Et-ul Si J-ul
  • Please log in to reply
1049 replies to this topic
#21 Rapier
Rapier
    Membru senior
  • Oraş:Bucureşti
  • Maşina:Audi
  • Model:A4 B6(8E) 2004 (AVF)
  • Motorizarea:1.9TDi >131CP
Posted 22.03.2007 @ 09:41
Se pare ca nu s-a inteles... J-ul NU ESTE NICI O DIMENSIUNE, reprezinta profilul interiorului jantei si a muchiei acesteia
J, JJ, K, JK, B, P and D : Tyre bead profiles / rim contour designations.
Posted Image No, my keyboard letters weren't stuck down when I typed this. The letter that typically sits between the rim width and diameter figures stamped on the wheel, and indicates the physical shape of the wheel where the tyre bead meets it. In the cross-section on the left you can see the area highlighted in red.
Like so many topics, the answer as to which letter represents which profile is a long and complicated one. Common wisdom has it that the letter represents the shape. ie. "J" means the bead profile is the shape of the letter "J". Not so, although "J" is the most common profile identifier. 4x4 vehicles often have "JJ" wheels. Jaguar vehicles (especially older ones) have "K" profile wheels. Some of the very old VW Beetles had "P" and "B" profile wheels.
Anyway the reason it is an "awkward topic to find definitive data on" is very apparent if you've ever looked at Standards Manual of the European Tyre and Rim Technical Organisation. It is extremely hard to follow! There are pages and pages (64 in total) on wheel contours and bead profiles alone, including dimensions for every type of wheel you can think of (and many you can't) with at least a dozen tabled dimensions for each. Casually looking through the manual is enough to send you to sleep. Looking at it with some concentration is enough to make your brain run out of your ears. To try to boil it all down for you, it seems that they divide up the rim into different sections and have various codes to describe the geometry of each area. For example, the "J" code makes up the "Rim Contour" and specifies rim contour dimensions in a single category of rims called "Code 10 to 26 on 5deg. Drop-Centre Rims". To give you some idea of just how complex / anal this process is, I've recreated one such diagram with Photoshop below to try to put you off the scent.
Posted ImageFrom the tables present in this manual, the difference in dimensions between "J" and "B" rims is mainly due to the shape of the rim flange. This is the part in the above diagram defined by the R radius and B and Pmin parameters. Hence my somewhat simpler description : tyre bead profiles.
Note that in my example, the difference between "J" and "B" rims is small but not negligible. This area of rim-to-tire interface is very critical. Very small changes in a tyre's bead profile make large differences in mounting pressures and rim slip.
"A" and "D" contour designations come under the category of "Cycles, Motorcycles, and Scooters" but also show up in the "Industrial Vehicles and Lift Trucks" category. Naturally, the contours have completely different geometry for the same designation in two different categories.
The "S", "T", "V" and "W" contour designation codes fall into the "Commercial Vehicles, Flat Base Rims" category. The "E", "F", "G" and "H" codes fall into the "Commercial Vehicles, Semi-Drop Centre Rims" category. Are you beginning to see just how complex this all is?
I think the best thing for you, dear reader, is a general rule-of-thumb, and it is this : if your wheels are stamped 5J15 and you buy 5K15 tyres, rest assured they absolutely won't fit.
  • 0
#22 razdan
razdan
    Membru Senior
  • Oraş:Iaşi
  • Maşina:VW, Seat
  • Model:G5, Leon
  • Motorizarea:2.0TDI & 1.8TSI
Posted 22.03.2007 @ 19:59
O mica observatie referitoare la J in cazul discutat. De fapt pentru o latime a anvelopei de 225mm, 7,5 si 9 reprezinta limitele intre care se poate situa J; deci pe jante 7,5J, sau 8J, sau 8,5J sau 9J putem monta anvelope cu latimea 225.
  • 0
#23 speedo
speedo
  • Oraş:Bacău
  • Maşina:Volkswagen
  • Model:Sharan Trendline
  • Motorizarea:1.9 TDI
Posted 23.03.2007 @ 18:40
Este aici undeva mai in josul paginii un calculator care spune ca poti pune 225mm de la 6J pana la 7,5J. Ce ziceti stiti un calculator mai bun? Difera aspectul estetic sau amprenta la sol a unei anvelope de 225 montata pe 6J fata de una identica montata pe 7,5J ?
  • 0
#24 razdan
razdan
    Membru Senior
  • Oraş:Iaşi
  • Maşina:VW, Seat
  • Model:G5, Leon
Posted 23.03.2007 @ 18:56
Pai nu, in postul pe care l-ai citat integral (nu se face asa cu postul precedent) scrie clar ca limitele pentru 225 sunt intre 7,5 si 9. Nu era vorba nicaieri de valori mai mici cum ar fi 6.
Daca o sa montezi o anvelopa de 225 pe o janta J6 o sa difere in primul rand siguranta, care o sa scada dramatic: Anvelopa va avea tendinta sa iasa de pe janta in viraje stranse, si chiar daca nu iese, tinuta de drum va fi deplorabila, anvelopa fiind foarte deformabila in lateral si amprenta la sol va fi probabil mai mica daca o sa faci presiunea mare si ... evident mai mare, dar nu eficienta daca scazi presiunea ...
  • 0
#25 speedo
speedo
  • Oraş:Bacău
  • Maşina:Volkswagen
Posted 23.03.2007 @ 19:16
Scuze pt quote-area postului respectiv,asta n-am mai stiut-o. Totusi ti-as fi recunoscator daca mi-ai da un link catre sursa de unde ai luat aceste date cu limitele pt 225 :strict intre 7,5J si 9J. Ma intereseaza pt ca vreau sa-mi iau jante pt anvelope de 225 inclusiv pe fata si cu un ET care sa le scoata putin in afara. Am observat ca arata f.bine asa pe masini ca a mea.
  • 0
#26 razdan
razdan
    Membru Senior
  • Oraş:Iaşi
  • Maşina:VW, Seat
  • Model:G5, Leon
Posted 23.03.2007 @ 19:37
Intra pe linkul pe care l-ai pus si tu (carbible), fa un "Find in page" pentru "An ideal rim-width calculator", introdu in calculatorul de acolo 225/45R17 si apasa pe butonul Click to calculate rim size.
Vei obtine cifrele pe care ti le-am spus: 7,5 up to 9.
  • 0
Michelin Romania
#27 speedo
speedo
  • Oraş:Bacău
  • Maşina:Volkswagen
Posted 23.03.2007 @ 21:00
Corect dar pe mine ma intereseaza 225/55R16 nicidecum 225/45R17 asa ca se schimba datele problemei. Iar pt 225/55R16 obtin 6x16 up to 7,5x16 .Tu ai spus "in cazul discutat" si atunci ai dreptate pt ca te refereai la ...45R17. DAR totusi cum vine asta :guma de 225 cu R16 merge pusa pe 6J (luam doar valorile minime ale J-ului) si guma de 225 cu R17 nu merge decat pe cel putin 7,5J ? Pai ce,la R16 dispare riscul pe care l-ai mentionat cu virajele? De-aia intrebam daca mai stii alt calculator de genu' asta.
  • 0
#28 razdan
razdan
    Membru Senior
  • Oraş:Iaşi
  • Maşina:VW, Seat
  • Model:G5, Leon
Posted 23.03.2007 @ 21:44
Attached File  plusone.gif   9.67KB   943 downloads
Ca si comparatie, orientativ, poti sa iei exemplul cu anvelopele de 16" fata de cele de 17" din poza anexata si luata din acelasi link.
Pana acum nu am stiut ca doresti jante de 16", nu ai spus.
R16 e mai mic cu un inch decat R17, inch care se regaseste in inaltimea talonului, mai mare cu 1/2 inch la anvelopele R16. Aceasta diferenta de inaltime, deci acest talon mai inalt (height/width = 0,55 fata de H/W=0,45) la anvelopele pe 16" face ca anvelopa mai inalta sa permita o janta J6 fara sa mai existe riscul de iesire de pe janta.
Datele oferite de calculator sunt corecte deci si in cazul tau: 225/55R16 merg jante de 16" 6J.
Oricum rotile 225/55R16 au o raza cu 10 mm mai mare ca rotile 225/45R17 si ar trebui sa vezi daca sunt intr-adevar recomandate pentru modelul tau.
Daca vrei un calculator pentru compararea diametrelor si a taloanelor, foloseste Miata.net Tire Size Calculator
  • 0
#29 bbm
bbm
    Membri Seniori
  • Oraş:Bucureşti
  • Maşina:Seat
  • Model:Leon Cupra R / BAM
  • Motorizarea:225 CP
Posted 23.03.2007 @ 22:41
asa stiam si eu
  • 0
#30 Robert27
Robert27
  • Oraş:Zalău
  • Maşina:VOLKSWAGEN
  • Model:GOLF IV/VARIANT/2001
  • Motorizarea:1.9TDI 90CP ALH
Posted 01.06.2007 @ 23:45
Buna baieti.
As avea nevoie de ajutorul vostru..Am gasit niste jante second hand la 330 euro setul care-mi imi cam fac cu ochiul. Problema e ca nu stiu daca se vor potrivi la Golf-ul meu:m-am uitat pe interior de unde mi-am notat urmatoarele:9JX16 H2 LK100 ET15 (de ET15 nu sunt 100% convins). Prinderea este in 5 suruburi. Intrebarea mea este nu e cam ingust un cauciuc (sunt montate si cauciucurile) de 205mm (205/55/16) pentru latimea jentii? Si nu o sa am probleme mai incolo cu rulment, bucse, directie?
jantele seamana f mult (daca nu-s cumva identice) cu cele din linkul http://www.rh-alurad.de/indexen.html modelul AD CUP pe 16 pentru VW Golf 4.Din pacate nu am inteles mai nimic din ce scria acolo in germana :icon_thumright: Nu am reusit sa i-au linkul direct oricat am incercat...
Va multumesc anticipat
  • 0
#31 Ratonul
Ratonul
  • Oraş:Bucureşti
  • Maşina:Volkswagen
  • Model:Passat 2003
  • Motorizarea:2.8
Posted 06.07.2007 @ 13:54
am niste jante 7J x 15 offset 37 cu cauciucuri 205/60/15 .. si vreau sa-mi iau 7,50x17 ET37/44. pot avea surprize sa nu se potriveasca? si ce cauciucuri imi trebuie sa nu se modifice viteza ? 215/?/17
  • 0
#32 R Z F
R Z F
  • Oraş:Bucureşti
  • Maşina:vw
  • Model:mk4
  • Motorizarea:2.0 i
Posted 06.07.2007 @ 14:38
225/45r17 sau 205/50r17. http://www.miata.net...e/tirecalc.html ,uite aici sa-ti calculezi singur,insa ia ca referinta 195/65r15(dimensiunea standard,originala) nu 205/60r15.
Edited by R Z F, 06.07.2007 @ 14:43.
  • 0
#33 Ratonul
Ratonul
  • Oraş:Bucureşti
  • Maşina:Volkswagen
  • Model:Passat 2003
  • Motorizarea:2.8
Posted 08.07.2007 @ 14:45
ms R Z F. dar pt niste jante 8Jx18 ET37 care sunt cauciucurile ideale? ca latime ma refer 205,215,225 ? si daca masina din fabrica are 195x65/15 exista posibilitatea sa atinga pe acolo fiind mai late sau sa suprasolicit servo?
Edited by ratonul, 08.07.2007 @ 14:50.
  • 0
#34 R Z F
R Z F
  • Oraş:Bucureşti
  • Maşina:vw
  • Model:mk4
  • Motorizarea:2.0 i
Posted 08.07.2007 @ 19:47
225/40r18,asta este dimensiunea recomandata de producator, poti pune fara probleme.vezi ca sunt colegi care au sau au avut dimensiunea asta,vorbeste cu ei.
  • 0
#35 Ratonul
Ratonul
  • Oraş:Bucureşti
  • Maşina:Volkswagen
  • Model:Passat 2003
  • Motorizarea:2.8
Posted 09.07.2007 @ 14:15
ok ms mult. cine are 225/40r18 poate scrie aici diferentele fata de stock-ul 195/65/15 ? manevrabilitate,demaraj,viteza,merge mai greu volanul,eventuale probleme?
  • 0
#36 pmi
pmi
  • Oraş:Bucureşti
  • Maşina:Skoda
  • Model:Octavia Tour
  • Motorizarea:1.9 TDI AXR
Posted 18.07.2007 @ 11:21
Atentie, un ET mai mic inseamna stabilitate mai mare (jantele mai in exterior) dar diametrul de bracaj va fi mai mare.
  • 0
#37 ovi_HGR
ovi_HGR
  • Oraş:Târgu Mureş
  • Maşina:Volkswagen
  • Model:Touran
  • Motorizarea:1.9TDI 105CP+
Posted 29.08.2007 @ 18:44
Stie cineva daca se potriveste o anvelopa de 205/55 R16 pe o janta 7.5j de 16? Din cate am inteles janta e mai lata decat anvelopa cu 1 cm.
  • 0
#38 R_a_z_v_a_n
R_a_z_v_a_n
    Moderator senior
  • Oraş:Slatina
  • Maşina:VW Passat
  • Model:B5.5 2004
  • Motorizarea:AVB 101+ CP
Posted 29.08.2007 @ 19:23
Ia uite aici .
LE: Trebuie sa fie intre 5,5 si 7.
Edited by razvancutitoiu, 29.08.2007 @ 19:26.
#39 ovi_HGR
ovi_HGR
  • Oraş:Târgu Mureş
  • Maşina:Volkswagen
  • Model:Touran
Posted 29.08.2007 @ 20:27
Mersi, m-am "luminat"... Acuma ori cumpar anvelope, ori schimb jantele... :P
  • 0
#40 ovi_HGR
ovi_HGR
  • Oraş:Târgu Mureş
  • Maşina:Volkswagen
  • Model:Touran
Posted 30.08.2007 @ 09:01
Din linkul de mai sus reiese ca nu se potriveste o anvelopa de 205 pe o janta de 7.5J.
Insa producatorul OZ (conform catalogului lor) spune ca se potriveste...
Sunt curios cum va arata anvelopa pe janta respectiva. :)
  • 0
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
