cata19
Calculator coloana, grup manete, volan comenzi compatibil cu airbag ul de Tiguan si cablaj volan multifuncțional
Spira nu trebuie ? Sau e calculator direct cu spira ? Un cod compatibil ?
Calculator cu tot cu spira. Corp comun, la modelul tau.
5k0....AL, AP, H, L...etc
Ai o lista completa aici, aloca timp pentru studiu http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
5K0-953-569-AL
We received e-mail feedback specific to 5K0-953-569-AL related to rejected Byte 02, Bit 0 "Electronic Steering Column Lock (ESCL) installed (PQ46 only)" coding. This module does not appear to be factory installed in 3C/35 chassis models with PQ46 ESCL and may NOT be compatible resulting in DTC: 02823 - Requirements for Locking the Steering Column Lock not met.
There's a (NAR market) 2017 (5N) Tiguan Limited without CCS horror story related to factory installed Part No SW: 5K0 953 501 CL HW: 5K0 953 569 AJ module. That SW# was dropped by VW and replacement HW# 5K0-953-569-AL modules have incompatible software with the TCM. The VW "fix" to resolve P1867/18275 - Powertrain Data Bus - Missing Message from Steering Wheel (J527) is located in post #49:
ce vrea sa zica la codul asta de spira ?
Salutare , recent m-am decis sa schimb volanul de la Tiguanul meu ( 1.4 TSI 170hp soft) , momentan am prima varianta de volan cu comenzi , si maneta de CC.
Am gasit un volan la 1200 ron ( probabil il iau cu 1000) complet , care are CC pe volan, si intrebarea mea este daca e nevoie si de altceva ca sa fac acele butoane sa mearga pe langa codare, multumesc.
@alexmr  Raspunsul pentru intrebarea ta il aveai mai sus in topic , pag 1 daca citeai  :
On 12/19/2022 at 1:50 PM, Al Bundy said:
CAlc de coloana highline cu lin 2.0 , cablaj de airbag pentru MFSW, volan multifunctional, airbag si codare.
Buna ziua,
Pentru acest retrofit se poate folosi cablaj msw varianta montata pe Tiguan 5N 2008? Sau trebuie alt cod de cablaj? Daca da, ma puteti ajuta cu un cod? Multumesc mult
Nu, nu se potriveste.
Daca iti cumperi volan cu calc comenzi in bratul din stanga, ai nevoie de 3c8 971 584F.
Versiunea de volan cu calc jos, in dreptul bratului central, ai nevoie de 5k0 971 584A
Multumesc mult pentru informatii
Dnu Florin, am inteles ideea, insa am o intrebare suplimentara. Am volan model mai nou cu calc comenzi in bratul central jos. Cablaj trebuie strict doar codul 5k0 971 584A sau merge si cu D(ultima versiune din ce am aflat) Acest volan are deja cablaj cu C, si nu se potriveste. Multumesc inca odata
Incarca poze cu volanul si cablajul, te rog
Nu am poza cu eticheta de la cablaj. Dar are codul 5K0 971 584C
Trebuie sa mearga cu un cablaj de Golf 6, etc. Deci 5k0....C...este compatibil. Mai nou, adica de Golf 6, Tiguan 1 FL, etc.
Daca masina ta este non facelift, cu ceasurile vechi (iluminare albastra cu rosu), ai nevoie de calculator de coloana cod 1k0 953 549 CH... CJ...sau CK (acesta merge doar pe masina cu cv manuala).
In rest,  volanul, cablajul - sunt codurile ok.
  • 5 months later...
Salut am primul volan cu 8 comenzi și doresc sa îl schimb cu al doilea, ce trebuie sa achiziționez pe langa volan. Mulțumesc
calculator de coloana care sa stie de lin 2.0, volan, airbag si cablaj.
Ce an este masina ta?
An 12.2009. Mulțumesc
F l o r i n
Fa o scanare sa vedem ce calculator de coloana ai. E posibil sa fie compatibil
Salut asta ajuta??
Adresa 16: Electronica volan        Etichete: ROJ\1K0-953-549-MY9.lbl
   Numar VAG SW: 1K0 953 549 CK    HW: 1K0 953 549 CK
   Component: J0527           056 0111
   Codare: 0000132
   Atelier: WSC 01324 020 00200
   VCID: 7DF14CF324F16765E9-8028
   Subsistem 1 - Numar VAG: XXXXXXXXXXX
   Component: E0221           002 0030
F l o r i n
Ai noroc, calculatorul tau de coloana suporta LIN 1.3 si LIN 2.0. Montezi volanul, codezi calc coloana pe Lin 2.0 si o sa mearga comenzile noului model de volan
Mulțumesc frumos!!!
