passat b5 1.9 TDI
Martor abs ramas aprins
5 postări în acest subiect de discuţie
Salut, am si eu o mica problema. Am fost la un "meserias" sa imi fac o scanare cu vag-ul si nu stiu de ce l-a mancat in _ _ _ sa dea un test de abs si astfel masina sa-mi ramana in "01486 - system function test activated". Am facut testul de strada cum am citit in alt topic si nimic. Daca ma puteti ajuta cu o idee ceva, va multumesc anticipat. -Golf V 1.6 FSI cod motor BAG-
0
Distribuie această postare
Link către postare
Eroare ta :
01486 - System Function Test Activated
Possible Symptoms
  • ABS/ESP non-functional
Possible Causes
  • System Function Test not performed
Possible Solutions
  • Perform System Function Test (see vehicle specific diagnostic procedures for details
 Si  rezolvarea :
daca ai   bosch  :
ESP System Function Test
Notes
  • The ESP road test serves to check the plausibility of the signals from the lateral acceleration sender, rotation rate sender and pressure sender.
  • It should always be carried out after removing or replacing any parts of the ESP system.
  • It is not possible to cancel the ESP road test after it has been started. The complete test procedure must be performed.
Pre-Conditions
  • ABS/EDS Warning Light (K47) ON and ASR/ESP Indicator Light (K86) ON.
  • Engine RUNNING.
  • Vehicle standing.
Instructions
  • Press brake pedal firmly until the ASR/ESP Indicator Light (K86) goes OFF. A brake pressure of at least 35 bar needs to be reached for this.
  • Start road test (Do this on an enclosed site or make sure to drive according to traffic regulations).
  • Make a right turn, then a left turn (or vice versa). A rotation rate (turn rate) of ~10 °/s must be reached while driving these turns.
  • The ABS/EDS Warning Light (K47) should now went OFF.
  • A common example for turns like this is driving turns with a radius of 10 to 12 meters (30 to 40 feet) with a speed of 15 to 30 kph (9 to 18 mph).
  • The ABS, EDS, ASR and ESP functions may NOT get activated during these test.
  • Doing other maneuvers between the turns will have no influence on the ESP System Function Test.
daca ai conti/teves  :
Notes
Pre-Conditions
  • ABS Warning Light (K47) ON and ASR Indicator Light (K155) OFF.
  • Engine RUNNING.
  • Vehicle standing.
Instructions
  • Press brake pedal firmly until the ASR Indicator Light (K155) goes ON. A brake pressure of at least 35 bar needs to be reached for this.
  • The ABS Warning Light (K47) should now went OFF.
Modificat de misulikkk
0
Link către postare
... tot meseriasul   trebuia sa remedieze problema - a dat Output test pe ABS ..... acum, trebuie finalizata procedura si eroarea va disparea - martorii se vor stinge.
... interfete - clone - pe toate drumurile, sa stim sa le utilizam corect, acolo-i baiul.
0
Link către postare
 Da..
0
Link către postare
