Configurare din vag-com
bebeko
Buna, astept cu nerabdare noua mea achizitie - o skoda fabia elite, 1.2 htp -, si as dori sa aflu ce se poate configura din vag com . Masina are si inchidere centralizata + telecomanda + alarma oem. Am inteles ca se poate configura semnal sonor la activare/dezactivare alarma, inchidere automata usi ,etc. Dar altceva ?
  • Replies 84
  • bebeko
    11
  • Al Bundy
    8
  • Shushu
    6
  • F l o r i n
    5
Iata cateva adaptari care se pot face cu VAG-COM pe autoturismele Fabia:
* 1 Coding
* 2 Adaptation
[edit]Coding
* 00016 = Central Locking without Power Windows
* 00064 = Central Locking with 2 Power Windows (Front)
* 00256 = Central Locking with 4 power Windows (Front & Back)
* +00 = 2-Door with Selective (Single) Door Locking active
* +01 = Selective (Single) Door Locking inactive
* +02 = 4-Door
[edit]
Adaptation
Here are some more Fabia ECU settings that can be programmed with VAG-COM. they come from OpenObd.org (Babelfish translated from German, but some parts really quite unclear).
I have used some of the coding - changed country code, adjusted the highway flashers and the default wipers. However, my usual disclaimer applies.
Cheers
Bas
{electrical system}
STG 09 (electrical system) select
STG coding - > function 07
Coding number (basis): 000000
+00016 - 4-tuerige execution
+00128 - heatable outside mirrors
+01024 - Tail cover remote unlocking remote operated
+08192 - Rear windshield wiper with comfort circuit
+16384 - Control electrical washer pump
Controller adjustment
STG Login - > function 11 Note: Before the adjustment a Login has to take place.
Login code: 21343
STG adjustment - > function 10
- > channel 001 (clamp 30G)
30G clamping wedges – withdrawal??????
Range of values: 1-253 = 0,66-173 min/
Default value: 44 = 30 min
- > channel 002 (heated windshield)
Disconnection time of the heated windshield.
Default value: 29 = 20 min
- > channel 003 (heated outside mirror)
Disconnection time of the heated outside mirrors.
Default value (to 04/02): 29 = 20 min
Default value (starting from 05/02): 254 (without disconnection)
- > channel 004 (heated back window)
Disconnection time of the heated back window.
- > channel 005 (boot remote unlocking)
Time of the remote button press for boot remote unlocking.
Range of values: 1-254 = 0.32-81.6 s
Default value: 3 = 1 s
- > channel 006 (comfort-flash)
Number of flashing cycles for comfort flashers (highway)
Range of values: 0 - 5
Default value: 3
- - > channel 007 (wiping wash mechanism)
Number of wipes on spray.
- Range of values: 0 -?
Default value: 5
{combination instrument}
Controller coding
STG 17 (combination instrument) select
??xxx: Extra options and optional extras
+00 - no extra options
+01 - Brake lining wear announcement
+02 - Seat belt warning
+04 - Wiping water level warning
+08 - does not occupy
+16 - Activation clock in MFA
xx?xx: Country selection
0 - Germany (D)- metric 24hr
1 - Remainder of the world (RdW) ???
2 - THE USA (US)-imp
3 - Canada (CDN)- metric –12hr
4 - Great Britain (GB)-
5 - Japan (JP)-metric
6 - Saudi Arabia (SA)- metric –24hr- Speed chime at 120km/h
7 - Australia (OUT) – metric
- > channel 30 (tank fuel sensor adjustment)
The base value is 128 now can it in 1 ohm steps adjust, the respective maximum values is 120 and/or. 136.
- > channel 50 (going away barrier)
Login for the adaptation of the going away barrier, combination instrument to the engine expensive equipment. (??)
{comfort system}
Controller coding
STG 46 (comfort system) select
Central Locking (4-window):
00258 - Single door opening
00259 - Total door opening
- > channel 03 (auto-LOCK)
The vehicle is locked at a speed of 15km/h (0 = OFF; 1 = ON).
- > channel 04 (auto-UNLOCK)
The vehicle is locked at a speed of 15km/h and unlocked after to taking out the ignition key (0 = OFF; 1 = ON).
- > channel 05 (interior monitoring disconnection)
Connection of starting from of the interior monitoring with twice operate of ZV (0 = OFF; 1 = ON).
- > channel 06 (unlocking horns)
Unlocking is confirmed with a short acoustic signal (0 = OFF; 1 = ON).
Needs factory alarm
- According to legislator in Germany not certified.
- > channel 07 (locking device horns)
Locking is confirmed with a short acoustic signal (0 = OFF; 1 = ON).
- Needs factory alarm
- > channel 08 (unblocking flashing)
The turn signals are operated when unlocking (0 = OFF; 1 = ON).
- > channel 09 (bolting device flashing)
The turn signals are operated when locking (0 = OFF; 1 = ON).
- > channel 10 (alarm horn)
Land tuning of the alarm horn (1 = remainder of the world; 2 = Germany; 3 = GB).
Affects kind, length and volume of the alarm tone (legal guidelines consider).
x??xx: ESP (electronic stability program)
Note: Over this place it is specified whether the guidance assistance has its own guidance angle sensor, or whether via CAN from the ESP will receive the signal.
01 - no ESP 12 – ESP xxx??: Program type
10 - Normally (heavy vehicles)
30 - Comfort (heavy vehicles)
40 - Normally (light vehicles)
50 - Comfort (light vehicles)
60 - Mobility assistance
ECU/Convenience Unit Coding Options
Many functions can be enabled or disabled with a readily available special cable and VAG-COM software.
A common problem on Fabia's is that the motorised ventilation flaps stick. This can sometimes be reset using VAG-COM as follows. A symptom of this is that the temperature will differ from what you expected or set on the dashboard controls.
[select]
[08 Heater/A.C]
[04 Basic Settings].
Select channel 000 and let it run until the numbers stop moving, select channel 001and repeat then channel 002 and repeat. The incrementing numbers mean the flap is moving from one stop to the other. Should at the end read 0. Login again and clear any fault codes.
Other handy features are -
ANTI HIJACK
[select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Adaptation - 10]
Channel 03 to 08 (Depending Options Below)
Adaptation Value (1 = on, 0 = off)
[save]
Channel 03 Auto Lock
Channel 04 Auto Unlock
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Lock, turn signals flash
Remember to do a scan of the module on each one to find out what each channel is, prior to making any changes as some cars beep is channel 7, not channel 6.
SINGLE DOOR UNLOCK
[select]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the existing Soft. Coding. If you have selective unlocking (Meaning you press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
So, if you have a car that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
POWER STEERING WEIGHT
[select]
[44 - Steering Assist] (from Chassis tab)
[Recode - 07]
Take note of the value which is in the form 0001x1 where x is the weight setting, eg 000121
If x is set to 1, it will be very light, if it is set to 5 it will be heavy
Replace the number with the required weight, eg 000151
[Do It!]
HEADLAMP ADJUSTMENT: (Xenon only)
[select]
[55 - H. Light Range]
[basic Settings - 04]
Set channel to "000"
[Do It!]
Wait about 20 seconds
Manually adjust headlamps
[Done, Go back]
EGR DISABLING
With the engine warmed up and running at idle in neutral with all major accessories such as air conditioning turned off, connect the scan tool cable and start the scan tool software.
[01 - Engine]
[Login - 11] and enter 12233 as the access code
[Adaptation] and go to block 3.
Give the accelerator pedal a quick "blip" to ensure that the EGR remains turned on for the next minute while you perform the following steps.
Note that the display shows a default adaptation value of 32768 and shows approximately 250 +/- 20 mg/stroke of air intake volume.
If all is well, enter 33768 as the new adaptation value, and select "test". Note that the displayed air intake volume changes, usually to about 370 mg/stroke. The specification limit is 370 mg/stroke, so if you want to remain within OEM shop manual specifications for emission control reasons, you might have to enter a number slightly smaller than 33768. (If you don't care about road-legal NOx emission limits then leave it at 33768. [Depending on the usage cycle, NOx at this setting can be increased by as much as 40%]) If all is well and you have a setting that you are happy with which results in an intake air volume of 370 mg/stroke or just a hair less, enter [save]. The values aren't exactly the same, but when you enter the value 33768, the ECU will automatically adapt it. In my case it was something like 33628. 370mg/stroke is what your looking for.
Si unde se pot face aceste adaptari? Fara sa strice si setarile deja existente.
Pe o masina de test :lol:
:screwy:
oricine are vag com te poate ajuta, numai sa te duci cu setarile listate
Ma intereseaza blocarea-deblocarea usilor. Parca mi se pare mai frumoasa optiunea "channel 04" din ceea ce am inteles eu usile se blocheaza la 15 km/h si se deblocheaza automat atunci cand scoatem cheia din contact.
De exemplu daca am pe cineva in spate si trebuie sa-l las intr-un anumit loc, poate sa deschida usa tragand de dispozitiv de doua ori sau trebuie sa opresc motorul si sa scot cheia din contact? Sau merge si altfel? Sau mai bun ar fi "channel 03"? Masina are inchidere centralizata si cred ca a fost pusa after-sale. Acum daca apas pe butonul de la geam se blocheaza toate usile si daca deschid de la mine se deschid toate.
trebuie facute ambele setari 03/04 daca vrei, desigur, ambele functii. :P
oricare dintre usi, se deschide la aII-a actionare a manetei.
Exista 2 "moduri" de incuiere: simpla si dubla.
  • Incuierea simpla este cea pe care o faci apasand butonul de inchidere de pe usa soferului, sau la 15 km/h avand setarea facuta. Asta iti permite ca la prima tragere de maner la una din usile din fata sa se descuie toate usile, urmand ca apoi sa poti deschide oricare usa. La usile din spate, la prima tragere se deblocheaza DOAR usa respectiva, la a doua tragere plutand sa o deschizi.
  • Incuierea dubla este cea din telecomanda de pe cheie sau din broasca daca nu ai pe cheie telecomanda, asta practic blocand manerele interioare. Poti sa tragi de ele pana le rupi, nici o usa nu se va descuia si nu se va deschide.
Sal, si-a facut cineva din modul confort sa se ridice geamurile cand ti apasat 2 secunde pe incuiat(din telecomanda) ?astept un raspuns,ms.
Aceasta operatiune NU se poate face cu vag-com ci doar cu vds-pro. Asta daca ai telecomanda din fabrica.
da...dar eu am incercat la un prieten"riddler" de pe forum, mi-a spus ca imi trebuie codul de log in, el i-a facut si unui prieten pe golf 4 cu acelasi vag-com.ai vreo idee?ms.
NU se poate face cu vag-com la Fabia 1 ! Iti trebuie vds-pro !
Mai vrei alte idei ?
Modificat de bebeko
Ma poti ajuta ? tu ti-ai facut,a mea e din 2002,ELEGANCE, se poate face?ms pt raspuns.
Multumesc! Am sa te tin la curent cu ce fac, eu mi-am facut deocamdata sa se incuie singura la 15kmh si sa se descuie la scoaterea cheii din contact si a mers prin vag-com, am sa caut pe cineva cu VDS si te anunt,ms mult !
Mai poti sa activezi avertizare luminoasa / sonora la inchiderea/deschidera usilor ( am avut dar am renuntat la avertizarea sonora la deschidera usilor ).
Sa se deschida la prima apasare a butonului de pe telecomanda doar usa sofer, pe urma la a doua apasare celelalte usi ( am avut dar am renuntat ).
Doar cu vag-com.
Exista colegi pe forum care au vds-pro.
Modificat de bebeko
Imi poti da si mie procedura cu avertizarea sonora la inchiderea/deschiderea usilor? si cu usa la sofer ?
Eu sunt din brasov,nu cred ca este nici un forumist cu vds-pro din brasov,sti pe cineva in apropiere ?
MULTUMESC MULT !
Daca citesti, scrie si mai sus ( postul 2 ), dar iti extrag unele pasaje:
[select]
[Adaptation - 10]
[save]
Pentru activare cu vds-pro, citeste pe larg aici : http://vwforum.ro/index.php?showto...2321&st=420
Modificat de bebeko
Credeam ca sunt altele, din cate imi aduc aminte nu cred ca mergeau, ori asta e doar pt masinile cu geamuri manuale ?dupa cum vad la inceput, ca eu am luat toate alea de mai sus,dar nu cred ca a incercat baiatul sa-mi bage astea.
A ta din ce an e ? ms.
este cineva din ploiesti sa ma ajute si pe mine cu o setare de vag-com la fabia mea?
Vreau sa setez toate geamurile electrice sa se ridice cand incui masina din telecomanda.
In motentul de fata daca bag cheia in butuc si tin in pozitia inchis se ridica toate 4, dar vreau sa am si din telecomanda sa nu frec butucul.
Cu stima
din cate stiu iti tb un cablu serial, pus pe un laptop mai vechi care are mufa serial...
c-am greu mai gasesti asa ceva
este un tutorial undeva pe aici pe forum
