg
am reusit.... am legat firu albastru cu gri de la esp... multumesc frumoa de ajutor
Share this post
Link to post
snake17
Buna seara,
Astazi dupa ce m-am urcat in masina, am pornit motorul, s-a aprins displayul si mi-a aparut bootloader version 2.31 MMI (H43) si numai pot face nimic. Stiti cumva cum pot rezolva aceasta probllema? Am uitat, audi a6 c6 3000tdi 2005
Va multumesc frumos.
Share this post
Link to post
lucaflo26
Tre sa il scoti din recovery
Share this post
Link to post
Cristian2006
On 7/23/2010 at 10:46 PM, Costel Diaconu said:
Stie cineva cu se reactiveaza comenzile de pe volan? la un Audi A6 din 2005 sa facut update de soft la versiunea 5570, totul functioneaza ok dar nu mai merg comenzile de pe volan si nu gasesc in meniul MMI-ului nimic despre acestea.
Astept cu nerabdare un sfat util.
Salut,tu cum ai activat comenzile pe volan?aceeași chestie am pățit și eu si nu-i dau de capăt.ms
Edited by Cristian2006
Share this post
Link to post
Minzatu
Am și eu o problema cu navigatia, am luat borna plus și după ce am pus-o la loc nu s-a mai aprins navigatia, nici luminile pe consola, nici la magazia  de cd din torpedou.
Edited by cogdao
Scrie corect gramatical, fara prescurtari gen messenger.
Share this post
Link to post
F l o r i n
Verifica întâi siguranțele. Dacă sunt ok, fa un test cu vcds ul pe fibra optica, sa vedem unde este problema
Share this post
Link to post
Domini24
Salut! Am si eu o problema la Navigatia MMI Audi a6 din 2006. Am mers astazi cu masina toata ziua si a mers sistem MMI Radio/cd/ etc. Dupa o jumatate de ora ( stationare) cand am pornit masina nu s-a mai aprins ecranul... Am apasat buton de pornire a Navigatiei MMI, se aprinde imi apare Audi MMI si pe urma ( nu pourma) se inchide la loc. Poate sa ma ajute cineva in legatura cu asta?
Share this post
Link to post
cogdao
O scanare ai facut?
Share this post
Link to post
F l o r i n
Trebuie verificat si fizic, posibil la scanare sa nu vezi modulele
Share this post
Link to post
Whisky
Posted (edited)
On 2/7/2013 at 5:39 PM, usexpert said:
Va salut, va rog mult am aceiasi problema am un audi a6 2005 am facut update la 5570 si nu mai merg comenzile la volan. daca este cineva care ma poate ajuta va multumesc foarte mult.
va salut, va rog mult daca are cineva o solutie care sa ma ajute sa repar comenzile la volan dupa ce am facut update la 5570 nu mai merg. daca la leg cu vag com la el si apas pe ele ca si semnal vad ca fac ceva dar nimic volum , mod etc. va multumesc foarte mult
Salut. A gasit cineva rezolvare pentru aceasta problema ? Multumesc frumos.
Edited by Whisky
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
Important Information
Acest site folosește cookie-uri. Continuarea navigării reprezintă acceptul dvs. pentru această folosință. Pentru mai multe detalii privind gestionarea preferințelor privind cookie-uri, vedeți Politica de utillizare cookie-uri
