ALEXIO
Sfat achizitionare VW New Beetle
2 postări în acest subiect de discuţie
Salutare!
Am o mica nelamurire cu privire la achizitionarea unui VW New Beetle, an fabricatie 1999, cod motor ALH, cu 102k km la bord. Am facut astazi o scanare la masina cu un vag-com si am asa:
Monday,01,February,2016,11:03:34:52379
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
VIN:    License Plate: BEETLe
Chassis Type: 9C - VW New Beetle (1999 > 2010)
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
Address 01: Engine        Labels: 038-906-018-AGR.lbl
   Part No: 038 906 018 AP
   Component: 1,9l R4 EDC 0000SG  2124
   Coding: 00002
   Shop #: WSC 00066
   VCID: 64CC5248F497241EF5-4B00
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 1J0 907 379 S
   Component: ESP     20    CAN  V010
   Coding: 00241
   Shop #: WSC 00066
   VCID: 4182BBDC4B4551363E-4B00
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 609
   Component:  D AIRBAG VW3 SG   0002
   Coding: 00068
   Shop #: WSC 00066
   VCID: 6CDC3A681C476C5EBD-4B00
Address 17: Instruments        Labels: 1C0-919-xx0.lbl
   Part No: 1C0 919 861 A
   Component: KOMBI+WEGFAHRS. M73 V23
   Coding: 00142
   Shop #: WSC 00332
   VCID: 27560544C5218F0610-4B00
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0X1161410
   Ident.-Nr. Wegfahrs.:VWZ5Z0X1161410
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 5Y Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00066
   VCID: 040C72C814D7841E55-4B00
   Subsystem 1 - Part No: 1J2959802C
   Component: 5Y Tőrsteuerger. FS0001r
   Subsystem 2 - Part No: Steuerger
   Component: t Beif. antwortet nicht
3 Faults Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
            25-10 - Unknown Switch Condition - Intermittent
01332 - Door Control Module; Passenger Side (J387)
            49-00 - No Communications
01135 - Interior Monitoring Sensors
            36-10 - Open Circuit - Intermittent
End-------------------------(Elapsed Time: 04:39)--------------------------
despre address 46 central conv stiu despre ce e vorba, mai exact macaraua de pe partea dreapta a cedat iar respectivul umreaza sa o repare zilele ce urmeaza. nelamurirea mea este in privinta adresei 17, mai exact a instrumentelor de bord. Mi s-a parut suspect sa imi apara mesajul No Faults Found, or DTCs not supported by controller, or a communication error occurred. Se poate sa se fi schimbat clusterul? am incercat sa citesc si KM din Applications> read edc15-16 mileage, insa nu am putut sa flu nimic. masina arata bine din punct de vedere vizual si trage bine.
0
Distribuie această postare
Link către postare
deci sa te linistesc la fel apare si la mine pe canalul 17 (new beetle 2001, km nu-i pot citi nici eu, testat cu 2 clone si un ross tech original eu am acum 330k, acum pe bune daca masina aia are 107k in bord o cumpar, km reali nu-i poti citii chiar daca diagnoza reuseste sa citeasca din edc15 eepromul lui se poate rescrie deci naspa, cel mai bine duo la un mecanic si uita-te sub ea si dupa la vw sa-ti zica ceva istoric despre ea. fostul proprietar ma gandesc ca era ca mine 01135 - Interior Monitoring Sensors 36-10 - Open Circuit - Intermittent si-a scos sezorii ca avea caine deci probabil stia cu ce se mananca masina aia.
0
Link către postare
