contact pornire ventilator clima
alex_gafita
Salut! am o problema la masina din profil si sper sa gasesc rezolvare. Atunci cand pun contactul fara sa pornesc motorul porneste ventilatorul mic (cel de la clima) precizez ca, clima in masina e inchisa. Am facut o scanare cu vagcomu-ul si am gasit urmatoarele :
Tuesday,13,December,2016,13:37:11:62939
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
Address 01: Engine        Labels: 038-906-019-AVF.lbl
2 Faults Found:
17994 - Engine Mount Solenoid Valves (N144/N145)
            P1586 - 35-10 - Short to Plus - Intermittent
17664 - Engine Coolant Temp Sensor (G62)
            P1256 - 35-10 - Open or Short to Plus - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04255
   Shop #: WSC 06435
   VCID: E5C1D71F7F949D36875-5072
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            35-10 - - - Intermittent
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 01211
   VCID: 3C77D27B2C9E7CFE88B-4A9C
1 Fault Found:
00532 - Supply Voltage B+
            53-10 - Supply Voltage Too Low - Intermittent
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   Shop #: WSC 00000
   VCID: EBD5A1279970AB46D11-5072
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
            43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1110
   Coding: 06891
   Shop #: WSC 01211
   VCID: 73E539474140F386991-4A3A
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0002
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
13 Faults Found:
01134 - Alarm Horn (H12)
            49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
00955 - Key 1
            35-00 - -
01559 - Drivers Door
            61-00 - Won't De-Safe
01331 - Door Control Module; Driver Side (J386)
01560 - Passenger Door
            61-10 - Won't De-Safe - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01561 - Rear Left Door
01333 - Door Control Module; Rear Left (J388)
01562 - Rear Right Door
01334 - Door Control Module; Rear Right (J389)
End   ---------------------------------------------------------------------
dupa stergerea erorilor am ramas doar cu astea
1 Fault Found:
   Coding: 06891
   Shop #: WSC 01211
   VCID: 73E539474140F386991-4A9C
3 Faults Found:
Modificat de alex_gafita
Salut. Am schimbat senzorul G62 si problema a fost rezolvata. Binenteles am avut batai de cap cu acea clama de plastic care a pocnit la scoatere si garnitura care am pierdut-o in scut :). Recomand cand schimbati senzorul G62 sa faceti comanda la el cu tot cu garnitura si clama. Multumesc!
Alex, cele de la Hella vin cu oring si clema de fixare, in cutie.
cele OEM vin fara - asa cum recomanzi si tu, cumparati si oringul si clema de fixare, plus antigel si apa distilata - pentru completare.
  • 5 months later...
Ma ajutati si pe mine? Nu gasesc ce reprezinta eraoarea de la ventilatorul de clima :
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Coolant Fan Control Module (J293) faulty
Coolant Fan Control Module faulty
Engine Control Module Power Supply Relay (J271) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Coolant Fan Control Module (J293)
Check Coolant Fan Control
Perform Output Test
Check/Replace Coolant Fan Control Module (J293)
Check Activation Signal with Ocilloscope
Check Engine Control Module Power Supply Relay (J271)
Only applies if the Coolant Fan is running with Engine cooled down and Ignition OFF until Battery is drained
Special Notes
When found in Audi A3 (8P), the complete Coolant Fan may need to be replaced. Detailed Instructions and Repair Information can be found under Recall 19D8 (2004439).
