Showing results for tags 'vw new beetle'.
  • Căutare după etichete
  • Căutare după autor
Tipul conţinutului
Forum
  • Generale
    • Lucruri generale
    • Legislatie & asigurari
  • Tehnic
    • Volkswagen
    • Audi
    • Seat
    • Skoda
    • Performance & Technical
  • Comunitate
    • Masina mea
    • Intalniri vwforum.ro
    • Social
  • Administrativ
    • Below the line
  1. Salutare! Am o mica nelamurire cu privire la achizitionarea unui VW New Beetle, an fabricatie 1999, cod motor ALH, cu 102k km la bord. Am facut astazi o scanare la masina cu un vag-com si am asa: Monday,01,February,2016,11:03:34:52379 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 15.7.3.0 (x64) Data version: 20151216 www.Ross-Tech.com VIN: License Plate: BEETLe Chassis Type: 9C - VW New Beetle (1999 > 2010) Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-018-AGR.lbl Part No: 038 906 018 AP Component: 1,9l R4 EDC 0000SG 2124 Coding: 00002 Shop #: WSC 00066 VCID: 64CC5248F497241EF5-4B00 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ESP-F.lbl Part No: 1J0 907 379 S Component: ESP 20 CAN V010 Coding: 00241 Shop #: WSC 00066 VCID: 4182BBDC4B4551363E-4B00 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl Part No: 1J0 909 609 Component: D AIRBAG VW3 SG 0002 Coding: 00068 Shop #: WSC 00066 VCID: 6CDC3A681C476C5EBD-4B00 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1C0-919-xx0.lbl Part No: 1C0 919 861 A Component: KOMBI+WEGFAHRS. M73 V23 Coding: 00142 Shop #: WSC 00332 VCID: 27560544C5218F0610-4B00 Subsystem 1 - Part No: Ident Component: Nr. Wegfahrs.:VWZ5Z0X1161410 Ident.-Nr. Wegfahrs.:VWZ5Z0X1161410 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.lbl Part No: 1J0 959 799 AH Component: 5Y Zentral-SG Komf. 0001 Coding: 00257 Shop #: WSC 00066 VCID: 040C72C814D7841E55-4B00 Subsystem 1 - Part No: 1J2959802C Component: 5Y Tőrsteuerger. FS0001r Subsystem 2 - Part No: Steuerger Component: t Beif. antwortet nicht 3 Faults Found: 01483 - Control Circuit for Rear Lid Remote Unlocking 25-10 - Unknown Switch Condition - Intermittent 01332 - Door Control Module; Passenger Side (J387) 49-00 - No Communications 01135 - Interior Monitoring Sensors 36-10 - Open Circuit - Intermittent End-------------------------(Elapsed Time: 04:39)-------------------------- despre address 46 central conv stiu despre ce e vorba, mai exact macaraua de pe partea dreapta a cedat iar respectivul umreaza sa o repare zilele ce urmeaza. nelamurirea mea este in privinta adresei 17, mai exact a instrumentelor de bord. Mi s-a parut suspect sa imi apara mesajul No Faults Found, or DTCs not supported by controller, or a communication error occurred. Se poate sa se fi schimbat clusterul? am incercat sa citesc si KM din Applications> read edc15-16 mileage, insa nu am putut sa flu nimic. masina arata bine din punct de vedere vizual si trage bine.
