Problema Xenon Leon 1P
pity98
Salut baieti , de ceva vreme intampin probleme cu xenon`ul. In prima instanta s`a ars un bec , si le`am schimbat pe amandoua evident .. sa nu fie diferente de nuanta sau eu mai stiu . Becurile sunt Philips (pe ele scrie made in Germany) .. nu stiu cat de Germany sunt , ca dupa 3 saptamani unul a inceput sa palpaie in mers. Din cele 2 becuri ce le`am avut intitial , cel ars l`am aruncat si cel bun l`am pastrat ca o rezerva ( si e China !) . Le`am tot schimbat intre ele , dar numai cele noi cumparate imi fac figuri (si in prezent merg cu cel de "China" fara probleme), nu palpaie nu nimic pe orice parte l`as pune .. stanga/dreapta . Dar acum a inceput sa imi palpaie si becul din bord precum ca am o eroare . Am pus VCDS si mi`au aparut urmatoarele erori :
Address 55: Xenon Range       Labels: 5M0-907-357-V2.LBL
Control Module Part Number: 5M0 907 357 A    HW: 5M0 907 357 A
  Component and/or Version: AFS-Steuergeraet    0001
           Software Coding: 2555909
            Work Shop Code: WSC 01629 995 98234
           Additional Info: 7L6941329A  AFS-Lst.-Modul l    0002   7L6941329A  AFS-Lst.-Modul r    0004
                      VCID: 326BFC43ADDABA8E527-8067
4 Faults Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
            007 - Short to Ground - MIL ON
             Freeze Frame:
                    Fault Status: 11100111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 189002 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:52:03
             Freeze Frame:
                    Voltage: 14.34 V
                    Speed: 0.0 km/h
                        ABS 1
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 189002 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:52:03
             Freeze Frame:
                    Voltage: 14.34 V
                    Speed: 0.0 km/h
                        ABS 1
02630 - Voltage Supply for Swivel Module Position Sensor; Right
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 189002 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:52:13
             Freeze Frame:
                    Voltage: 14.06 V
                    Speed: 0.0 km/h
                        ABS 1
02628 - Sensor for Swivel Module Position; Right
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 189002 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:52:13
             Freeze Frame:
                    Voltage: 14.06 V
                    Speed: 0.0 km/h
                        ABS 1
As avea cateva intrebari ... cat de grava e situatia ? cat de costisitoare ? dar foarte mult m`ar interesa sa stiu daca pot renunta la xenon de tot si sa folosesc becuri normale H7 , dar fara sa schimb tot farul .. sa imi ramana asa cu lupa cum e acum .. pentru ca nu am de gand sa dau cate 400-500 ron pe 2 becuri periodic . Multumesc !
verifica conectica care o ai la far - calculator - etc - problema pare sa nu fie de la bec. Sterge erorile si posteaza numai ce ramane
Astea au ramas dupa ce am sters erorile .. sunt cele care persista ..
Banuiesc ca ai schimbat becul direct pe masina..nu ai demontat farul.De cele mai multe ori se produc alte probleme cand se lucreaza asa,spatiul fiind f strimt..
Cum a zis si Florin-verifica conector, cablajele din far..
Da .. am schimbat becul fara sa demontez farul .. dar interesant e ca la inceput a mers cat a mers , dupa aia a luat`o razna de tot cu erorile de mai sus . O sa caut un electrician si cumpar alte becuri daca e nevoie . Dar o alternativa , gen sa trec pe H7 fara a renunta la lupa .. doar la xenon ? sau ceva "adaptoare" de la D1S la H7 ? .. ca am vazut cate ceva pe internet , forumuri ... dar nimic concret pentru Seat ...
Modificat de pity98
Implica mai multe modificări, inclusiv la far. Sincer, alții plătesc sa treacă la xenon oem... Iar tu, sa scapi de el? Eu zic sa o repari asa cum trebuie..... E păcat de asemenea mașina.
Inteleg . O sa caut un electrician sa o scot la capat cumva . E clar ca am fost si sunt foarte multumit de xenon , dar de la un bec ars sa apara atatea complicatii .. ☺️
Nu e de la becul ars....
Exista posibilitatea sa pun kit de xenon chiar daca am de fabrica?nu o mai scot la capat cu farul acela..si nici nu am electricieni straluciti aici..farul e cu lupa,mai multe persoane mi'au spus ca daca e montat cum trebuie nu ar trebui sa am probleme. Astept orice sfat..ca astia deja mi'au spus ca trebuie sa schimb farul ..trebuie sa existe o alternativa.... Multumesc
Modificat de pity98
  • 6 months later...
Stie careva sa imi spuna care este numarul sigurantei responsabile de AFS ?multumesc
Buna ziua
Trebuie sa înlocuiesc becul xenon pentru ca a început sa pâlpâie și sa se stingă uneori dar când opresc și repornesc farurile se aprinde iar (asta e semn ca e pe ducă, nu?). Îmi apare și in bord semnul de bec dar uneori dispare.
Va rog sa ma ajutați cu un sfat sau îndrumare.. Unde as putea găsi ce bec se potrivește exact pentru modelul de mașina Seat Altea 2006 2.0 TDI 103 kW?
Am văzut ca sunt multe coduri și criterii și nu știu unde as putea afla care se potrivește pe mașina mea care are instalație de far dublu xenon.
Am găsit de cumpărat becul acesta pe net.. oare se potrivește?
https://www.emag.ro/bec-xenon-d2s-35w-4300k-pentru-far-oe-vag-vw-audi-seat-skoda-85122/pd/DB9ZBVBBM/?X-Search-Id=daef601fb826244c03fe&X-Product-Id=36004082&X-Search-Page=1&X-Search-Position=3&X-Section=search&X-MB=0&X-Search-Action=view&ref=
Dar mai sunt și altele la 50-60 de lei.. aștept recomandarea voastră ☺️
Multumesc anticipat ?
Numai original sau Philips, Osram, etc
Esti sigur ca becul e de vina? Incearca sa schimbi becurile intre ele. Cumperi in functie de soclu. Daca ai soclu d2s atunci doar acest tip de bec cumperi. Marca? In functie de buget.
în urmă cu 2 ore, AlexW8 a scris:
...mașina mea care are instalație de far dublu xenon...
Problema imediata pe care o vad este ca in ETKA, pentru anul 2006 nu exista Altea echipata cu dublu xenon (faza lunga si scurta).
Ai grija sa nu ai lupe montate in faruri, daca colegul spune ca nu exista altea echipata cu dublu xenon, atunci vei avea surpriza ca sunt H1 becurile (in proportie de 90%). :)
