Recensamant Golf/Vento mk3!
ByZ
Ce Golf / Vento aveti?
165 voturi
  1. 1. ...Motorizare?
    • 1.4 60 CP
      19
    • 1.6 75 CP
      40
    • 1.6 100 CP
      8
    • 1.8 75 CP
      21
    • 1.8 90 CP
      31
    • 2.0 115 CP
    • 2.0 150 CP
      4
    • 2.8 174 CP
      2
    • 2.9 190 CP
      0
    • 1.9 D 64 CP
      3
    • 1.9 TD 75 CP
      6
    • 1.9 TDI 90 CP
      22
    • 1.9 TDI 110 CP
      2
  2. 2. ...Varianta de echipare?
    • CL
      76
    • GL
      44
    • GLX ( Vento)
      4
    • GT
      18
    • GTD
      3
    • GTI
      16
    • VR6
      4
  3. 3. ...Golf/Vento?
    • Golf
      150
    • Vento
      15
  4. 4. Caroserie Golf...
    • Hatchback 2 usi
      47
    • Hatchback 4 usi
      89
    • Variant
      17
    • Cabrio
      2
am votat si eu :D
eu nu am sigur acea eticheta. se pot afla in alt fel datele care erau scrise pe ea ?
si...despre ce capac la roata de rezerva e vorba? ca eu nu am...sau doar unele au ?
  • Replies 70
  • GTI_85
  • mihuz
    6
  • ByZ
    5
  • eleet
    5
datele care sunt trecute pe eticheta le gasesti si in programul ETKA. :)
la mine eticheta e lipita pe o laterala a banchetei (stanga) :blink:
Golf 3 Europe - 1994 Tdi 90Cp - 1Z
Am decodat serile trecute pe eticheta din portbagaj (marcate cu bold), restul serilor sunt decodate cu ETKA(in care se gasesc inclusiv cele trecute pe eticheta). Daca imi permiteti un sfat: atentie la fiecare litera/cifra gresita se modifica total semnificatia seriei.
A8D = Luxury equipment
B01 = Type approval Germany
B0A = Component parts set without country-specific design requirement
C5Y = Alloy wheels 8J x 18
E7G = Golf GL "Europe"
F0A = No special purpose vehicle, standard equipment
G0C = 5-speed manual transmission
H4V = Tires 175/70 R14 88H
J0N = Battery 330 A (61 Ah)
K8G = Hatchback
L0L = Left-hand drive vehicle
M2K = 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIand MVEG 2 base engine is T2F
N2L = Fabric seat covering "Speed" leather bolsters
Q1W = Standard front seats with integrated storage trays
S6G = Region
T2F = 4-cylinder diesel engine 1.9 L unit 028.C
U0C = Instrument insert with tachometer clock and km/h speedometer
V0F = CONTINENTAL tires
0A2 = 4 doors
0AB = Front stabilizer
0DG = Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
0FA = Standard manufacturing sequence
0G4 = Cable gearshift
0KZ = Stickers for special editions
0MA = Without label for starting an automatic
0N2 = Heavy-duty rear axle
0Q0 = Without label for brake-proportioning values
0RA = Without ignition/starter switch locking system
0TA = Without floor mats
0Y1 = Standard climatic zones
1AC = Anti-lock brake system (ABS)
1BA = Standard suspension/shock absorption
1C1 = Antifreeze up to -25 degree celsius tolerance up to -30 degree C
1D0 = Without trailer hitch
1E0 = Without activated charcoal canister
1EC = Special identification plate
1G6 = Space-saving spare wheel
1H1 = Load-sensitive proportioning valve
1K2 = Hydraulic clutch actuation
1KB = Drum brakes, rear
1LL = Disc brakes, front
1N1 = Power steering
1NG = Wheel center cover and wheel trim ring
1SA = Without additional engine guard
1TB = Fuel tank vent line with gravity valve and PVC breather hose
1WB = Transmission shafts w/ 100 mm in diameter
1X0 = Front wheel drive
1Z0 = Initial standard fuel filling2B5 = Additional exterior noise suppression
2C1 = Height adjustable steering column
2D0 = Without cd enhancing underbody panel
2E0 = Base chassis
2G0 = Without insert for the filling up of fuel
2JE = Partially painted bumpers
2LA = Fuel tank without special material treatment
2P1 = Plastic trunk sill protection
2PY = Steering wheel for air bag system (RoW) (lightweight design)
2QV = Nameplate set "GL TDI"
2V1 = Dust and pollen filter
3AF = Right exterior mirror: convex, electrically adjustable and heated
3B0 = Without additional child seat anchor
3BS = Left exterior mirror: aspherical, electrically adjustable and heated
3C1 = Static lap belt, center rear
3CA = Without partition
3FE = Electric slide/tilt sunroof with sun screen/sunblind
3GA = Without cargo area
3H0 = Without backrest release for front seats
3J7 = Articulated and height-adjustable headrests for front seats
3L1 = Manual height adjustment for left front seat
3M0 = Without special measures
3NC = Rear seat bench/backrest, split folding
3P1 = Bracket for first aid kit and warning triangle
3Q1 = Rear headrests
3QC = 3-point seat belts, front
3S0 = Without roof rails/roof load rack
3U1 = Foldable trunk cover
3W0 = Without additional noise suppression measures for passenger compartment
3YH = Door pockets, front
3ZE = 3-point seat belts, outer rear with height adjustment and ECE label
4A0 = Without seat heater
4AF = Door and side trim panel in foam film and woven fabric
4B1 = Protective side molding
4E0 = Tailgate/trunk lid unlocking from outside
4F1 = Central locking system
4GF = Windshield in heat-insulating glass
4J1 = Floor tray, extension center console
4KC = Side and rear windows in heat-insulatingglass
4N1 = Padded dashboard
4Q0 = No flame retardent materials
4R1 = Power windows
4SA = Without left vanity mirror
4TB = Vanity mirror right
4UE = Air bag for driver and front seat passenger
4V0 = Without front passenger seat adjustment from the rear
4W0 = Without cassette and CD storage unit
4YB = Stowage box rear (door and side panel)
4Z0 = Without glove compartment/door, without trays
5AZ = code not found :-(
5C0 = Without special body measures
5J0 = Without rear spoiler
5K0 = Without surface protection, with additional transit coating
5L1 = Front spoiler
6B0 = Without tie-down eyes for load restraint
6EA = Without additional side body covers (stone guard)
6FE = Body-colored exterior mirror housings and tailgate handle
6KA = Radiator grille
6NA = Unsplit molding roof liner
6P1 = License plate bracket rear (ECE)
6PA = Plastic hand brake lever handle
6Q4 = Comfort gearshift knob/handle
6R3 = Rubber gearshift boot
6SC = Tufted trunk floor covering
6Y0 = Without cruise control warning system
6Z1 = Yellow turn signal lights
7A0 = Without CD changer/CD player
7AD = Anti-theft alarm system and passenger compartment control
7E3 = Sheathed type glow plug heater
7L0 = Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
7Y0 = Without lane change assistant
8A0 = Park distance control, front and rear with rear view camera
8AB = Radio "alpha"
8BB = Halogen headlight for driving on the right
8CC = Speedometer sensor without seal (electronic speedometer sensor)
8E5 = Local interference suppression for FM radio reception
8F2 = Side turn signal lights
8GL = Alternator 120 A
8K0 = Without special headlight activation
8KA = W/o catalytic converter warning light
8L1 = Bright rod antenna
8M1 = Rear window wiper and washer system with intermittent control
8N2 = Windshield wiper intermittent control infinitely variable
8PB = Ashtray light
8Q1 = Headlight-range adjustment
8QC = Key with light
8RD = 2 speakers (passive)
8S1 = Reading light front
8SA = Taillight assemblies, standard design
8T0 = Without cruise control system (CCS)
8TC = Rear fog light for driving on the right
8WA = Without front fog light
8X0 = Without headlight washer system
8Y1 = Two-tone horn
9A0 = Without taxi alarm system
9AA = Manually controlled heating system
9D0 = Without preparation for two-way radio installation
9E1 = Luggage compartment lighting
9F0 = Without sound combination for rotating emergency light and radio antenna preparation
9FA = Without automatic transmission indicator light
9J0 = Without supertone system and tone sequence control
9P0 = Without seat belt reminder
9Q0 = Without multi-function display/ on-board computer
9R0 = Without night vision system
9T1 = Heated washer nozzles, front
9TA = Without additional warning lights
9U0 = Without brake pad wear indicator
9W0 = W/o car phone preparation/installation
X0A = National sales program Germany
Modificat de eleet
Golf 3 1998 1.6 gt 101caluti de mare AKS Cabrio Karmann
Dotari Fabrica-servo
-4 x geam el
-Abs integral
-2x airbag
-oglinzi el si incalzite
-faruri el
-volan reglabil
-inchidere centralizata cu ridicarea automata a geamurilor
-decapotare electrica
-scaune sport Recaro din fabrica
Cam astea sunt cele vizibile de mine :icon_thumright:
nu ar trebui sa lipseasca din masina ,asa cum spune si amadeo ,dar la altele am vazut-o lipita sub cuiul de la portbagaj
Subscriu , la mine e sub incuietoarea de la portbagaj !
GOLF 1.8GL
X2B = National sales program Great Britain
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
C1V = Steel wheels 5.5J x 13 Offset 38
H2L = Tires 175/70 R13 T
J1P = Battery 220 A (44 Ah)
M59 = 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, cat. conv. a. MVEG 2/EU 3Dbase engine is T5C
1AB = Power brake
1ME = Steering wheel
1NF = Wheel center cover and wheel trim ring
3AV = Right exterior mirror: aspherical, electrically adjustable and heated
3BF = Left exterior mirror: convex, electrically adjustable and heated
T5C = 4-cylinder gasoline engine 1.8 L unit 051.2
3UI = Seat preparation SCS
0G3 = Gearshift linkage
8GM = Alternator 70 A
1LM = Disc brakes, front
-mai are si 4 geamuri electrice dar nu apare codul pe eticheta:|
r3sp3ct
wv mk3 bon jovi 1,8 55kw
abs,clima,recaro,geamuri electrice fata,oglinzi si faruri electrice,
geamuri cu tenta verzui
deeeeeeci:
vento GT 1.8i 90cp fab dec 1993
aer conditionat, oglinzi electrice incalzite, volan si scaun reglabil pe inaltime,(am 1.90 deci sunt grozave) proiectoare ceata MFA discuri spate duze incalzite jante, servo faruri electrice geamuri cu tenta inchisa si daca ar fi sa comparam cu lista de dotari de la logan mai am plafoniera dubla si manete de viraj :blink:
Modificat de omu_negru84
Golf 3 1.8 55kw hatchback 5 usi 1994 edition ''Savoy'' varianta de echipare GL
Dotari:
*A/C manual
*ABS
*oglinzi el. si incalzite
*faruri cu reglaj electric
*duze incalzite
*volan reglabil
*scaun sofer reglabil pe inaltime
*bancheta fractionara 1/3, 2/3
*proiectoare ceata
*airbag sofer + pasager
*servo
*geamuri cu tenta verde
Modificat de catalin_ucc
arici nastase
#golf 3,an 1992,1.9 TD,servo,scaune recaro,trapa electrica si cam atat :)
Daca nu puteți vota (Primul pas), va rog nu mai postați pentru ca nu se mai poate realiza sondajul.
Modificat de taz21
Pff...eu nu pot vota :) Imi da eroare.
salllllllllll
Golf 3 variant 2.0 116cp
Dotari:
ABS
Servo directie
Aer Conditionat
2 airbag-uri
4 geamuri electrice
Oglinzi electrice incalzite
Scaune recaro
Scaun sofer reglabil pe inaltime
Volan reglabil
Faruri reglaj electric
cititi mai sus...primul pas.... :D
An fabricatie : 05.1997
Motor : 1.6 benzina ,101 cai.
Nr km : 174 k .
Provenienta : Germania
Inmatriculata Ro.
Culoare : rosu aprins
Caroserie : 5 usi.
Dotari :
- Aer conditionat
- Inchidere centralizata cu telecomanda
- ABS
- 2 airbag-uri
- Geamuri electrice fata
- Interior GTI
VW VENTO GL
1.9 TDI 66kw/90 CP
an fabricatie 1996
inmatriculata Ro
2 airbag
culoare rosu inchis...cam atat.....foarte multumit de ea..... ;)
Golf GTI 2.0 16v 150 CP - Hatchback/4 usi
An Fabricatie: 1995
AC Manual - urmeaza update la climatronic
Computer bord
4 Geamuri Electrice
Inchidere centralizata + Telecomanda
ABS
Separat am montat faruri cu angel eyes + semnale clare in bara fata + triple clare spate (alb/rosu)
masina are stock suspensii sport, este foarte rigida dar foarte manevrabila in acelasi timp, o adevarata jucarie pt copii mari
Acizitie recenta 10.04.2010:
VW Golf 3 variant 1,9 TDI 90 CP
Echipare Trendline
fabr. 07.1997
alb
Km 362.000
Dotari:
A/C manual
Jante aliaj OEM 14"
Inchidere centralizata vacumatica
ABS
2xAirbag-uri frontale
Servodirectie
Urmeaza (sper):
BC+CC
Volan de piele si interior de piele.
